Blocking incoming call based in Caller ID
I'm looking for a way to block an incoing call based on the Incoming callers Caller ID. The gateways we are using are H323 gateways. Does anyone have a good idea how to do this in either the gateway or call manager?
A sample of code would be appreciated if it is a router h323 config.
Thanks in advance.
1 REPLY
Bronze
Re: Blocking incoming call based in Caller ID
Yes you can block the calls based on caller id .You have to use voice translation rules and apply this to incoming voice dial-peer
voice translation-rule 1
rule 1 reject \^2142146000\
voice translation-profile incoming
translate called 1
voip-incoming translation-profile incoming
Radhika
148
