09-11-2002 07:28 AM - edited 03-12-2019 08:43 PM
Hi, I want to set up a route pattern to block a PSTN number from accessing my IP telephony network. I know how to set up route patterns in call manager but I suspect that this affects only outbound calls. I need to know what to do to handle inbound calls.
I heard that personal assistant can be used to do this sort of thing but I do not have it and the matter is rather urgent.
Any suggestion would be appreciated.
Ade
09-12-2002 10:50 AM
I would handle it on the gateway. Try this on your dial-peer.
Rick
09-13-2002 05:33 AM
Hi Rick,
Thanks a lot for your suggestion. I tried putting in the command but it was not recognised. I curently run IOS 12.2 XN with MGCP dial peers. Or is this command available with only H323?
Ade
09-13-2002 11:51 AM
May only be able to do it on h323. That command was implemented in IOS 11 code.
09-14-2002 01:02 PM
Thanks Rick,
I just upgraded the IOS to 12.2.11T and still could not get the command in. I guess it is just for H.323
Thanks for your help.
Ade
