bogen paging via h323 fxo port
have an existing set up with a vic-2fxo in a vg200,using h323 to a bogen pcm2000. works fine. i am trying to move the line to a 2821 isr with a vic2-4fxo card. config is same but when i try to access the bogen, after a few seconds, i get what sounds like a busy tone from the bogen.
from the vg200, i hear a 2-beep confirmation tone and then i'm connected through, but from the 2821 i get this constant beep tone. the dial-peer sends a 00 to the bogen, but when connected to the 2821 fxo, it sounds like the digits aren't being sent and thus the constant beeps. i've tried dialing the 00 after getting connected, but get same beeps.
any ideas? could the cards have different settings that require a different config?
thanks
rob
Bronze
Re: bogen paging via h323 fxo port
I think there is a misconfiguration in the dial peer settings in the router's voice port .
Try useing the steps in this document to help.
1807
