Community Member
bri mgcp backhaul with ccm 4.1(3)
Hello guys,
I tried to configured a BRI interface on a 1760 as an MGCP GW with the CCM 4.1(3) but it doesn't work. Everything looks fine, the "sh ccm-manager" shows that I'm registered with the right CCM, I also can see that the BRI endpoint is registered on the GW page on CCMADMIN.
The problem is located on the ISDN bri connection: the Layer 2 is TEI_ASSIGNED.
When I remove the ccm-manager binding on the bri interface, the layer 2 comes up and the state is MULTIPLE FRAME ESTABLISHED. And as soon as I reenter the "isdn bind-l3 ccm manager service mgcp" command, the layer 2 state changes to TEI_ASSIGNED. Here is my config (very simple):
router#sh run
Building configuration...
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router
boot-start-marker
boot system flash flash:c1700-advipservicesk9-mz.123-11.T3.bin
boot-end-marker
enable password 7 <removed>
tdm clock bri-auto
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 3
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
no ftp-server write-enable
isdn switch-type basic-net3
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server <removed>
ccm-manager config
interface FastEthernet0/0
ip address <removed>
interface BRI1/0
no ip address
shutdown
interface BRI3/0
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
interface BRI3/1
no ip address
isdn static-tei 0
ip classless
no ip http server
no ip http secure-server
control-plane
voice-port 3/0
compand-type a-law
cptone FR
voice-port 3/1
compand-type a-law
cptone FR
mgcp
mgcp call-agent <removed> 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
application mgcpapp
port 3/0
dial-peer voice 2 pots
application mgcpapp
port 3/1
line con 0
line aux 0
line vty 0 4
login
end
and here are the output for the debug isdn q921:
01:34:12: ISDN BR3/1 Q921: User RX <- IDCKRQ ri=0 ai=0
01:34:12: ISDN BR3/1 Q921: User TX -> IDCKRP ri=4224 ai=0
01:34:13: ISDN BR3/1 Q921: User RX <- SABMEp sapi=0 tei=0
01:34:13: ISDN BR3/1 Q921: S4_SABME: BACKHAULED & vsc_wants_L2_up = FALSE
01:34:14: ISDN BR3/1 Q921: User RX <- SABMEp sapi=0 tei=0
01:34:14: ISDN BR3/1 Q921: S4_SABME: BACKHAULED & vsc_wants_L2_up = FALSE
As the bri connection works fine without the ccm-manager l3 binding, I don't think it's caused by the Telco.
Thanks for your help
jp
Bronze
Re: bri mgcp backhaul with ccm 4.1(3)
hi,
firts do not add the "application mgcpapp" command to voice dial peers that support BRI backhaul.
seems to be an ios issue. try it with 12.4. ios image.
greetings
mehmet
Community Member
I was the IOS image. None of the 12.3(11) worked, but with a 12.3(14) it works fine.
Strange, because according to Cisco, 12.3(11) should work.
jp
Community Member
Thank you for posting your solution. Our 2811 was running 12.3(11)T5 and had the same problem with a PRI on a VWIC-1MFT-T1. Debug of ISDN q921 showed state as TEI_ASSIGNED. Upgraded to 12.3(14)T6 and state changed to MULTIPLE_FRAME_ESTABLISHED.
Thanks again.
vl
822
