Broadcasting over 79xx VoIP speakerphones
bthomaso2
Does anyone know if Call Manager has a function where you can broadcast over the speakerphones in an emergency situation? If not, are there products that can do this? Ideally, I'd like something where I can create groups and broadcast to specific groups or to the entire campus.
5 Replies 5
Jaime Valencia
no, we do not provide paging
try berbee informacast
java
if this helps, please rate
java
Rob Huffman
Hi Brian,
This feature (Group Paging) is not built-in to any CUCM version (including 7.x, unlike CME) but is most possible (via IP Phone speaker and Overhead) using these highly rated Third party products;
CDW-Berbee Informacast
http://www.berbee.com/public/berbeesoftware/InformaCast.aspx
IPCelerate
http://www.ipcelerate.com/assets/docs/IPcelerate_ER.pdf
Hope this helps!
Rob
Thanks much! I will check these out.
Hi, just for additional info, I'm testing the evaluation software SA-Announce from syn-apps
www.syn-apps.com
so far so good,
Best regards
David
That's good to know. Thanks!
