Business Telephone System questions
I have some questions that maybe someone can help me to understand:
1. In a business telephone system, is the PRI that is used the same as an ISDN PRI?
2. If so, is it exactly the same?
3. One a PRI, is there one channel per phone call, so you have a maximum of 24 phone calls per PRI?
4. How does the telephone system get the phone call outside the building to another caller?
5. If you have a DID line and want to FAX sensitive documents, is it secure? Should it be encrypted?
6. What does it mean when someone becomes a POP?
Bronze
Re: Business Telephone System questions
- PRI is the same as an ISDN PRI, ISDN is the underlying signalling and you can have PRI(23B channels and 1D channel) and BRI (2B channel and 1D channel)
- Yes should be the exactly same
Right one call per channel but the max calls you can have is 23. The last channel is used for signalling.
You order the PRI from a telephone company, so on one side the PRI is connected to your PBX and on the other side to the telephone company's switch. This connection means your PBX is esentially connected to Public Switch Telephone Network (PSTN). From here you can call anyone else that is connected to the PSTN.
I would encrypt the fax if the document is sensitive. They have fax machines that offer security features.
Guess they had a new addition in the family :) Only acronym of POP in telecom I know is Point of presence, is that what you mean?
Hall of Fame Super Red
Hi Milan,
Nice answer here and good sense of humour as well! 5 points from this end.
Rob
208
