Busy tone after ISDN DISCONNECT message
I have Cisco CallManager 4.1(3) and Cisco 2811 router as a gateway between VoIP and PSTN. Cisco 2811 fowards all calls that begins with "9" to PBX. It's simple and traditional design, isn't it? Here is the dial-peer:
dial-peer voice 9 pots
destination-pattern 9T
translate-outgoing calling 34000
direct-inward-dial
port 0/0/0:15
forward-digits all
The problem: users don't hear busy tone when a PSTN number is busy. Telco sends DISCONNECT message through ISDN (with cause i = 0x8091 - User busy) and CCM just drops the call :(
How do I make CCM (or gateway?) to generate busy tone to Cisco IP phone users?
P.S. I've employed "voice call convert-discpi-to-prog always" command - no effect. I've also turned on "Retain Media on Disconnect with PI for Active Call" option in CCM. Nothing changed.
Silver
Re: Busy tone after ISDN DISCONNECT message
I think there are no available channels for the call to complete
http://www.cisco.com/warp/public/471/bri-mppp.shtml
i dont think so, because the call is outgoing, so if the PBX sent the DISCONNECT/busy its because :
a.- The PBX dont have a channel available to make the call out to the PSTN
b.- The final user its occuping its phone
The real problem its that the Gw dont recongnize the BUSY signal and simply drop the call, i had the same issue, and we need to change from PRI to QSIG, and the issue was resolved.
I hope it help....
Greetings
Rodrigo
Green
Add:
Router(config)#voice rtp send-recv
Router(config)#voice call send-alert
Telco should send Disconnect with Cause IE = User Busy.
He can include a Progress IE = 8, in this case and with the command configured :
This Disconnect will be mapped to Progress, Voice path will Cut Thru and IP phone will hear busy tone send by PSTN.
Does he send a Release Complete after Setup or do you also see the Call Proceeding?
Also, including a PI = 3 in the outgoing Setup can help.
In this way we are indicating to PSTN we are a NON-ISDN terminal and need info INBAND.
configure following on the Outgoing POTS :
progress_ind setup enable 3
and
progress_ind alert enable 8
As long as the Telco does not send the correct Cause IE we will not hear a busy tone although this is not the case.
A debug voice ccapi inout will be great.
Let us know
1373
