C1721 + VIC-2BRI-S/T: Is it possible ???
Following data sheets, C1721 accepts VWIC cards in one of its slots.
But the VIC-2BRi is not listed as a possible interface cards for this router.
I'm surprised to think it would not be possible.
Can anybody confirm, before I buy it to try ?
And if it's true, which smallest router could be used for voice toll bypass design with an DSL connection + 1Ethernet + 1 VIC-BRI ?
I simply want to transport voice packets from different branch office, in&out some others branch offices PSTN/ISDN in others countries (call cost reduction)
Thanks to help me on this architecture choice for SME.
1 ACCEPTED SOLUTION
Re: C1721 + VIC-2BRI-S/T: Is it possible ???
The answer is no. The 1721 has no capability for voice DSPs - the VWICs it can have are for data applications only, such as the VWIC-MFT terminating channelised connections for leased line / data use.
You would be best off with a 1751-V or 1760-V that can support the VIC-2BRI-NT/TE and ADSL, but be aware there may not be QoS support over DSL on these platforms yet - you will need to check the release notes for this!
We use the VIC-2BRI (in a NM-2V) for connection to PABXs and this works fine.
Regards.... Phil.C
1 REPLY
Regards.... Phil.C
90
