Community Member
c2600 bearer cap issue
Hi all!
On a 2651XM with 2 BRI port, we recognize a strange problem. Direct inward dialing is ok, let's say on phone 2105. If I redirect a phone in the PSTN to 2105 (redirected by provider network), the provider network sends a additional information with the call, so the call will fail with the ISDN debug message "ISDN ERROR unsupported bearer cap".
Does anybody know about that problem?
Thanks, Andy
Re: c2600 bearer cap issue
We need to see what are that additional information which comes with the isdn SETUP message for a forwarded call which is not received in the regualr dialin call.
So pl. enable the "debug isdn q931" and make a call directly from pstn to that 2105 AND also capture the same for a call forwarded to that 2105. Post both the isdn debug here so that we can compare.
Community Member
Thanks for the reply. Here a quick describtion of th e situation:
First Call to phone "22" from "0794060041" (calling id is not visible because it is anonymous!) is ok. Then I redirect the phone "0794060041" to "22" and call it from another phone, the call fails. Below you can find thew debuging of this behaviour:
voicegate01#
Apr 29 08:35:42.683: ISDN BR1/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Calling Party Number i = 0x00A3
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '22'
Plan:ISDN, Type:Unknown
Apr 29 08:35:42.703: ISDN BR1/1 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Apr 29 08:35:42.731: ISDN BR1/1 Q931: TX -> ALERTING pd = 8 callref = 0x81
Apr 29 08:35:50.479: ISDN BR1/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x8090 - Normal call clearing
Apr 29 08:35:50.483: ISDN BR1/1 Q931: TX -> RELEASE pd = 8 callref = 0x81
Apr 29 08:35:50.567: ISDN BR1/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
voicegate01#
voicegate01#
voicegate01#
Apr 29 08:36:30.071: ISDN BR1/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Facility i = 0x91A1130202152602010F300A0201010A0101A1028100
- ETSI Supplementary Service, Invoke, Diverting leg 2
Progress Ind i = 0x8583 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '0313840511'
Apr 29 08:36:30.075: ISDN BR1/1 **ERROR**: host_incoming_call: Received a call with a bad bearer cap from on B
Apr 29 08:36:34.067: ISDN BR1/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Apr 29 08:36:34.075: ISDN BR1/1 **ERROR**: host_incoming_call: Received a call with a bad bearer cap from on B
Apr 29 08:36:38.067: ISDN BR1/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x82E6 - Recovery on timer expiry
Apr 29 08:36:38.071: ISDN BR1/1 Q931: L3_Go: L3_GetUser_NLCB returned NULL cid 0x0 cr 0x81 ev 0x45 ces 1 -- Message igno
red
Apr 29 08:36:38.075: ISDN BR1/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Cause i = 0x80D1 - Invalid call reference value
Thanks for your support!
Andy
210
