c549 DSP - Per Call DSP Usage... ???
kneg
Hi ALL !
From Cisco.com:
C549 technology is available to support either medium complexity codecs or high complexity codecs.
C549 voice cards support four voice/fax-relay calls per DSP with medium complexity codecs.
C 549 voice cards support two voice/fax-relay calls per DSP with high complexity codecs.
We have VFC board:
show vfc 1 board
VFC board state is UP, vfc status VCWARE running(0x4)
VFC board in slot 1 with 30 dsps
Does this VFC board support max 120 simultaneous calls
with g729r8 codec ?
Thanks for ALL !
mimckee
I could be wrong, but that sounds right to me. g729r8 is a medium complexty codec and if you have 30 dsps and 4 calls a dsp you would be 120.
Hope this helps,
-Mckee
pacameron
Level 4
Level 4
Can't tell from this. Do a 'sh vfc 1 dir' to see what DSP code the voice card is running. The filename will tell you if it is running C542 or C549 DSPs. If you have C549's and a 4 port E1 card, then you should be able to make 120 calls using medium complexity (G729/G711) codecs.
hi, Sir :
why i cann't use the command show vfc in my router 3845, IOS is 12.4(24), what's the command is familiar to show vfc
