Cable for CAT4224 high-density analog module?
I need to find a vendor who makes a compatible cable for the WS-X4604-GWY and Catalyst 4224 high-density analog module. This would be an RJ-21 Amphenol connector to 8 RJ-11 Female connectors. I don't <think> there is a cisco part number for this. Any info greatly appreciated, thanks in advance.
1 REPLY
Re: Cable for CAT4224 high-density analog module?
It's really a standard RJ-21 telco cable so you can get it from any supplier that carries them, and patch panels if you need one. On the patch panel, the first 8 ports would be the ones used.
Also, in case you didn't already have this, the pinouts for the card can be found at:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/inst_nts/ags_inst/cable.htm
86
