calculating the ratio of required trunks to phone users
Is there a rule of thumb for calculating the ratio of required trunks to phone users?
Assuming a small environment, where I don’t have any measured value of BusyHours, Erlangs,
i.e. if I only have 25 phone users – not very busy – it’s not a call center. What’s a reasonable number of trunks?
What about if I have 50 phone users?
Silver
Re: calculating the ratio of required trunks to phone users
The short answer is that there is no easy answer. A through answer to your question needs to take into account a number of variables (size of the telco switch, calling patterns of the subscribers and size of the local metropolitan area).
Try:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087acf.html
Any estimate will vary wildly based on your type of business. If most of your business is done on the web or face to face, 2 trunks may be sufficient for 25 users. If however, most of your business is done on the phone and your 25 users each spend 75% of the day on the phone, you might need a PRI. I would recommend estimating the busy hour traffic and using an Erlang calculator such as the one below.
http://www.erlang.com/calculator/erlb/
Hope this helps. If so, please rate the post.
Brandon
you better have a look here:
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_white_paper09186a00800d6b74.shtml
(IP Telephony/Voice over IP (VoIP) Traffic Analysis)
also look at the CallManager capacity tool
http://www.cisco.com/cgi-bin/CT/CCMCT/ct.cgi
normally you use 4 BHCA for a normal user,
but you need to know how long the average calls are,
i.e. 3/5/10 minutes
413
