09-26-2006 12:15 PM - edited 03-13-2019 03:07 PM
i have a user who cant receive incoming phone calls on a line if she is already on the phone. the second caller will hear " call can not be completed as dialed".
any ideas?
09-26-2006 12:49 PM
What are the Max Calls, Busy Trigger, and Call Forward Busy destination settings for this DN?
Brandon
09-26-2006 02:18 PM
Max Calls - 4
Busy Trigger - 2
Call Forward Busy - voicemail "checked" - destination empty - ccs empty
09-27-2006 04:40 AM
I assume you can call the voicemail pilot DN from this DN?
Brandon
09-28-2006 01:15 PM
yes - things work fine until she is on the line with another call.
i'm going to troubleshoot tonight.
i'll post results this week.
12-04-2006 12:15 PM
Hi Jerry,
Did you solve your issue ? I'm having a similar one here: when the user's on the line, we get a reorder tone. The CFB & CFNA are set to go to VM.
The workaround is to uncheck the boxes to disable the forwards to VM, fill the box with the DN of the VoieMail Pilot, update, reset and then it works. After that, we check the boxes to set the forwards to go to VM and it's ok. Any ideas ?
Thanks.
