Call control and Firewall
Hi all,
I have a question with regard to what ports should be open on firewall to allow voice call through.
For example I have two offices one in Sydney and one in Melbourne. The call manager is in sydney. Both offices has pix firewall. Now if sydney office has to make a call to Melbourne office, the Sydney office firewall will allow to pass the voice call as it is going from inside to outside. How about Melbourne office firewall. What need to be done on that firwall to allow a call from outside (Sydney) to inside. If the answer is to open ports from 16XXX to 32XXX, is it not a big threat to the network or is there is any other way to do it.
Tks
1 REPLY
Re: Call control and Firewall
Here is a link to a document which lists the TCP/UDP ports used by CallManager:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801a62b9.shtml
Below is a document which describes how to use application inspection to avoid opening a range of ports as you have described above. Application inspection can open ports dynamically based on a given protocols needs. Take a look at the section called Configuring Application Inspection (Fixup). Here you will see sections for SCCP, MGCP, H.323, etc.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a008017278b.html#wp1078381
Hope this helps.
Brandon
98
