call detail record analysis on cisco gateway
i want any software for cdr analysis in the gateway
can anybody help me,if so it will be helpful
Re: call detail record analysis on cisco gateway
I use Infortel's VoIP View. Not cheap, but a great call accounting software.
I am not sure exactly what you are wanting. Are you wanting a software package that analyzes Cisco CallManager CDR records? And need to catorgorize the calls that go out the gateway? Or are you wanting some CDR program that runs on the gateway itself?
Thank you,
-Mckee
yes i want to run some package at the gateway to account all the details happening in the gateway
u can download a software called telecount from www.telecount.com ; its an evaluation copy for 60 days.Its quite good to use to capture your cdrs. I guess that would do it for u, it can capture cdrs from multiple gateways too
I would suggest from my personal expiriance to use Cisco Secure v.3.00
It is easy to use, it is Radius base that supports Cisco VSA and h.323 attributes for VoIP accounting.
302
