call drop after hold press
CCM----ICT-----CCME
Calling from CCM4.1 IP Phone to phone in CCME and placing it on hold, the call is dropped. The trace does not help me much. Anyone has experienced this issue?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: call drop after hold press
Do you have MOH in seperate device pool with different Region using g.711 wheareas the dial-peer uses g.729 (default)? Try adding codec g711 ulaw on the dial-peer or create "voice-class codec" listing g711 and g729 and assign this to the dial-peer.
HTH,
Chris
Try Bug - CSCsa90359
Thank you but this is not the case because the line is not shared
HTH,
Chris
i changed the trunking from ict to h323 and the issue was solved, thank you anyway
185
