Call Drop problem in IPCC
We have IPCC enterprise network and we are facing call drop problem within conversion between Agents and callers.
Can any body provide us the guide lines that we can identify the root cause of drop calls.
Muzammel
Re: Call Drop problem in IPCC
hi muzammel
this problem can be caused by packet drops check your connectivity and make sure there is no packet drops in your links
Hi Shahid,
Thanks for the reply. Yes, call can drop for packet loss in the network and for many others issus like weak gsm signal. But how can identify that this drop is for what cause.
Any mechanism in ICM that we can identify the drop calls causes.
Muzammel
Hi Muzammel,
You can run Agent Call Detail report and check the reasoncode of every state, Reason code vary with UCCX and UCCE deployment. Reason code details are mentioned on top of report page.
You can also configure IP SLA Monitor on your voice gateways to check QoS achievements.
Iftikhar Ahmed
Hi Muzammel,
You should open a case with Cisco Tac to start some traces.
Justin
362
