Call drops with 15 secs
I sending the call to the my service provider, they using cisco gateway. Every 15 secs the call will drop, I try using as5300 and 3640 with FXO cards to send the call, however, the result is the same. How to solved the problem? Thanks!
Debug information
Q931 Message IE Decodes
Protocol Discriminator : 0x08
CRV Length : 2
CRV Value : 0x8010
Message Type : 0x5A: RELEASE_COMP
Cause: Length Of IE=2
Data 80BF
User-User: Length Of IE=33
Data 052580060008914A0002011100BDA6C6F7150611CC8061E9F713713ADB06800100
02:53:50: cc_api_call_disconnected(vdbPtr=0x620A1AC0, callID=0x28, cause=0x3F)
02:53:50: sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(40), disp(0)
02:53:50: cid(40)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(11)csize(0)in(0)fDest(0)
02:53:50: -cid2(39)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_CONFERENCED_ALERT)
02:53:50: ssa: Disconnected cid(40) state(5) cause(0x3F)
02:53:50: ccConferenceDestroy (confID=0xB, tag=0x0)
02:53:50: cc_api_bridge_drop_done (confID=0xB, srcIF=0x620A1AC0, srcCallID=0x28, dstCallID=0x27, disposition=0 tag=0x0)
02:53:50: cc_api_bridge_drop_done (confID=0xB, srcIF=0x62197CA4, srcCallID=0x27, dstCallID=0x28, disposition=0 tag=0x0)
CRV Length : 2
CRV Value : 0x0010
Data 80BF
CRV Length : 2
CRV Value : 0x8010
Data 80BF
02:53:50: sess_appl: ev(30=CC_EV_CONF_DESTROY_DONE), cid(39), disp(0)
02:53:50: cid(39)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(11)csize(0)in(1)fDest(0)
02:53:50: -cid2(40)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_ACTIVE)
02:53:50: ssaConfDestroyDone
02:53:50: ccCallDisconnect (callID=0x27, cause=0x3F tag=0x0)
02:53:50: ccCallDisconnect: existing_cause = 0x0, new_cause = 0x3F
02:53:50: ccCallDisconnect (callID=0x28, cause=0x3F tag=0x0)
02:53:50: cc_api_icpif: expect factor = 0
02:53:50: g113_calculate_impairment (delay=133,
loss=3), Io=0 Iq=0 Idte=0 Idd=0 Ie=22 Itot=22
02:53:50: cc_api_call_disconnect_done(vdbPtr=0x620A1AC0, callID=0x28, disp=0, tag=0x0)
02:53:50: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(40), disp(0)
02:53:50: cid(40)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_ACTIVE)cfid(-1)csize(0)in(0)fDest(0)
02:53:50: -cid2(39)st2(SSA_CS_DISCONNECTING)oldst2(SSA_CS_CONF_DESTROYING)
02:53:50: ssaDisconnectDone
02:53:50: cc_api_call_disconnect_done(vdbPtr=0x62197CA4, callID=0x27, disp=0, tag=0x0)
02:53:50: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(39), disp(0)
02:53:50: cid(39)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONF_DESTROYING)cfid(-1)csize(1)in(1)fDest(0)
02:54:12: cc_handle_periodic_timer: Calling the callback, ccTimerctx - 0x61CCA900
02:54:12: ccTimerStart: ccTimerctx - 0x61CCA900
Best regards,
Tony
1 REPLY
Silver
Re: Call drops with 15 secs
I am wondering how do you get Q931 debug message for FXO voice call drop. May be you should double check, if you monitoring the correct ports.
btw, use the following document to troubleshoot the FXO port issues
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a008007c9c0.html
147
