call fails - no circuit (34)
Hi all,
.. call fails, as you can see, to exit through dial-peer 200 and so are switched to dial-peer 100 (the reason is there is no circuit). I think gatekeeper and dial-peer configuration is ok. Also on the remote side everything should be configured ok. What problem do you think can be? I'm really in trouble.
show dial-peer voice 200:
VoiceOverIpPeer200
peer type = voice, information type = voice,
description = `',
tag = 200, destination-pattern = `.T',
answer-address = `', preference=1,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 200, Admin state is up, Operation state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
modem transport = system,
URI classes:
Incoming (Called) =
Incoming (Calling) =
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
type = voip, session-target = `ras',
technology prefix: 70
settle-call = disabled
ip media DSCP = ef, ip signaling DSCP = af31,
ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
ip video rsvp-fail DSCP = af41,
UDP checksum = disabled,
session-protocol = cisco, session-transport = system,
req-qos = best-effort, acc-qos = best-effort,
req-qos video = best-effort, acc-qos video = best-effort,
req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
RTP dynamic payload type values: NTE = 101
Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
CAS=123, ClearChan=125, PCM switch over u-law=0,A-law=8
RTP comfort noise payload type = 19
fax rate = voice, payload size = 20 bytes
fax protocol = system
fax-relay ecm enable
fax NSF = 0xAD0051 (default)
codec = transparent, payload size = 0 bytes,
Media Setting = flow-through (global)
Expect factor = 10, Icpif = 20,
Playout Mode is set to adaptive,
Initial 60 ms, Max 250 ms
Playout-delay Minimum mode is set to default, value 40 ms
Fax nominal 300 ms
Max Redirects = 1, signaling-type = cas,
VAD = enabled, Poor QOV Trap = disabled,
Source Interface = NONE
voice class sip url = system,
voice class sip rel1xx = system,
redirect ip2ip = disabled
probe disabled,
voice class perm tag = `'
Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 1144, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "22 ",
Last Disconnect Text is "no circuit (34)",
Last Setup Time = 300456456
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: call fails - no circuit (34)
gatekeeper and dial-peers configuration:
gatekeeper
zone local localGKname localdomain localGKIP
zone remote remoteGk1name remoteGK1domain remoteGK1IP 1719
zone remote remoteGK2name remoteGK2domain remoteGK2IP 1719
zone remote remoteGk3name remoteGK3domain remoteGK3IP 1719
zone subnet localGKname ...IP.../19 enable
zone prefix Gk1 50*
zone prefix Gk2 70*
zone prefix Gk3 70*
no shutdown
server registration-port 1718
dial-peer voice 100 voip
preference 10
destination-pattern .T
session target ras
tech-prefix 50
codec transparent
dial-peer voice 200 voip
session target ras
tech-prefix 70
codec transparent
1232
