Call Failure
hi.
We have a link with voice and data; a problem in the remote place is presented when is carried out a call since the central place; despues of the first one ring the following tone is of occupied.
I enclose information of some debug.
ACA#show config
Using 1551 out of 29688 bytes
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ACA
enable password 7 00071A150754
memory-size iomem 10
ip subnet-zero
ip host centra 172.25.0.5
voice-port 1/0/0
input gain 4
cptone MX
timeouts call-disconnect 1
voice-port 1/0/1
input gain 4
dial-peer voice 301 pots
destination-pattern 2809
port 1/0/0
dial-peer voice 302 pots
destination-pattern 2401
port 1/0/1
dial-peer voice 941 voip
destination-pattern +....
tech-prefix 7
ip precedence 5
session target ipv4:172.25.0.13
dial-peer voice 942 voip
destination-pattern 8
tech-prefix 7
ip precedence 5
process-max-time 200
interface Multilink1
ip address 172.25.0.14 255.255.255.252
no ip directed-broadcast
ip rtp priority 16384 16383 25
ip rtp header-compression iphc-format
ip tcp header-compression iphc-format
no ip mroute-cache
fair-queue 64 256 10
no cdp enable
ppp multilink
ppp multilink fragment-delay 20
ppp multilink interleave
multilink-group 1
interface Ethernet0/0
ip address 172.25.5.97 255.255.255.224
interface Serial0/0
bandwidth 64
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 172.25.0.13
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
password 7 030752180500
login
no scheduler allocate
end
ACA uptime is 2 weeks, 5 days, 1 hour, 20 minutes
System image file is "flash:c2600-is-mz.120-5.T"
cisco 2610 (MPC860) processor (revision 0x202) with 45056K/4096K bytes of memory.
Processor board ID JAD03333273 (3187356891)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
ACA#debug vtsp all
Voice telephony call control all debugging is on
ACA#term mon
2w5d: vtsp_do_call_setup_req
2w5d: vtsp_do_call_setup_req: Call ID=43143, guid=8133A060
2w5d: vtsp_process_event(): [1/0/0 (2496), 0.S_SETUP_REQUEST, E_TSP_PROCEEDING]act_setup_pend_proceeding
2w5d: dsp_close_voice_channel: [1/0/0] packet_len=8 channel_id=1 packet_id=75
2w5d: dsp_open_voice_channel_20: [1/0/0] packet_len=16 channel_id=1 packet_id=74 alaw_ulaw_select=0 associated_signaling_channel=0 time_slot=65535 serial_port=65535
2w5d: dsp_encap_config_20: [1/0/0] packet_len=24 channel_id=1 packet_id=92 TransportProtocol 2 t_ssrc=0x0 r_ssrc=0x0 t_vpxcc=0x0 r_vpxcc=0x0
2w5d: dsp_set_playout_delay: [1/0/0] packet_len=18 channel_id=1 packet_id=76 mode=1 initial=60 min=4 max=200 fax_nom=300
2w5d: dsp_echo_canceller_control: [1/0/0] packet_len=10 channel_id=1 packet_id=66 flags=0x0
2w5d: dsp_set_gains: [1/0/0] packet_len=12 channel_id=1 packet_id=91 in_gain=40 out_gain=65506
2w5d: dsp_vad_enable: [1/0/0] packet_len=10 channel_id=1 packet_id=78 thresh=-38
2w5d: vtsp_process_event(): [1/0/0, 0.S_SETUP_REQ_PROC, E_TSP_ALERT]act_setup_pend_alert
2w5d: vtsp_process_event(): [1/0/0, 0.S_SETUP_REQ_PROC, E_CC_BRIDGE]act_bridge
2w5d: vtsp_ring_noan_timer_start: 164661676
2w5d: vtsp_get_cdb: call_id (0x9BF) not found
2w5d: vtsp_process_event(): [1/0/0, 0.S_SETUP_REQ_PROC, E_CC_CAPS_IND]act_caps_ind
2w5d: act_caps_ind:Encap 1, Vad 2, Codec 0x4, CodecBytes 20,
FaxRate 2, FaxBytes 20 SignalType 0
DtmfRelay 1, Modem 1
2w5d: vtsp_process_event(): [1/0/0, 0.S_SETUP_REQ_PROC, E_CC_CAPS_ACK]act_caps_ack
2w5d: dsp_idle_mode: [1/0/0] packet_len=8 channel_id=1 packet_id=68
2w5d: dsp_cp_tone_off: [1/0/0] packet_len=8 channel_id=1 packet_id=71
2w5d: dsp_voice_mode: [1/0/0] packet_len=24 channel_id=1 packet_id=73 coding_type=19 voice_field_size=20 VAD_flag=1 echo_length=64 comfort_noise=1 inband_detect=1 digit_relay=0 AGC_flag=0
2w5d: dsp_cp_tone_on: [1/0/0] packet_len=30 channel_id=1 packet_id=72 tone_id=1 n_freq=2 freq_of_first=440 freq_of_second=480 amp_of_first=4000 amp_of_second=4000 direction=2 on_time_first=2000 off_time_first=4000 on_time_second=2000 off_time_second=4000
2w5d: vtsp_process_event(): [1/0/0, 0.S_SETUP_REQ_PROC, E_TSP_CONNECT]act_setup_pend_connect
2w5d: vtsp_ring_noan_timer_stop: 164661885
2w5d: vtsp_process_event(): [1/0/0, 0.S_CONNECT, E_TSP_DISCONNECT_IND]act_generate_disc
2w5d: vtsp_ring_noan_timer_stop: 164661902
2w5d: vtsp_process_event(): [1/0/0, 0.S_CONNECT, E_CC_BRIDGE_DROP]act_bdrop
2w5d: vtsp_process_event(): [1/0/0, 0.S_CONNECT, E_CC_DISCONNECT]act_disconnect
2w5d: vtsp_ring_noan_timer_stop: 164661903
2w5d: dsp_get_error_stat: [1/0/0] packet_len=10 channel_id=0 packet_id=6 reset_flag=1
2w5d: vtsp_timer: 164661903
2w5d: vtsp_process_event(): [1/0/0, 0.S_WAIT_STATS, E_DSP_GET_ERROR]act_get_error
2w5d: 1/0/0: rx_dropped=0 tx_dropped=0 rx_control=0 tx_control=105 tx_control_dropped=1028 dsp_mode_channel_1=12371 dsp_mode_channel_2=46694 c[0]=26313 c[1]=22283 c[2]=50504 c[3]=9827 c[4]=31511 c[5]=49219 c[6]=2023 c[7]=40060 c[8]=0 c[9]=1 c[10]=0 c[11]=1 c[12]=31089 c[13]=26467 c[14]=26221 c[15]=29817
2w5d: dsp_get_levels: [1/0/0] packet_len=8 channel_id=1 packet_id=89
2w5d: vtsp_process_event(): [1/0/0, 0.S_WAIT_STATS, E_DSP_GET_LEVELS]act_get_levels
2w5d: dsp_get_tx_stats: [1/0/0] packet_len=10 channel_id=1 packet_id=86 reset_flag=1
2w5d: vtsp_process_event(): [1/0/0, 0.S_WAIT_STATS, E_DSP_GET_TX]act_stats_complete
2w5d: vtsp_timer: 164661905
2w5d: vtsp_process_event(): [1/0/0, 0.S_WAIT_RELEASE, E_TSP_DISCONNECT_CONF]act_wrelease_release
2w5d: vtsp_process_event(): [1/0/0, 0.S_CLOSE_DSPRM, E_DSPRM_CLOSE_COMPLETE]act_terminate
2w5d: vtsp_free_cdb,cdb 0x81339E5C
2w5d: vtsp_tsp_call_setup_ind (sdb=0x813ED004, tdm_info=0x0, tsp_info=0x813ECF10, calling_number= called_number= redirect_number=): peer_tag=301
2w5d: vtsp_do_call_setup_ind
2w5d: vtsp_do_call_setup_ind: Call ID=70125, guid=8133A060
2w5d: vtsp_do_call_setup_ind: type=0, under_spec=0, name=, id0=0, id1=0, id2=0, calling=2809, called=
2w5d: dsp_close_voice_channel: [] packet_len=8 channel_id=1 packet_id=75
2w5d: dsp_open_voice_channel_20: [] packet_len=16 channel_id=1 packet_id=74 alaw_ulaw_select=0 associated_signaling_channel=0 time_slot=65535 serial_port=65535
2w5d: dsp_encap_config_20: [] packet_len=24 channel_id=1 packet_id=92 TransportProtocol 2 t_ssrc=0x0 r_ssrc=0x0 t_vpxcc=0x0 r_vpxcc=0x0
2w5d: dsp_set_playout_delay: [] packet_len=18 channel_id=1 packet_id=76 mode=1 initial=60 min=4 max=200 fax_nom=300
2w5d: dsp_echo_canceller_control: [] packet_len=10 channel_id=1 packet_id=66 flags=0x0
2w5d: dsp_set_gains: [] packet_len=12 channel_id=1 packet_id=91 in_gain=40 out_gain=65506
2w5d: dsp_vad_enable: [] packet_len=10 channel_id=1 packet_id=78 thresh=-38
2w5d: vtsp_process_event(): [, 0.S_SETUP_INDICATED, E_CC_SETUP_ACK]act_setup_ind_ack
2w5d: dsp_voice_mode: [] packet_len=24 channel_id=1 packet_id=73 coding_type=1 voice_field_size=80 VAD_flag=0 echo_length=64 comfort_noise=1 inband_detect=1 digit_relay=0 AGC_flag=0act_setup_ind_ack(): dsp_dtmf_mode()
dsp_dtmf_mode(VTSP_TONE_DTMF_MODE)
2w5d: dsp_dtmf_mode: [] packet_len=10 channel_id=1 packet_id=65 dtmf_or_mf=0
2w5d: vtsp_timer: 164661937
2w5d: vtsp_process_event(): [, 0.S_DIGIT_COLLECT, E_CC_GEN_TONE]act_gen_tone
2w5d: dsp_cp_tone_off: [] packet_len=8 channel_id=1 packet_id=71
2w5d: dsp_cp_tone_on: [] packet_len=30 channel_id=1 packet_id=72 tone_id=3 n_freq=2 freq_of_first=350 freq_of_second=440 amp_of_first=4000 amp_of_second=4000 direction=1 on_time_first=65535 off_time_first=0 on_time_second=65535 off_time_second=0
2w5d: vtsp_process_event(): [, 0.S_DIGIT_COLLECT, E_TSP_DISCONNECT_IND]act_generate_disc
2w5d: vtsp_ring_noan_timer_stop: 164662169
2w5d: vtsp_process_event(): [, 0.S_WAIT_HOST_DISC, E_CC_DISCONNECT]act_get_error_stats
2w5d: dsp_get_error_stat: [] packet_len=10 channel_id=0 packet_id=6 reset_flag=1
2w5d: vtsp_timer: 164662169
2w5d: vtsp_process_event(): [, 0.S_WAIT_ERROR_STAT, E_DSP_GET_ERROR]act_stats_complete
2w5d: : rx_dropped=0 tx_dropped=0 rx_control=0 tx_control=105 tx_control_dropped=3081 dsp_mode_channel_1=9062 dsp_mode_channel_2=48387 c[0]=63160 c[1]=35518 c[2]=64839 c[3]=1522 c[4]=52107 c[5]=33898 c[6]=12419 c[7]=37982 c[8]=0 c[9]=0 c[10]=0 c[11]=1 c[12]=7390 c[13]=12556 c[14]=14033 c[15]=16794
2w5d: dsp_idle_mode: [] packet_len=8 channel_id=1 packet_id=68
2w5d: vtsp_timer: 164662170
2w5d: vtsp_process_event(): [, 0.S_WAIT_RELEASE, E_TSP_DISCONNECT_CONF]act_wrelease_release
2w5d: vtsp_process_event(): [, 0.S_CLOSE_DSPRM, E_DSPRM_CLOSE_COMPLETE]act_terminate
DEBUG VPM ALL.
00:01:33: htsp_process_event: [1/0/0, 1.2 , 5] fxsls_onhook_setup
00:01:33: dsp_set_sig_state: [1/0/0] packet_len=12 channel_id=128 packet_id=39 state=0x0 timestamp=0x0htsp_alert
00:01:34: hdsprm_vtsp_codec_loaded_ok: G729 firmware needs download
00:01:34: dsp_download: p=0x80E9255C size=34172 (t=9462): 3A 66 6D
00:01:34: dsp_receive_packet: MSG_TX_RESTART_INDICATION: code=0 t=9471
00:01:34: dsp_download: p=0x80EAE79C size=31448 (t=9471): 33 6A AE
00:01:34: dsp_receive_packet: MSG_TX_RESTART_INDICATION: code=0 t=9480
00:01:34: htsp_process_event: [1/0/0, 1.5 , 11] fxsls_waitoff_voice
00:01:35: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=10063 systime=9592
00:01:35: htsp_process_event: [1/0/0, 1.5 , 34] fxsls_waitoff_offhook
00:01:35: dsp_set_sig_state: [1/0/0] packet_len=12 channel_id=128 packet_id=39 state=0x4 timestamp=0x0
00:01:35: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x4 timestamp=10070 systime=9593
00:01:35: htsp_process_event: [1/0/0, 1.3 , 26] fxsls_offhook_onhook
00:01:36: htsp_process_event: [1/0/0, 1.3 , 39] fxsls_offhook_timerhtsp_release_req, csb = 81205940, cause = 16
00:01:36: htsp_process_event: [1/0/0, 1.2 , 7] fxsls_onhook_release
00:02:09: htsp_process_event: [1/0/1, 1.2 , 5] fxsls_onhook_setup
00:02:09: dsp_set_sig_state: [1/0/1] packet_len=12 channel_id=129 packet_id=39 state=0x0 timestamp=0x0htsp_alert
00:02:09: hdsprm_vtsp_codec_loaded_ok: G729 firmware needs download
00:02:09: dsp_download: p=0x80E9255C size=34172 (t=12997): 3A 66 6D
00:02:10: dsp_receive_packet: MSG_TX_RESTART_INDICATION: code=0 t=13006
00:02:10: dsp_download: p=0x80EAE79C size=31448 (t=13006): 33 6A AE
00:02:10: dsp_receive_packet: MSG_TX_RESTART_INDICATION: code=0 t=13015
00:02:10: htsp_process_event: [1/0/1, 1.5 , 11] fxsls_waitoff_voice
00:02:11: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=45416 systime=13127
00:02:11: htsp_process_event: [1/0/1, 1.5 , 34] fxsls_waitoff_offhook
00:02:11: dsp_set_sig_state: [1/0/1] packet_len=12 channel_id=129 packet_id=39 state=0x4 timestamp=0x0
00:02:11: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x4 timestamp=45422 systime=13128
00:02:11: htsp_process_event: [1/0/1, 1.3 , 26] fxsls_offhook_onhook
00:02:11: htsp_process_event: [1/0/1, 1.3 , 39] fxsls_offhook_timerhtsp_release_req, csb = 81205940, cause = 16
00:02:11: htsp_process_event: [1/0/1, 1.2 , 7] fxsls_onhook_release
1 REPLY
Re: Call Failure
Here is a link that will help you interpret the debug output:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1700/1750/1750voip/debug.htm
275
