call flow (should this work)
I am trying to dial an extension from an external number (it has DID) this is the call flow
External device ---> Main GW---->CM---->Route Pattern----> Remote h323 GW--->FXS port--->device
I can call the device from other internal devices but not using its DDI, should this work?
below is the config of dial peer
dial-peer voice 3893 pots
destination-pattern 3893
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
fax rate disable
port 2/1
forward-digits all
Hall of Fame Super Silver
Re: call flow (should this work)
I am assuming that 3893 are the last 4 digits of the DID. All you need to do on the CCM is to create a route pattern 3893 and point it to the H323 GW, which where the FXS port is configured as:
voice-port 2/1
connection plar opx 3893
make sure that the the Main GW configuration in CCM has significant digits set correctly.
Rate all helpful posts!
Chris
thanks for your help, the digits coming in are actually 321893 which come through the main mgcp gateway, the go into cm to a translation pattern to remove the 32 and then replace 1 with a 3, so it becomes 3839, then there is a route pattern which send 3893 to the a another h.323 gw and then out off the fxs port.
when I dial from an external phone I can see the call procedding but do not hear ringing this end..
also a ccapi debug shows the call hiting the fxs gw,
do I need this command for it to work?connection connection plar 3893
121
