call-forward busy
I have the CME 3.3 with 7902 phones and I'm trying to do call-forward when extension 100 is busy to 101.
This is the configuration:
telephony-service
max-ephones 5
max-dn 5
ip source-address 192.168.3.1 port 2000
auto assign 1 to 5
user-locale ES
network-locale ES
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
transfer-system full-consult
directory entry 45 667433712 name Santi
directory entry 4 101 name pruebas
directory entry 20 667433712 name santi
ephone-dn 1 dual-line
number 100 no-reg primary
call-forward busy 101
call-forward noan 101 timeout 10
ephone-dn 2 dual-line
number 101 no-reg primary
ephone-dn 3 dual-line
number 102 no-reg primary
But doesn't runs neither call-forward busy and noan
when the extension 100 is busy, if you call you hear normal dial tone, but never is transfered.
Any ideas?
1 REPLY
Hall of Fame Super Red
Re: call-forward busy
Hi Santi,
Because this DN is set up as dual-line you need to add the following. Have a look;
The following example creates an ephone-dn with the number 1001 in dual-line mode. The no huntstop command allows calls to continue to hunt to other ephone-dns if this one is busy or does not answer. The huntstop channel command disables call hunting to the second channel of this ephone-dn if the first channel is busy or does not answer.
Router(config)# ephone-dn 10 dual-line
Router(config-ephone-dn)# number 1001
Router(config-ephone-dn)# no huntstop
Router(config-ephone-dn)# huntstop channel
Router(config-ephone-dn)# exit
From this CME doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611350.html#wp1056194
Hope this helps!
Rob
320
