04-23-2008 03:49 AM - edited 03-13-2019 05:11 PM
User wants to forward external calls only to cell phone and let the internal calls go to voice mail. Can this be done? 7941 phone;Call Manager 4.2;
Unity 4.0 Build 4.0(5)
Solved! Go to Solution.
04-23-2008 04:37 AM
Hi Mary,
Hope all is well :) This is not possible with Call Forward All but is possible with Forward No Answer and Forward Busy. For example;
Device>Phone>Selected DN>Call Forward and Pickup Settings>
Set;
Forward No Answer Internal - to VM Pilot#
Forward No Answer External - to Cell/Mobile (9-xxx-xxxx depending on dial plan) Make sure the CSS has External Access
Hope this helps!
Rob
04-23-2008 04:37 AM
Hi Mary,
Set;
Hope this helps!
Rob
04-23-2008 05:47 AM
Thanks, Rob!!!! I knew you would have the answer for me.
04-23-2008 05:58 AM
Hi Mary,
You are always welcome my friend :)
Take care,
Rob
04-24-2008 01:20 PM
hey that worked out pretty slick, thanks Rob!
04-24-2008 02:18 PM
Hi Mike,
Good stuff! Glad to be of some small help :)
Take care,
Rob
