Call Forward via SIP Trunk on CM5
Having a problem where CM 5 is unable to forward an external call to a voicemail server via a sip trunk. Calls from a SIP phone on CM5 to the vm server work fine. Calls between IP phones with the CFNA set to the vm work fine. Only external calls are having a problem. The gateway is an mgcp gateway. Here is the router config -
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
h323
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
header-passing
controller T1 0/3/0
framing esf
linecode b8zs
pri-group timeslots 1-4,24 service mgcp
controller T1 0/3/1
framing esf
linecode b8zs
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 10.0.2.50 255.255.255.0
duplex auto
speed auto
interface Serial0/3/0:23
no ip address
isdn switch-type primary-ni
isdn incoming-voice voice
isdn supp-service tbct
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/3/1:23
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.2.1
voice-port 0/3/0:23
voice-port 0/3/1:23
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.0.2.43
ccm-manager config
mgcp
mgcp call-agent 10.0.2.43 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
port 0/3/0:23
dial-peer voice 10 pots
service mgcpapp
port 0/3/1:23
dial-peer voice 2229 voip
service session
destination-pattern .T
redirect ip2ip
session protocol sipv2
session target ipv4:10.10.50.12
dtmf-relay rtp-nte
codec g711ulaw bytes 80
gateway
timer receive-rtp 1200
Is there something that I'm missing here?
The cm is 10.0.2.43
The vm server is 10.10.50.12
And yes, this router can ping it.
I tried using the "sip-ua" command but that didn't seem to have nay effect.
Brent
Re: Call Forward via SIP Trunk on CM5
Brent,
Quick question, why does the sip trunk have to come to the router and then go via sip to the voicemail server ? Cant you do direct sip integration to your voicemail server, since 5.0 has native support for sip ?
Just curious..
153
