Call Forward
Is there a way to change the call forward feature where user's extension is used instead of last name? (Unity 2.4)<br><br><br><br>
Anonymous
N/A
Re: Call Forward
you mean forwarding a message to another subscriber? You can always switch between selecting subscribers as recipients using their name or using their extension number by pressing "##". You can also change the default method (we default to spelling the name) on the conversations page for the subscriber in the SA (i.e. it can be set on a user by user basis).
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
Anonymous
N/A
Re: Call Forward
Hi!
Well that answers that... :) Is there any type of global change editor that works with Unity? I have over 300 users I need to make this change to.. :)
THanks!
don
Anonymous
N/A
Re: Call Forward
sure... on my web page there's a tool called "Bulk Edit" that allows you to make changes to large numbers of call handlers and/or subscribers. This tool will be shipping with 3.x soon but I have versions on my page for both 3.x and 2.x that have been used extensively in the field.
Jeff Lindborg
Cisco Systems
lindborg@cisco.com
102
