Call Forward
I am having troubles with call forwarding to a toll free number. It seems to have only stopped working since we upgraded from 3.1(2c) to 3.2(1)
The scenario is:
In Directory Number for a particular phone, under Call Forwarding and Pickup Settings I set the destination to 918664953574 (I also tried Cisco TAC number as a test), I get a busy signal when I dial the extension (in this case the extension is 1596). If I dial 918664953574 direct from a phone, it does work. If I use the local number 94953574 or another LD number 915619898721 for example, it does work. I haven't added any Route Filters and the only blocking route patterns I have are for 900 976 and 809
- Jim
Re: Call Forward
Jim,
Can you turn on detailed tracing and make the call? Look at the ccm trace for dd="1596".
Can you get the next 40-50 lines after that and paste them into this post. Then we can try and see what is happening. See if we are sending an outbound setup. Are you using 9.@ for your route pattern? Is that in a partition? If so make sure that the call forward all has a css assigned to it that can call that number.
Let me know what you find,
-Mckee
Re: Call Forward
03/05/2002 12:11:49.064 Cisco CallManager|Digit analysis: match(fqcn="7018", cn="7018", pss="API_Local:API_Long Distance:API_International", dd="1596")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Digit analysis: analysis results|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager||PretransformCallingPartyNumber=7018
|DialingPartition=
|DialingPattern=1596
|DialingRoutePatternRegularExpression=(1596)
|DialingWhere=
|PatternType=Enterprise
|PotentialMatches=NoPotentialMatchesExist
|DialingSdlProcessId=(1,37,984)
|PretransformDigitString=1596
|PretransformTagsList=SUBSCRIBER
|PretransformPositionalMatchList=1596
|CollectedDigits=1596
|UnconsumedDigits=
|TagsList=SUBSCRIBER
|VoiceMailbox=1596
|VoiceMailCallingSearchSpace=
|VoiceMailPilotNumber=4000
|DisplayName=
|RouteBlockFlag=RouteThisPattern
|InterceptPartition=
|InterceptPattern=1596
|InterceptWhere=
|InterceptSdlProcessId=(1,27,1)
|InterceptSsType=16777221
|InterceptSsKey=671|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 13 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|ForwardManager - wait_SsInterceptInd Received - Party= 0x1004870, InterceptKey= 0x29F |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|ForwardManager - findCallBySsParty - mPartyToActiveCallIndexMap entry NOT found for party= 0x1004870 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|ForwardManager - findActivationEntryBySsParty - mPartyToActivationIndexMap - Entry NOT found for party= 0x1004870|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|ForwardManager - addActiveCallTableEntry - Added entry for InterceptKey= 0x29F, Party= 0x1004870 CallKey= 0xC72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|ForwardManager - wait_SsInterceptInd - New Forward or Call Pickup started for Dn= 1596. Party= 0x1004870, InterceptKey= 0x29F, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - awaitForwardInitiation_SsInterceptInd - 1 CFA attempted. CallKey= 0xC72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - findInterceptTableEntry - mDnToInterceptIndexMap entry NOT found for dn= 918664953574, InterceptKey= 0x25FC71C |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - findInterceptTableEntry - mDnToInterceptIndexMap entry NOT found for dn= 918664953574, InterceptKey= 0x100652BC |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - findInterceptTableEntry - mDnToInterceptIndexMap entry NOT found for dn= , InterceptKey= 0x100652BC |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - formatRedirectCallReq - Using Orig Party CallKey= C72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - sendRedirectCallReq ForwardActiveCallEntry - Redirected Party= 0x1004870 Node= 1, to Dn= 918664953574 CSS= , CallKey= C72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - redirectCallToForwardAllDestination - Last Forward - Dn= 918664953574, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7018><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Insert an entry into CiCcp table, now this table has 25 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|StationD: 7294e84 SelectSoftKeys instance=1 reference=16795760 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Delete entries from CiCcp table, now this table has 24 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Digit analysis: match(fqcn="7018", cn="7018", pss="API_Local:API_Long Distance:API_International", dd="918664953574")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
|DialingPartition=
|DialingPattern=9.@
|DialingRoutePatternRegularExpression=(9)(1)(866)([2-9]XX)(XXXX)
|DialingWhere=(AREA-CODE == 800) OR (AREA-CODE == 888) OR (AREA-CODE == 877) OR (AREA-CODE == 855) OR (AREA-CODE == 866)
|PatternType=National
|DialingSdlProcessId=(1,87,3)
|PretransformDigitString=918664953574
|PretransformTagsList=ACCESS-CODE:LONG-DISTANCE-DIRECT-DIAL:AREA-CODE:OFFICE-CODE:SUBSCRIBER
|PretransformPositionalMatchList=9:1:866:495:3574
|CollectedDigits=18664953574
|UnconsumedDigits=
|TagsList=LONG-DISTANCE-DIRECT-DIAL:AREA-CODE:OFFICE-CODE:SUBSCRIBER
|PositionalMatchList=1:866:495:3574
|VoiceMailbox=
|DisplayName=
|InterceptPartition=
|InterceptPattern=
|InterceptWhere=
|InterceptSdlProcessId=(0,0,0)
|InterceptSsType=0
|InterceptSsKey=0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004870, BCC= 1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004870, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|RouteListCdrc - RouteListName = PRI-List; Processing route number 1; Trying to locate DeviceName = 10.64.15.111.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004870, BCC= 1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Default- BCC ignored. BCC= 1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|RouteListCdrc; Device 10.64.15.111 located.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.064 Cisco CallManager|RouteListCdrc (1,86,1625) extending call to Device (1,30,1)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
Re: Call Forward
What kinda gateway do you have? It looks like it is stripping the 9 is it suppose to? I really need to see the next 20-30 lines after what you have now. It looks like the call is getting forwarded again and I am not sure why.
Thank you,
-Mckee
Re: Call Forward
Here is the rest of the trace, I wasn't sure where to whack it off so I hope it's not too long.
The Gateway (10.64.15.111) is a VG200 with a 2 port PRI interface. It should not be removing the 9, we sue a 9 for all other direct outside calls. I have tried leaving the 9 out of the Destination field and it still failed.
03/05/2002 12:11:49.064 Cisco CallManager|Locations_reserveBandwidth -- cdccPID=(1.15.9153) Orig=Dest=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|H225Cdpc::TcpStartSessionRes: from H225Handler=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:49.236 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|Out Message -- H225SetupMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|Ie - H225BearerCapabilityIe IEData= 04 03 80 90 A2 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|Ie - Q931DisplayIe IEData= 28 0E 4A 69 6D 20 52 69 63 68 61 72 64 73 6F 6E |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|Ie - H225CallingPartyIe IEData= 6C 0C 20 81 38 35 38 35 35 32 32 32 30 30 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|Ie - Q931CalledPartyIe IEData= 70 0C A1 31 38 36 36 34 39 35 33 35 37 34 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|Ie - H225UserUserIe IEData= 7E 00 7B 05 20 B0 06 00 08 91 4A 00 02 01 40 0D 00 4A 00 69 00 6D 00 20 00 52 00 69 00 63 00 68 00 61 00 72 00 64 00 73 00 6F 00 6E 02 00 01 05 00 4B 99 7C 86 8A 70 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 00 49 0C 11 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 01 00 01 00 06 A0 01 00 19 01 40 B5 00 00 12 12 90 09 74 07 00 00 8F 31 35 39 36 04 40 04 00 01 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.236 Cisco CallManager|IsdnMsgData2= 08 02 06 59 05 04 03 80 90 A2 28 0E 4A 69 6D 20 52 69 63 68 61 72 64 73 6F 6E 6C 0C 20 81 38 35 38 35 35 32 32 32 30 30 70 0C A1 31 38 36 36 34 39 35 33 35 37 34 7E 00 7B 05 20 B0 06 00 08 91 4A 00 02 01 40 0D 00 4A 00 69 00 6D 00 20 00 52 00 69 00 63 00 68 00 61 00 72 00 64 00 73 00 6F 00 6E 02 00 01 05 00 4B 99 7C 86 8A 70 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 00 49 0C 11 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 01 00 01 00 06 A0 01 00 19 01 40 B5 00 00 12 12 90 09 74 07 00 00 8F 31 35 39 36 04 40 04 00 01 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.252 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.252 Cisco CallManager|In Message -- H225CallProceedingMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.252 Cisco CallManager|Ie - H225UserUserIe -- IEData= 7E 00 2A 05 21 C0 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D7 09 00 11 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 06 80 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.252 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.252 Cisco CallManager|IsdnMsgData1= 08 02 86 59 02 7E 00 2A 05 21 C0 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D7 09 00 11 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 06 80 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.330 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC49E, TCPHandle=0x3b0db20, Socket=0xe40, IPAddr=10.64.50.181, Port=52651, Device Controller=[1,92,427]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.181><:SEP0007EB7CC49E>
03/05/2002 12:11:49.330 Cisco CallManager|StationInit: 3b0db20 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.181><:SEP0007EB7CC49E>
03/05/2002 12:11:49.377 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB4621E6, TCPHandle=0x927de80, Socket=0x81c, IPAddr=10.64.50.156, Port=53108, Device Controller=[1,92,335]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.156><:SEP0007EB4621E6>
03/05/2002 12:11:49.377 Cisco CallManager|StationInit: 927de80 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.156><:SEP0007EB4621E6>
03/05/2002 12:11:49.377 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB5946E0, TCPHandle=0x3b0da58, Socket=0xd80, IPAddr=10.64.50.136, Port=52354, Device Controller=[1,92,425]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.136><:SEP0007EB5946E0>
03/05/2002 12:11:49.377 Cisco CallManager|StationInit: 3b0da58 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.136><:SEP0007EB5946E0>
03/05/2002 12:11:49.408 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00082166FA2D, TCPHandle=0x3b0d544, Socket=0x730, IPAddr=10.64.51.11, Port=51889, Device Controller=[1,92,413]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.11><:SEP00082166FA2D>
03/05/2002 12:11:49.408 Cisco CallManager|StationInit: 3b0d544 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.11><:SEP00082166FA2D>
03/05/2002 12:11:49.439 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007850569AF, TCPHandle=0xc2d65c8, Socket=0xb74, IPAddr=10.64.50.205, Port=53198, Device Controller=[1,92,438]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.205><:SEP0007850569AF>
03/05/2002 12:11:49.439 Cisco CallManager|StationInit: c2d65c8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.205><:SEP0007850569AF>
03/05/2002 12:11:49.439 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.439 Cisco CallManager|In Message -- H225ProgressMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.439 Cisco CallManager|Ie - Q931FacilityIe - Recognized only -- IEData= 1C 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.439 Cisco CallManager|Ie - Q931ProgressIndIe -- IEData= 1E 02 80 88 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.439 Cisco CallManager|Ie - H225UserUserIe -- IEData= 7E 00 40 05 28 00 21 40 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D7 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 06 A0 01 00 16 01 40 B5 00 00 12 0F 60 01 04 00 01 08 08 08 02 80 FF 1E 02 80 88 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.439 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.439 Cisco CallManager|IsdnMsgData1= 08 02 86 59 03 1C 00 1E 02 80 88 7E 00 40 05 28 00 21 40 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D7 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 06 A0 01 00 16 01 40 B5 00 00 12 0F 60 01 04 00 01 08 08 08 02 80 FF 1E 02 80 88 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.439 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 14 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.439 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.439 Cisco CallManager|ForwardManager - wait_SsRedirectCallRes - Received DestParty= 0x1004874, CallKey= 0xC72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.439 Cisco CallManager|ForwardManager - wait_SsRedirectCallRes - mPartyToActiveCallIndexMap Added Entry for DestParty= 0x1004874, CallKey= 0xC72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.439 Cisco CallManager|Forwarding - awaitingCallResponse_SsRedirectCallRes - DestParty= 0x1004874, CallKey= 0xC72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.439 Cisco CallManager|Forwarding - sendSsNotifyReq - to Party= 0x1004874, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.439 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=9.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:49.455 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004874, BCC= 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004874, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795760,16795764): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|ConnectionManager - storeMediaInfo(16795760): ADD NEW ENTRY, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|ConnectionManager - storeMediaInfo(16795764): ADD NEW ENTRY, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004874, BCC= 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Default- BCC ignored. BCC= 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6611) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaManager(6611) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaManager - wait_AuConnectRequest(capbility query) - creating connection between party1(16795760) and party2(16795764)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|StationD: 7294e84 CallState callState=12 lineInstance=1 callReference=16795760|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|StationD: 7294e84 CallInfo callingPartyName='Jim Richardson' callingParty=7018 cgpnVoiceMailbox= calledPartyName='' calledParty=18664953574 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=1596 originalCdpnVoiceMailbox=1596 originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty= lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795760. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795760, CallingPartyName=Jim Richardson, CallingParty=7018, CalledPartyName=, CalledParty=18664953574, OriginalCalledPartyName=, OriginalCalledParty=1596, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|StationD: 7294e84 DialedNumber dialedNumber=1596 lineInstance=1 callReference=16795760.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:49.455 Cisco CallManager|ProcessH245Interface(0) created w/ ip = 6f0f400a and port = 30679|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:49.455 Cisco CallManager|H245Interface(1545)::start (H245Client session) ip = 6f0f400a, port = 30679|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795760) and party2(16795764)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.455 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.455 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795760,16795764)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.611 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=7018:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.611 Cisco CallManager|StationD: 7294e84 SelectSoftKeys instance=1 reference=16795760 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.611 Cisco CallManager|StationD: c2d6f28 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:49.611 Cisco CallManager|StationD: c2d6f28 SelectSoftKeys instance=1 reference=16795762 softKeySetIndex=6 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:49.611 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="9")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:49.611 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:49.611 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7302><:SEP0007EB7CC489>
03/05/2002 12:11:49.611 Cisco CallManager|StationD: c2d6f28 StartTone tone=34(OutsideDialTone), direction=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager - wait_AuReConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6611)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, send ReconnectRequest to MC|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaCoordinator - wait_AuReConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6611) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6612) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager(6612) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.642 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.658 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.658 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795760) and party2(16795764)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.658 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.783 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI1, TCPHandle=0x725ef4c, Socket=0x11f8, IPAddr=10.64.5.21, Port=2421, Device Controller=[1,92,237]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI1>
03/05/2002 12:11:49.783 Cisco CallManager|StationInit: 725ef4c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI1>
03/05/2002 12:11:49.799 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=MTP_API-CM-1, TCPHandle=0x72946b4, Socket=0xa6c, IPAddr=10.64.5.11, Port=1451, Device Controller=[1,46,2]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.11><:MTP_API-CM-1>
03/05/2002 12:11:49.799 Cisco CallManager|StationInit: 72946b4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.11><:MTP_API-CM-1>
03/05/2002 12:11:49.845 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI2, TCPHandle=0x3b0c66c, Socket=0xc8c, IPAddr=10.64.5.21, Port=2422, Device Controller=[1,92,239]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:11:49.845 Cisco CallManager|StationInit: 3b0c66c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:11:49.845 Cisco CallManager|H245Interface(1545) OLC indication chan number = 1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.845 Cisco CallManager|StationD: 7294e84 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.845 Cisco CallManager|StationD: 7294e84 OpenReceiveChannel conferenceID=0 passThruPartyID=96977 millisecondPacketSize=20 compressionType=4(Media_Payload_G711Ulaw64k) qualifierIn=?. myIP: 9232400a (10.64.50.146)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.845 Cisco CallManager|StationInit: 7294e84 OpenReceiveChannelAck Status=0, IpAddr=0x9232400a, Port=20580, PartyID=96977|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.845 Cisco CallManager|H245Interface(1545) paths established ip = 9232400a, port = 20580|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:49.845 Cisco CallManager|H245Interface(1545) OLC outgoing confirm ip = 6f0f400a, port = 18484|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.845 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.845 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.845 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.845 Cisco CallManager|StationD: 7294e84 StartMediaTransmission conferenceID=0 passThruPartyID=96977 remoteIpAddress=6f0f400a(10.64.15.111) remotePortNumber=18484 milliSecondPacketSize=20 compressType=4(Media_Payload_G711Ulaw64k) qualifierOut=?. myIP: 9232400a (10.64.50.146)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:49.861 Cisco CallManager|Locations_adjustBandwidth -- cdccPID=(1.15.9153) Orig=Dest=0 no entry for cdcc. No need to adjust.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.861 Cisco CallManager|InboundStim - StationOffHookWithCgpnMessageID CallingPartyNumber=7140 CallingPartyVmbx= tcpHandle=0x3b0d60c|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c StationOutputDisplayText don't need to send, because mIsALegacyDevice = 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4015><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|CTI: RoutePatternToCtiGlobalCallID::findValue(): RP=4015:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.861 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::findValue() : RP=4015:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=2(LampOn).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationInit: 3b0d60c KeypadButton kpButton=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationInit: 3b0d60c KeypadButton kpButton=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationInit: 3b0d60c KeypadButton kpButton=9.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c CallState callState=1 lineInstance=1 callReference=16795765|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c DisplayPromptStatus timeOutValue=0 promptStatus='Enter Number' content='Enter Number' lineInstance=1 callReference=16795765 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c SelectSoftKeys instance=1 reference=16795765 softKeySetIndex=4 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c ActivateCallPlane lineInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI3, TCPHandle=0x3b0c860, Socket=0xcb4, IPAddr=10.64.5.21, Port=2450, Device Controller=[1,92,284]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI3>
03/05/2002 12:11:49.861 Cisco CallManager|StationInit: 3b0c860 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI3>
03/05/2002 12:11:49.861 Cisco CallManager|Insert an entry into CiCcp table, now this table has 25 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|Insert an entry into CiCcp table, now this table has 26 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|Digit analysis: match(fqcn="4015", cn="7140", pss="API_Local:API_Long Distance:API_International", dd="")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c StartTone tone=33(InsideDialTone), direction=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|StationD: 3b0d60c SelectSoftKeys instance=1 reference=16795765 softKeySetIndex=6 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.861 Cisco CallManager|Digit analysis: match(fqcn="4015", cn="7140", pss="API_Local:API_Long Distance:API_International", dd="1")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Digit analysis: match(fqcn="4015", cn="7140", pss="API_Local:API_Long Distance:API_International", dd="17")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Digit analysis: match(fqcn="4015", cn="7140", pss="API_Local:API_Long Distance:API_International", dd="179")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Digit analysis: match(fqcn="4015", cn="7140", pss="API_Local:API_Long Distance:API_International", dd="1799")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Digit analysis: analysis results|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager||PretransformCallingPartyNumber=7140
|DialingPartition=
|DialingPattern=
|DialingWhere=
|PatternType=Unknown
|DialingSdlProcessId=(0,0,0)
|PretransformDigitString=1799
|CollectedDigits=
|UnconsumedDigits=
|TagsList=
|VoiceMailbox=
|DisplayName=
|RouteBlockFlag=BlockThisPattern
|InterceptPartition=
|InterceptPattern=1799
|InterceptWhere=
|InterceptSdlProcessId=(1,50,1)
|InterceptSsType=16777226
|InterceptSsKey=69633|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 15 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|MessageWaitingManager - findInterceptTableEntry - Found Intercept table entry for dn= 1799, InterceptKey= 0x11001 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.877 Cisco CallManager|StationD: 3b0d60c CallState callState=12 lineInstance=1 callReference=16795765|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|StationD: 3b0d60c CallInfo callingPartyName='Voicemail' callingParty=4015 cgpnVoiceMailbox= calledPartyName='' calledParty=1799 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=1799 originalCdpnVoiceMailbox= originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty= lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795765. version: 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795765, CallingPartyName=Voicemail, CallingParty=4015, CalledPartyName=, CalledParty=1799, OriginalCalledPartyName=, OriginalCalledParty=1799, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|StationD: 3b0d60c DialedNumber dialedNumber=1799 lineInstance=1 callReference=16795765.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:49.877 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.877 Cisco CallManager|MessageWaiting - getting_call_info_SsCallInfoRes - MessageWaitingLamp for Dn= 7140 Turned OFF|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.877 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7140><:>
03/05/2002 12:11:49.877 Cisco CallManager|StationD: 3b0d2ec SetLamp stimulus=15(VoiceMail) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.877 Cisco CallManager|StationD: 3b0d2ec SetLamp stimulus=15(VoiceMail) stimulusInstance=0 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.877 Cisco CallManager|StationD: 3b0d2ec DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Your current options' lineInstance=0 callReference=0 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.877 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4015><:>
03/05/2002 12:11:49.877 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4015:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.892 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI4, TCPHandle=0x3b0c928, Socket=0xcc4, IPAddr=10.64.5.21, Port=2424, Device Controller=[1,92,238]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:49.892 Cisco CallManager|StationInit: 3b0c928 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:49.892 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0006D74B0EA1, TCPHandle=0x927caf8, Socket=0x760, IPAddr=10.64.50.241, Port=52470, Device Controller=[1,92,266]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.241><:SEP0006D74B0EA1>
03/05/2002 12:11:49.892 Cisco CallManager|StationInit: 927caf8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.241><:SEP0006D74B0EA1>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c SetSpeakerMode speakermode=2(Off).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c ClearPromptStatus lineInstance=1 callReference=16795765.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c CallState callState=2 lineInstance=1 callReference=16795765|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c DisplayPromptStatus timeOutValue=0 promptStatus='Your current options' content='Your current options' lineInstance=0 callReference=0 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c ActivateCallPlane lineInstance=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c DefineTimeDate timeDateInfo=? systemTime=1015359109.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|StationD: 3b0d60c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 14 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|Delete entries from CiCcp table, now this table has 24 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:49.892 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9155) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:49.908 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI5, TCPHandle=0x3b0c9f0, Socket=0xce0, IPAddr=10.64.5.21, Port=2425, Device Controller=[1,92,227]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI5>
03/05/2002 12:11:49.908 Cisco CallManager|StationInit: 3b0c9f0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI5>
03/05/2002 12:11:49.939 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI6, TCPHandle=0x3b0cb1c, Socket=0xd08, IPAddr=10.64.5.21, Port=2426, Device Controller=[1,92,236]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:49.939 Cisco CallManager|StationInit: 3b0cb1c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:49.970 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI7, TCPHandle=0x3b0cc48, Socket=0xd0c, IPAddr=10.64.5.21, Port=2427, Device Controller=[1,92,235]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI7>
03/05/2002 12:11:49.970 Cisco CallManager|StationInit: 3b0cc48 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI7>
03/05/2002 12:11:50.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI8, TCPHandle=0x3b0cd74, Socket=0xd1c, IPAddr=10.64.5.21, Port=2428, Device Controller=[1,92,228]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI8>
03/05/2002 12:11:50.002 Cisco CallManager|StationInit: 3b0cd74 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI8>
03/05/2002 12:11:50.017 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI9, TCPHandle=0x725efb0, Socket=0x1200, IPAddr=10.64.5.21, Port=2429, Device Controller=[1,92,233]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI9>
03/05/2002 12:11:50.017 Cisco CallManager|StationInit: 725efb0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI9>
03/05/2002 12:11:50.017 Cisco CallManager|StationInit: 3b0d60c OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:50.017 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4015:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.017 Cisco CallManager|StationD: 3b0d60c DefineTimeDate timeDateInfo=? systemTime=1015359110.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:50.017 Cisco CallManager|StationD: 3b0d60c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:50.017 Cisco CallManager|StationD: 3b0d60c SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:50.049 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C6778C, TCPHandle=0xc2d7054, Socket=0xdb0, IPAddr=10.64.50.48, Port=50162, Device Controller=[1,92,460]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.48><:SEP000750C6778C>
03/05/2002 12:11:50.049 Cisco CallManager|StationInit: c2d7054 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.48><:SEP000750C6778C>
03/05/2002 12:11:50.080 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI10, TCPHandle=0x3b0ce3c, Socket=0xd64, IPAddr=10.64.5.21, Port=2431, Device Controller=[1,92,234]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI10>
03/05/2002 12:11:50.080 Cisco CallManager|StationInit: 3b0ce3c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI10>
03/05/2002 12:11:50.080 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C6768E, TCPHandle=0xc2d662c, Socket=0x960, IPAddr=10.64.50.208, Port=52900, Device Controller=[1,92,439]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.208><:SEP000750C6768E>
03/05/2002 12:11:50.080 Cisco CallManager|StationInit: c2d662c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.208><:SEP000750C6768E>
03/05/2002 12:11:50.095 Cisco CallManager|StationInit: 3b0c928 Stimulus stimulus=4(Transfer) stimulusInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.095 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:CISCOUM1-VI4>
03/05/2002 12:11:50.095 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::store() : RP=4003:, bRc=1, CallOrigin=7, T=restart0_StationStimTransfer(), #entries=1|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.095 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 15 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.095 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 16 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.095 Cisco CallManager|TransferManager: SsInfoInd : init transfer,XFERringPriSsPty=16795744, XFERringPtyDslAddr (0,0,352665610,2424), XFERringPtyPID (1,37,445),XFERredSsPty=16795739, XFERredPtyDslAddr (0,0,20070410,2427), XFERredPtyPID (1,61,1).|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.095 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.095 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.095 Cisco CallManager|StationD: 3b0c928 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=3(LampWink).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 CallState callState=8 lineInstance=1 callReference=16795744|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI11, TCPHandle=0x3b0d094, Socket=0xd9c, IPAddr=10.64.5.21, Port=2432, Device Controller=[1,92,229]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI11>
03/05/2002 12:11:50.111 Cisco CallManager|StationInit: 3b0d094 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI11>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=1 reference=16795744 softKeySetIndex=2 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 DisplayPromptStatus timeOutValue=0 promptStatus='Hold' content='Hold' lineInstance=1 callReference=16795744 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795739,16795744): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|ConnectionManager - storeMediaInfo(16795744): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6606)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6606)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 CloseReceiveChannel conferenceID=0 passThruPartyID=96913. myIP: 1505400a (10.64.5.21)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 StopMediaTransmission conferenceID=0 passThruPartyID=96913. myIP: 1505400a (10.64.5.21)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16597 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
C: D00000000100485b00000000800014bf
I: 4
X: 4
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=4(LampFlash).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 StationOutputDisplayText don't need to send, because mIsALegacyDevice = 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16597
|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:50.111 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16597|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:50.111 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:50.111 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16597 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.111 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|CTI: RoutePatternToCtiGlobalCallID::findValue(): RP=4003:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.111 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::findValue() : RP=4003:, bRc=1, CallOrigin=7, T=, #entries=1|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.111 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::remove() : RP=4003:; bRc=1, T=await_ci_res_CcCiRes(), #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.111 Cisco CallManager|StationD - StationOutputSetLamp ignored|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 CallState callState=1 lineInstance=1 callReference=16795767|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 DisplayPromptStatus timeOutValue=0 promptStatus='Enter Number' content='Enter Number' lineInstance=1 callReference=16795767 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=1 reference=16795767 softKeySetIndex=4 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|StationD: 3b0c928 ActivateCallPlane lineInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.111 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795739) and party2(16795744)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.111 Cisco CallManager|Insert an entry into CiCcp table, now this table has 25 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|Insert an entry into CiCcp table, now this table has 26 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.111 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.111 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6606) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.111 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795739,16795744): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|Digit analysis: match(fqcn="4003", cn="4003", pss="API_Local:API_Long Distance:API_International", dd="")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.127 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.127 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq - MRGL=0,CREATED CHILD USING DEFAULT LIST|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-1 Group=0 Counter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-2 Group=0 Counter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc - Started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::findDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq MtpDevice=MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes MohResource=MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|Locations_reserveBandwidthForMediaResource -- cdccPID=(1.15.9149) UserParty=Media Source=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.127 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI12, TCPHandle=0x3b0d350, Socket=0xdb4, IPAddr=10.64.5.21, Port=2433, Device Controller=[1,92,232]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI12>
03/05/2002 12:11:50.127 Cisco CallManager|StationInit: 3b0d350 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI12>
03/05/2002 12:11:50.127 Cisco CallManager|MohDControl - AllocateMohResourceReq successfully - AudioSourceID and MuticastFlag = 1, 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|StationD: 3b0c928 StartTone tone=33(InsideDialTone), direction=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::resource_rsvp_AllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MRM::updateMohCounter MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MRM::updateMohCounter allocateCounter=1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceManager::waiting_MrmChildStopInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaResourceCdpc::shutting_down_MrmChildStopConf|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795739,16795769): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|ConnectionManager - storeMediaInfo(16795769): ADD NEW ENTRY, tail == 23|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6613) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.127 Cisco CallManager|MediaManager(6613) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:50.142 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795739) and party2(16795769)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795739,16795769)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16598 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
L: p:20, a:PCMU, s:off
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:50.142 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16598
03/05/2002 12:11:50.142 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16598|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:50.142 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16598 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
MDCX 16599 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
v=0
o=- 4 0 IN EPN S0/DS1-0/4@SDA00908F003733
s=Cisco SDP 0
t=0 0
c=IN IP4 0.0.0.0
m=audio 0 RTP/AVP 96
a=rtpmap:96 PCMU
03/05/2002 12:11:50.142 Cisco CallManager|MohDControl - stationOutputStartMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|MohDControl - RemoteIpAddr: 132400a (10.64.50.1) RemoteRtpPortNumber: 24224 msecPacketSize: 20 compressionType: 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
200 16599
03/05/2002 12:11:50.142 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16599|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:50.142 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16599 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:S0>
03/05/2002 12:11:50.142 Cisco CallManager|StationD: 3b0c928 SetLamp stimulus=4(Transfer) stimulusInstance=1 lampMode=4(LampFlash).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:50.158 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI13, TCPHandle=0x725f014, Socket=0x121c, IPAddr=10.64.5.21, Port=2464, Device Controller=[1,92,285]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI13>
03/05/2002 12:11:50.158 Cisco CallManager|StationInit: 725f014 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI13>
03/05/2002 12:11:50.174 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI14, TCPHandle=0x725f078, Socket=0x1228, IPAddr=10.64.5.21, Port=2465, Device Controller=[1,92,286]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI14>
03/05/2002 12:11:50.174 Cisco CallManager|StationInit: 725f078 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI14>
03/05/2002 12:11:50.205 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI15, TCPHandle=0x3b0d47c, Socket=0xd34, IPAddr=10.64.5.21, Port=2434, Device Controller=[1,92,231]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI15>
03/05/2002 12:11:50.205 Cisco CallManager|StationInit: 3b0d47c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI15>
03/05/2002 12:11:50.205 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.205 Cisco CallManager|StationD: c2d6f28 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.205 Cisco CallManager|StationD: c2d6f28 SelectSoftKeys instance=1 reference=16795762 softKeySetIndex=6 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.205 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="91")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.205 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.220 Cisco CallManager|StationInit: 3b0c928 KeypadButton kpButton=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.220 Cisco CallManager|StationD: 3b0c928 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.220 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=1 reference=16795767 softKeySetIndex=6 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.220 Cisco CallManager|Digit analysis: match(fqcn="4003", cn="4003", pss="API_Local:API_Long Distance:API_International", dd="7")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.220 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.236 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI16, TCPHandle=0x3b0d60c, Socket=0xe98, IPAddr=10.64.5.21, Port=2435, Device Controller=[1,92,230]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:50.236 Cisco CallManager|StationInit: 3b0d60c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:11:50.439 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644E74, TCPHandle=0x3b0d2ec, Socket=0x10a4, IPAddr=10.64.50.158, Port=51941, Device Controller=[1,92,409]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.158><:SEP0007EB644E74>
03/05/2002 12:11:50.439 Cisco CallManager|StationInit: 3b0d2ec KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.158><:SEP0007EB644E74>
03/05/2002 12:11:50.517 Cisco CallManager|StationInit: 3b0c928 KeypadButton kpButton=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.517 Cisco CallManager|Digit analysis: match(fqcn="4003", cn="4003", pss="API_Local:API_Long Distance:API_International", dd="71")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.517 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.564 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=6.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.564 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="916")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.564 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.564 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CB19E, TCPHandle=0xc2d649c, Socket=0x8d0, IPAddr=10.64.50.128, Port=52462, Device Controller=[1,92,435]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.128><:SEP0007EB7CB19E>
03/05/2002 12:11:50.564 Cisco CallManager|StationInit: c2d649c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.128><:SEP0007EB7CB19E>
03/05/2002 12:11:50.611 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC46F, TCPHandle=0x3b0db84, Socket=0xf84, IPAddr=10.64.50.127, Port=52327, Device Controller=[1,92,428]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.127><:SEP0007EB7CC46F>
03/05/2002 12:11:50.611 Cisco CallManager|StationInit: 3b0db84 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.127><:SEP0007EB7CC46F>
03/05/2002 12:11:50.627 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C684BE, TCPHandle=0x72943f8, Socket=0xc98, IPAddr=10.64.50.8, Port=53120, Device Controller=[1,92,342]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.8><:SEP000750C684BE>
03/05/2002 12:11:50.627 Cisco CallManager|StationInit: 72943f8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.8><:SEP000750C684BE>
03/05/2002 12:11:50.799 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644EFE, TCPHandle=0x3b0c734, Socket=0x1290, IPAddr=10.64.50.142, Port=51183, Device Controller=[1,92,526]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.142><:SEP0007EB644EFE>
03/05/2002 12:11:50.799 Cisco CallManager|StationInit: 3b0c734 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.142><:SEP0007EB644EFE>
03/05/2002 12:11:50.814 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.814 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:50.830 Cisco CallManager|StationInit: 3b0c928 KeypadButton kpButton=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.830 Cisco CallManager|Digit analysis: match(fqcn="4003", cn="4003", pss="API_Local:API_Long Distance:API_International", dd="710")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.830 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:50.892 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.892 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="9161")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.892 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:50.892 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750DD05FA, TCPHandle=0x725f1a4, Socket=0x1330, IPAddr=10.64.50.247, Port=50976, Device Controller=[1,92,515]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.247><:SEP000750DD05FA>
03/05/2002 12:11:50.892 Cisco CallManager|StationInit: 725f1a4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.247><:SEP000750DD05FA>
03/05/2002 12:11:51.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C67695, TCPHandle=0xc2d6564, Socket=0xdf0, IPAddr=10.64.50.214, Port=52817, Device Controller=[1,92,437]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.214><:SEP000750C67695>
03/05/2002 12:11:51.002 Cisco CallManager|StationInit: c2d6564 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.214><:SEP000750C67695>
03/05/2002 12:11:51.095 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB3F5D3A, TCPHandle=0xc2d7824, Socket=0xd60, IPAddr=10.64.50.129, Port=51438, Device Controller=[1,92,475]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.129><:SEP0007EB3F5D3A>
03/05/2002 12:11:51.095 Cisco CallManager|StationInit: c2d7824 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.129><:SEP0007EB3F5D3A>
03/05/2002 12:11:51.127 Cisco CallManager|StationInit: 3b0c928 KeypadButton kpButton=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Digit analysis: match(fqcn="4003", cn="4003", pss="API_Local:API_Long Distance:API_International", dd="7100")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Digit analysis: analysis results|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager||PretransformCallingPartyNumber=4003
|DialingPartition=
|DialingPattern=7100
|DialingRoutePatternRegularExpression=(7100)
|DialingWhere=
|PatternType=Enterprise
|PotentialMatches=NoPotentialMatchesExist
|DialingSdlProcessId=(1,37,473)
|PretransformDigitString=7100
|PretransformTagsList=SUBSCRIBER
|PretransformPositionalMatchList=7100
|CollectedDigits=7100
|UnconsumedDigits=
|TagsList=SUBSCRIBER
|VoiceMailbox=7100
|VoiceMailCallingSearchSpace=
|VoiceMailPilotNumber=4000
|DisplayName=
|RouteBlockFlag=RouteThisPattern
|InterceptPartition=
|InterceptPattern=7100
|InterceptWhere=
|InterceptSdlProcessId=(1,27,1)
|InterceptSsType=16777221
|InterceptSsKey=627|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 17 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Delete entries from TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|ForwardManager - wait_SsInterceptInd Received - Party= 0x1004877, InterceptKey= 0x273 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|ForwardManager - findCallBySsParty - mPartyToActiveCallIndexMap entry NOT found for party= 0x1004877 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|ForwardManager - findActivationEntryBySsParty - mPartyToActivationIndexMap - Entry NOT found for party= 0x1004877|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|ForwardManager - addActiveCallTableEntry - Added entry for InterceptKey= 0x273, Party= 0x1004877 CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|ForwardManager - wait_SsInterceptInd - New Forward or Call Pickup started for Dn= 7100. Party= 0x1004877, InterceptKey= 0x273, CallKey= 0xC73 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Forwarding - awaitForwardInitiation_SsInterceptInd - CFB Set. Extending Call CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Forwarding - Registered Rejection Intercept- PartyId= 0x1004877, CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Forwarding - ss - Extended Call to Party= 0x1004877, CallKey= 0xC73 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Insert an entry into TransTable, now this table has 9 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=1 reference=16795767 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7100><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|Locations_reserveBandwidth -- cdccPID=(1.15.9156) Orig=Dest=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.127 Cisco CallManager|StationD: 725eb64 StationOutputDisplayText don't need to send, because mIsALegacyDevice = 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|StationD: 725eb64 CallState callState=4 lineInstance=1 callReference=16795768|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='Voicemail' callingParty=4003 cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox=7100 originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=7100 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=0 callType=1(InBound) lineInstance=1 callReference=16795768. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795768, CallingPartyName=Voicemail, CallingParty=4003, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.127 Cisco CallManager|StationD: 725eb64 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=5(LampBlink).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 725eb64 SetRinger ringMode=2(InsideRing).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 725eb64 DisplayPromptStatus timeOutValue=0 promptStatus='€4003' content='From 003' lineInstance=1 callReference=16795768 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=1 reference=16795768 softKeySetIndex=3 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 18 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|Delete entries from TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|ForwardManager - wait_SsExtendCallRes - Received DestParty= 0x1004878, CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|ForwardManager - wait_SsExtendCallRes - mPartyToActiveCallIndexMap Added Entry for DestParty= 0x1004878, CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|Forwarding - awaitingCallResponse_SsExtendCallRes - DestParty= 0x1004878, CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004878, BCC= 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004878, CallKey= 0xC73 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004878, BCC= 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_ALERTING - CFNA timer set. CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4003:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=1 reference=16795744 softKeySetIndex=2 validKeyMask=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 CallState callState=12 lineInstance=1 callReference=16795767|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 CallInfo callingPartyName='Voicemail' callingParty=4003 cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox=7100 originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty= lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795767. version: 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795767, CallingPartyName=Voicemail, CallingParty=4003, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 DialedNumber dialedNumber=7100 lineInstance=1 callReference=16795767.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 CallInfo callingPartyName='Voicemail' callingParty=4003 cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox=7100 originalCalledPartyName='' originalCalledParty= originalCdpnVoiceMailbox= originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=7100 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795767. version: 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795767, CallingPartyName=Voicemail, CallingParty=4003, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 StartTone tone=36(AlertingTone), direction=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 CallState callState=3 lineInstance=1 callReference=16795767|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=1 reference=16795767 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.142 Cisco CallManager|StationD: 3b0c928 DisplayPromptStatus timeOutValue=0 promptStatus='Ring Out' content='Ring Out' lineInstance=1 callReference=16795767 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.283 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=9.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.283 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="91619")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.283 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.299 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16069 S0/DS1-0/3@SDA00908F003733 MGCP 0.1
X: 3
O: D/#
03/05/2002 12:11:51.299 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:51.299 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16069
RQNT 16600 S0/DS1-0/3@SDA00908F003733 MGCP 0.1
X: 3
R: D/[0-9ABCD*#]
Q: process,loop
200 16600
03/05/2002 12:11:51.299 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16600|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:51.299 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:51.299 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16600 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.299 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.299 Cisco CallManager|StationD: 3b0c66c KeypadButton KeyPadButton=15(Pound).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.345 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644CE2, TCPHandle=0x7295140, Socket=0x1304, IPAddr=10.64.50.179, Port=50018, Device Controller=[1,92,527]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.179><:SEP0007EB644CE2>
03/05/2002 12:11:51.345 Cisco CallManager|StationInit: 7295140 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.179><:SEP0007EB644CE2>
03/05/2002 12:11:51.424 Cisco CallManager|StationInit: 3b0c928 Stimulus stimulus=4(Transfer) stimulusInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.424 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:CISCOUM1-VI4>
03/05/2002 12:11:51.424 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::store() : RP=4003:, bRc=1, CallOrigin=7, T=restart0_StationStimTransfer(), #entries=1|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.424 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0004f20035f7, TCPHandle=0x3b0cdd8, Socket=0x12bc, IPAddr=10.64.51.4, Port=1292, Device Controller=[1,92,545]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.4><:SEP0004F20035F7>
03/05/2002 12:11:51.424 Cisco CallManager|StationInit: 3b0cdd8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.4><:SEP0004F20035F7>
03/05/2002 12:11:51.424 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 19 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.424 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 20 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.424 Cisco CallManager|TransferManager: SsInfoInd : complete transfer,TransferringSecondarSsParty=16795767, TransferringPartyDslAddr (0,0,352665610,2424), TransferringPartyPID (1,37,445),TransferDestinationSsParty=16795768, TransferDestinationDslAddr (0,0,-768458742,50282), TransferDesinatonPID (1,37,473).|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.424 Cisco CallManager|Delete entries from TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.424 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|Delete entries from TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795739,16795769): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 23|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - storeMediaInfo(16795769): EXISTING ENTRY DISCOVERED, tail == 23|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6613)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6613)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|MohDControl - stationOutputStopMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.439 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16601 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:51.439 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16601
03/05/2002 12:11:51.439 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16601|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:51.439 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16601 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795739) and party2(16795769)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6613) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795739,16795769): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaResourceManager::waiting_MrmDeallocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MRM::waiting_MrmDeallocateMohResourceReq- Deallocate received for MRM TransactionId= 16795769|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MRM::updateMohCounter MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MRM::updateMohCounter allocateCounter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(0,16795769): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - storeMediaInfo(0): NULL CI IGNORED, tail == 23|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - storeMediaInfo(16795769): EXISTING ENTRY DISCOVERED, tail == 23|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|Locations_releaseBandwidthForMediaResource -- cdccPID=(1.15.9149) no entry For MediaResource|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.439 Cisco CallManager|Delete entries from TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - no parties found|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest, extending disconnect to partyA interface instance(6062)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|MohDControl - stationOutputStopMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(0,16795769): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - ERROR deleteMediaInfoEntry(0): ENTRY NOT FOUND, tail == 23|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795769): ENTRY DELETED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.439 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|Delete entries from TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795744,0): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|ConnectionManager - storeMediaInfo(16795744): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|ConnectionManager - storeMediaInfo(0): NULL CI IGNORED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - no parties found|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest, extending disconnect to partyA interface instance(6057)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795744,0): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795744): ENTRY DELETED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|ConnectionManager - ERROR deleteMediaInfoEntry(0): ENTRY NOT FOUND, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|Insert an entry into TransTable, now this table has 9 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|StationD: 3b0c928 SetLamp stimulus=4(Transfer) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|StationInit: 3b0c928 OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.455 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795767,0): NO ENTRY FOUND IN TABLE|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|Delete entries from CiCcp table, now this table has 26 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|Delete entries from TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.455 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x100485B, CallKey= 0xC70 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004878, CallKey= 0xC73 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - removeActiveCallTableEntry mPartyToActiveCallIndexMap - Removed entry OrigParty= 0x100485B, CallKey= 0xC70 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - removeActiveCallTableEntry mPartyToActiveCallIndexMap - Removed entry DestParty= 0x1004860, CallKey= 0xC70 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - removeActiveCallTableEntry - Removed entry from CallTable and Mapping tables for OrigParty= 0x100485B, DestParty= 0x1004860, CallKey= 0xC70 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - wait_SsJoinInd mPartyToActiveCallIndexMap - Add Entries for. Party1= 0x100485B and Party2= 0x1004878, CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - getCallPickupEntry - No Entry Found for group= |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9158) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.470 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7100><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Forwarding - awaitingCallResponse_ForwardStopInd - Stopping. CallKey= 0xC70|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Forwarding - Unregistered Rejection Intercept- PartyId= 0x100485B, CallKey= 0xC70|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Forwarding - Unregistered Rejection Intercept- PartyId= 0x1004877, CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Forwarding - awaitingCallResponse_SsJoinInd Joined PartyA 0x100485B and PartyB 0x1004878, CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4003><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::remove() : RP=4003:; bRc=1, T=restart0_LmKeyReleaseReq(), #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.470 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4003:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.470 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Delete entries from TransTable, now this table has 5 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 19 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 18 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Delete entries from CiCcp table, now this table has 25 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|StationD: 3b0c928 ClearPromptStatus lineInstance=1 callReference=16795744.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|StationD: 3b0c928 CallState callState=2 lineInstance=1 callReference=16795744|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|StationInit: 3b0c928 OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.470 Cisco CallManager|StationD: 3b0c928 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=2(LampOn).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='' callingParty= cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=7100 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=0 callType=1(InBound) lineInstance=1 callReference=16795768. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795768, CallingPartyName=, CallingParty=, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=7100|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004860, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - findCallBySsParty - mPartyToActiveCallIndexMap entry NOT found for party= 0x1004860 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|ForwardManager - findInterceptBySsParty - Found entry for party= 1004860, SsKey= 12B |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9157) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.470 Cisco CallManager|StationD - CTI Reason Code: CtiReasonTransferredCall|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
RQNT 16602 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
X: 4
S: G/rt
03/05/2002 12:11:51.470 Cisco CallManager|StationD: 3b0c928 SetSpeakerMode speakermode=2(Off).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|StationD: 3b0c928 ClearPromptStatus lineInstance=1 callReference=16795767.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16602
03/05/2002 12:11:51.470 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16602|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:51.470 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16602 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.470 Cisco CallManager|StationD: 3b0c928 CallState callState=2 lineInstance=1 callReference=16795767|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 DisplayPromptStatus timeOutValue=0 promptStatus='Your current options' content='Your current options' lineInstance=0 callReference=0 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 ActivateCallPlane lineInstance=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 DefineTimeDate timeDateInfo=? systemTime=1015359111.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='' callingParty= cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=4003 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=3 callType=1(InBound) lineInstance=1 callReference=16795768. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795768, CallingPartyName=, CallingParty=, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=4003|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 17 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 16 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|Delete entries from TransTable, now this table has 5 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|Delete entries from CiCcp table, now this table has 24 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004877, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004877, CallKey= 0xC73 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|ForwardManager - findInterceptBySsParty - mSsToInterceptIndexMap entry NOT found for party= 1004877 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9156) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.486 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004877, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:51.486 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4003:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 DefineTimeDate timeDateInfo=? systemTime=1015359111.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.486 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.580 Cisco CallManager|MGCPHandler received msg from: 10.64.15.128
NTFY 227949 *@API-VG200LOAN-1-TCD MGCP 0.1
X: 0
O:
|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.128><:>
03/05/2002 12:11:51.580 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:><:>
03/05/2002 12:11:51.580 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.15.128
200 227949
03/05/2002 12:11:51.595 Cisco CallManager|MGCPManager remove recent Incoming transId 227947|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.128><:>
03/05/2002 12:11:51.611 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=8.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.611 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="916198")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.611 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=VGC0653d6b3d702, TCPHandle=0xc2d63d4, Socket=0xdd4, IPAddr=10.64.15.130, Port=20978, Device Controller=[1,92,278]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D702>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit: c2d63d4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D702>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=VGC0653d6b3d701, TCPHandle=0xc2d6438, Socket=0x1208, IPAddr=10.64.15.130, Port=20979, Device Controller=[1,92,277]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D701>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit: c2d6438 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D701>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=VGC0653d6b3d726, TCPHandle=0x729490c, Socket=0x1230, IPAddr=10.64.15.130, Port=20982, Device Controller=[1,92,287]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D726>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit: 729490c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D726>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=VGC0653d6b3d727, TCPHandle=0x7294970, Socket=0xaac, IPAddr=10.64.15.130, Port=20983, Device Controller=[1,92,288]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D727>
03/05/2002 12:11:51.627 Cisco CallManager|StationInit: 7294970 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D727>
03/05/2002 12:11:51.642 Cisco CallManager|StationInit: 3b0c928 OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.642 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4003:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.642 Cisco CallManager|StationD: 3b0c928 DefineTimeDate timeDateInfo=? systemTime=1015359111.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.642 Cisco CallManager|StationD: 3b0c928 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.642 Cisco CallManager|StationD: 3b0c928 SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:11:51.658 Cisco CallManager|MGCPHandler received msg from: 10.64.15.129
NTFY 285880 *@API-VG200LOAN-2-ED MGCP 0.1
X: 0
O:
|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.129><:>
03/05/2002 12:11:51.658 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:><:>
03/05/2002 12:11:51.658 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.15.129
200 285880
03/05/2002 12:11:51.674 Cisco CallManager|MGCPManager remove recent Incoming transId 285878|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.129><:>
03/05/2002 12:11:51.830 Cisco CallManager|StationInit: 7294e84 OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=7018:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 SetSpeakerMode speakermode=2(Off).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 ClearPromptStatus lineInstance=1 callReference=16795760.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 CallState callState=2 lineInstance=1 callReference=16795760|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Your current options' lineInstance=0 callReference=0 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 ActivateCallPlane lineInstance=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 DefineTimeDate timeDateInfo=? systemTime=1015359111.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7018><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 3b0cdd8 ClearPromptStatus lineInstance=1 callReference=16795760.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 3b0cdd8 CallState callState=2 lineInstance=1 callReference=16795760|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 3b0cdd8 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 3b0cdd8 DisplayPromptStatus timeOutValue=0 promptStatus='Your current options' content='Your current options' lineInstance=0 callReference=0 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004870, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004870, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|ForwardManager - findInterceptBySsParty - mSsToInterceptIndexMap entry NOT found for party= 1004870 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795760,16795764): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|ConnectionManager - storeMediaInfo(16795760): EXISTING ENTRY DISCOVERED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|ConnectionManager - storeMediaInfo(16795764): EXISTING ENTRY DISCOVERED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004870, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_RELEASE - Origination Release. Party= 0x1004870, CallKey= 0xC72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6612)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - StopSession sending disconnect to (74,6612) and remove connection from list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 CloseReceiveChannel conferenceID=0 passThruPartyID=96977. myIP: 9232400a (10.64.50.146)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.830 Cisco CallManager|StationD: 7294e84 StopMediaTransmission conferenceID=0 passThruPartyID=96977. myIP: 9232400a (10.64.50.146)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.146><:SEP0007EB39B6C5>
03/05/2002 12:11:51.908 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=4.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.908 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="9161984")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.908 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:51.955 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795760) and party2(16795764)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6612) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795760,16795764): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795760): ENTRY DELETED, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795764): ENTRY DELETED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.955 Cisco CallManager|Out Message -- H225ReleaseCompleteMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.955 Cisco CallManager|Ie - Q931CauseIe IEData= 08 02 80 90 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.955 Cisco CallManager|Ie - H225UserUserIe IEData= 7E 00 21 05 25 80 06 00 08 91 4A 00 02 01 11 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 06 80 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.955 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.955 Cisco CallManager|IsdnMsgData2= 08 02 06 59 5A 08 02 80 90 7E 00 21 05 25 80 06 00 08 91 4A 00 02 01 11 00 00 76 66 38 78 4E 71 1D 59 06 03 CC 0A 40 32 92 06 80 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.955 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 15 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 14 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|Delete entries from TransTable, now this table has 5 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|Delete entries from CiCcp table, now this table has 22 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004874, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004874, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|ForwardManager - wait_SsDataInd mPartyToActiveCallIndexMap - Removed entry DestParty= 0x1004874, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.955 Cisco CallManager|ForwardManager - findInterceptBySsParty - mSsToInterceptIndexMap entry NOT found for party= 1004874 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.970 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9153) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:51.970 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004874, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.970 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_RELEASE - Stopping Forwarding on destination Release. Party= 0x1004874, CallKey= 0xC72|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.970 Cisco CallManager|ForwardManager - removeActiveCallTableEntry mPartyToActiveCallIndexMap - Removed entry OrigParty= 0x1004870, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:51.970 Cisco CallManager|ForwardManager - removeActiveCallTableEntry - Removed entry from CallTable and Mapping tables for OrigParty= 0x1004870, DestParty= 0x0, CallKey= 0xC72 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30679="">
03/05/2002 12:11:52.127 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785469D2E, TCPHandle=0xc2d73d8, Socket=0xfec, IPAddr=10.64.50.204, Port=49955, Device Controller=[1,92,467]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.204><:SEP000785469D2E>
03/05/2002 12:11:52.127 Cisco CallManager|StationInit: c2d73d8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.204><:SEP000785469D2E>
03/05/2002 12:11:52.236 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785057127, TCPHandle=0xc2d6cd0, Socket=0x8a0, IPAddr=10.64.50.105, Port=53159, Device Controller=[1,92,455]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.105><:SEP000785057127>
03/05/2002 12:11:52.236 Cisco CallManager|StationInit: c2d6cd0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.105><:SEP000785057127>
03/05/2002 12:11:52.283 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.283 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="91619843")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.283 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.299 Cisco CallManager|StationInit: 3b0cb1c Stimulus stimulus=4(Transfer) stimulusInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::store() : RP=4005:, bRc=1, CallOrigin=7, T=restart0_StationStimTransfer(), #entries=1|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.299 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 15 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 16 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|TransferManager: SsInfoInd : init transfer,XFERringPriSsPty=16795757, XFERringPtyDslAddr (0,0,352665610,2426), XFERringPtyPID (1,37,443),XFERredSsPty=16795735, XFERredPtyDslAddr (0,0,20070410,2427), XFERredPtyPID (1,61,1).|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.299 Cisco CallManager|Insert an entry into TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|Delete entries from TransTable, now this table has 5 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|StationD: 3b0cb1c SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=3(LampWink).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|StationD: 3b0cb1c CallState callState=8 lineInstance=1 callReference=16795757|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=1 reference=16795757 softKeySetIndex=2 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|StationD: 3b0cb1c DisplayPromptStatus timeOutValue=0 promptStatus='Hold' content='Hold' lineInstance=1 callReference=16795757 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795735,16795757): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|ConnectionManager - storeMediaInfo(16795735): EXISTING ENTRY DISCOVERED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|ConnectionManager - storeMediaInfo(16795757): EXISTING ENTRY DISCOVERED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6610)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.299 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6610)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c CloseReceiveChannel conferenceID=0 passThruPartyID=96961. myIP: 1505400a (10.64.5.21)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c StopMediaTransmission conferenceID=0 passThruPartyID=96961. myIP: 1505400a (10.64.5.21)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16603 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
C: D00000000100485700000000800012c8
I: 1
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=4(LampFlash).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c StationOutputDisplayText don't need to send, because mIsALegacyDevice = 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16603
03/05/2002 12:11:52.314 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16603|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:52.314 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16603 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|CTI: RoutePatternToCtiGlobalCallID::findValue(): RP=4005:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.314 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::findValue() : RP=4005:, bRc=1, CallOrigin=7, T=, #entries=1|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.314 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::remove() : RP=4005:; bRc=1, T=await_ci_res_CcCiRes(), #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.314 Cisco CallManager|StationD - StationOutputSetLamp ignored|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c CallState callState=1 lineInstance=1 callReference=16795770|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c DisplayPromptStatus timeOutValue=0 promptStatus='Enter Number' content='Enter Number' lineInstance=1 callReference=16795770 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=1 reference=16795770 softKeySetIndex=4 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|StationD: 3b0cb1c ActivateCallPlane lineInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795735) and party2(16795757)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|Insert an entry into CiCcp table, now this table has 23 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|Insert an entry into CiCcp table, now this table has 24 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
NTFY 16070 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/6
03/05/2002 12:11:52.314 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:52.314 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6610) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795735,16795757): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
200 16070
03/05/2002 12:11:52.314 Cisco CallManager|Digit analysis: match(fqcn="4005", cn="4005", pss="API_Local:API_Long Distance:API_International", dd="")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.314 Cisco CallManager|Delete entries from TransTable, now this table has 5 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
RQNT 16604 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:52.314 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq - MRGL=0,CREATED CHILD USING DEFAULT LIST|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:52.314 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-1 Group=0 Counter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:52.314 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-2 Group=0 Counter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
200 16604
03/05/2002 12:11:52.314 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16604|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:52.314 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16604 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.314 Cisco CallManager|MediaResourceCdpc - Started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceCdpc::findDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq MtpDevice=MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|Insert an entry into TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes MohResource=MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|Locations_reserveBandwidthForMediaResource -- cdccPID=(1.15.9147) UserParty=Media Source=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.330 Cisco CallManager|MohDControl - AllocateMohResourceReq successfully - AudioSourceID and MuticastFlag = 1, 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|StationD: 3b0cb1c StartTone tone=33(InsideDialTone), direction=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceCdpc::resource_rsvp_AllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=6(Six).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MRM::updateMohCounter MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MRM::updateMohCounter allocateCounter=1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceManager::waiting_MrmChildStopInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaResourceCdpc::shutting_down_MrmChildStopConf|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795735,16795772): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|ConnectionManager - storeMediaInfo(16795735): EXISTING ENTRY DISCOVERED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|ConnectionManager - storeMediaInfo(16795772): ADD NEW ENTRY, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6614) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaManager(6614) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:52.330 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795735) and party2(16795772)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795735,16795772)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16605 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
I: 1
X: 1
L: p:20, a:PCMU, s:off
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:52.330 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16605
03/05/2002 12:11:52.330 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16605|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:52.330 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16605 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.330 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.346 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A4D8, TCPHandle=0x7295334, Socket=0x9a0, IPAddr=10.64.50.13, Port=50765, Device Controller=[1,92,365]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.13><:SEP00078546A4D8>
03/05/2002 12:11:52.346 Cisco CallManager|StationInit: 7295334 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.13><:SEP00078546A4D8>
03/05/2002 12:11:52.346 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.346 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16606 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
I: 1
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
v=0
o=- 1 0 IN EPN S0/DS1-0/1@SDA00908F003733
s=Cisco SDP 0
t=0 0
c=IN IP4 0.0.0.0
m=audio 0 RTP/AVP 96
a=rtpmap:96 PCMU
03/05/2002 12:11:52.346 Cisco CallManager|MohDControl - stationOutputStartMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.346 Cisco CallManager|MohDControl - RemoteIpAddr: 132400a (10.64.50.1) RemoteRtpPortNumber: 24222 msecPacketSize: 20 compressionType: 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.346 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16606
03/05/2002 12:11:52.346 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16606|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:52.346 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:52.346 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16606 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.346 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:S0>
03/05/2002 12:11:52.346 Cisco CallManager|StationD: 3b0cb1c SetLamp stimulus=4(Transfer) stimulusInstance=1 lampMode=4(LampFlash).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.455 Cisco CallManager|StationInit: 3b0cb1c KeypadButton kpButton=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.455 Cisco CallManager|StationD: 3b0cb1c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.455 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=1 reference=16795770 softKeySetIndex=6 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.455 Cisco CallManager|Digit analysis: match(fqcn="4005", cn="4005", pss="API_Local:API_Long Distance:API_International", dd="7")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.455 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.549 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00062825DFA4, TCPHandle=0x725f26c, Socket=0x1318, IPAddr=192.168.64.201, Port=51349, Device Controller=[1,92,535]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:192.168.64.201><:SEP00062825DFA4>
03/05/2002 12:11:52.549 Cisco CallManager|StationInit: 725f26c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:192.168.64.201><:SEP00062825DFA4>
03/05/2002 12:11:52.596 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CB145, TCPHandle=0xc2d6820, Socket=0x1174, IPAddr=10.64.50.131, Port=52618, Device Controller=[1,92,443]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.131><:SEP0007EB7CB145>
03/05/2002 12:11:52.596 Cisco CallManager|StationInit: c2d6820 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.131><:SEP0007EB7CB145>
03/05/2002 12:11:52.627 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=2.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.627 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="916198432")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.627 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.642 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC460, TCPHandle=0x7294b00, Socket=0xe54, IPAddr=10.64.50.245, Port=52036, Device Controller=[1,92,346]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.245><:SEP0007EB7CC460>
03/05/2002 12:11:52.642 Cisco CallManager|StationInit: 7294b00 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.245><:SEP0007EB7CC460>
03/05/2002 12:11:52.721 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B7A3, TCPHandle=0xc2d6a14, Socket=0x1030, IPAddr=10.64.50.50, Port=52912, Device Controller=[1,92,448]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.50><:SEP0007EB39B7A3>
03/05/2002 12:11:52.721 Cisco CallManager|StationInit: c2d6a14 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.50><:SEP0007EB39B7A3>
03/05/2002 12:11:52.767 Cisco CallManager|StationInit: 3b0cb1c KeypadButton kpButton=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.767 Cisco CallManager|Digit analysis: match(fqcn="4005", cn="4005", pss="API_Local:API_Long Distance:API_International", dd="71")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.767 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:52.767 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16071 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/2
03/05/2002 12:11:52.767 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:52.767 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16071
RQNT 16607 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
200 16607
03/05/2002 12:11:52.767 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16607|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:52.767 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:52.767 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16607 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.767 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.767 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=2(Two).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.814 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.814 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:52.830 Cisco CallManager|StationInit: c2d775c KeypadButton kpButton=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.199><:SEP000750DD07A4>
03/05/2002 12:11:52.830 Cisco CallManager|StationD: 725ef4c KeypadButton KeyPadButton=1(One).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.199><:SEP000750DD07A4>
03/05/2002 12:11:52.892 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16072 S0/DS1-0/3@SDA00908F003733 MGCP 0.1
X: 3
O: D/#
03/05/2002 12:11:52.892 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:52.892 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16072
RQNT 16608 S0/DS1-0/3@SDA00908F003733 MGCP 0.1
X: 3
R: D/[0-9ABCD*#]
Q: process,loop
200 16608
03/05/2002 12:11:52.892 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16608|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:52.892 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:52.892 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16608 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.892 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.892 Cisco CallManager|StationD: 3b0c66c KeypadButton KeyPadButton=15(Pound).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:52.939 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=9.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.955 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="9161984329")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.955 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:52.971 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CB150, TCPHandle=0x729571c, Socket=0x12b4, IPAddr=192.168.64.202, Port=51833, Device Controller=[1,92,536]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:192.168.64.202><:SEP0007EB7CB150>
03/05/2002 12:11:52.971 Cisco CallManager|StationInit: 729571c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:192.168.64.202><:SEP0007EB7CB150>
03/05/2002 12:11:53.064 Cisco CallManager|StationInit: 3b0cb1c KeypadButton kpButton=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.064 Cisco CallManager|Digit analysis: match(fqcn="4005", cn="4005", pss="API_Local:API_Long Distance:API_International", dd="710")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.064 Cisco CallManager|Digit analysis: potentialMatches=PotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.142 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750DCFE59, TCPHandle=0x7294f4c, Socket=0x10ac, IPAddr=10.64.50.124, Port=50555, Device Controller=[1,92,355]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.124><:SEP000750DCFE59>
03/05/2002 12:11:53.142 Cisco CallManager|StationInit: 7294f4c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.124><:SEP000750DCFE59>
03/05/2002 12:11:53.189 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00075079C005, TCPHandle=0x927d0d4, Socket=0x800, IPAddr=10.64.50.30, Port=50582, Device Controller=[1,92,140]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.30><:SEP00075079C005>
03/05/2002 12:11:53.189 Cisco CallManager|StationInit: 927d0d4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.30><:SEP00075079C005>
03/05/2002 12:11:53.221 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785056F79, TCPHandle=0xc2d6a78, Socket=0xd14, IPAddr=10.64.50.219, Port=53083, Device Controller=[1,92,449]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.219><:SEP000785056F79>
03/05/2002 12:11:53.221 Cisco CallManager|StationInit: c2d6a78 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.219><:SEP000785056F79>
03/05/2002 12:11:53.221 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC408, TCPHandle=0xc2d66f4, Socket=0x968, IPAddr=10.64.50.232, Port=52646, Device Controller=[1,92,441]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.232><:SEP0007EB7CC408>
03/05/2002 12:11:53.221 Cisco CallManager|StationInit: c2d66f4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.232><:SEP0007EB7CC408>
03/05/2002 12:11:53.283 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=8.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.283 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="91619843298")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.283 Cisco CallManager|Digit analysis: potentialMatches=ExclusivelyOffnetPotentialMatchesExist|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.314 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CB137, TCPHandle=0xc2d6884, Socket=0xb68, IPAddr=10.64.50.130, Port=52452, Device Controller=[1,92,444]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.130><:SEP0007EB7CB137>
03/05/2002 12:11:53.314 Cisco CallManager|StationInit: c2d6884 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.130><:SEP0007EB7CB137>
03/05/2002 12:11:53.361 Cisco CallManager|StationInit: 3b0cb1c KeypadButton kpButton=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Digit analysis: match(fqcn="4005", cn="4005", pss="API_Local:API_Long Distance:API_International", dd="7100")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Digit analysis: analysis results|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager||PretransformCallingPartyNumber=4005
|DialingPartition=
|DialingPattern=7100
|DialingRoutePatternRegularExpression=(7100)
|DialingWhere=
|PatternType=Enterprise
|PotentialMatches=NoPotentialMatchesExist
|DialingSdlProcessId=(1,37,473)
|PretransformDigitString=7100
|PretransformTagsList=SUBSCRIBER
|PretransformPositionalMatchList=7100
|CollectedDigits=7100
|UnconsumedDigits=
|TagsList=SUBSCRIBER
|VoiceMailbox=7100
|VoiceMailCallingSearchSpace=
|VoiceMailPilotNumber=4000
|DisplayName=
|RouteBlockFlag=RouteThisPattern
|InterceptPartition=
|InterceptPattern=7100
|InterceptWhere=
|InterceptSdlProcessId=(1,27,1)
|InterceptSsType=16777221
|InterceptSsKey=627|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 17 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|ForwardManager - wait_SsInterceptInd Received - Party= 0x100487A, InterceptKey= 0x273 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|ForwardManager - findCallBySsParty - mPartyToActiveCallIndexMap entry NOT found for party= 0x100487A |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|ForwardManager - findActivationEntryBySsParty - mPartyToActivationIndexMap - Entry NOT found for party= 0x100487A|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|ForwardManager - addActiveCallTableEntry - Added entry for InterceptKey= 0x273, Party= 0x100487A CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|ForwardManager - wait_SsInterceptInd - New Forward or Call Pickup started for Dn= 7100. Party= 0x100487A, InterceptKey= 0x273, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Forwarding - awaitForwardInitiation_SsInterceptInd - CFB Set. Extending Call CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Forwarding - Registered Rejection Intercept- PartyId= 0x100487A, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Forwarding - ss - Extended Call to Party= 0x100487A, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.361 Cisco CallManager|MGCPManager remove recent Incoming transId 16062|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:53.361 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=1 reference=16795770 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Delete entries from TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|ForwardManager - wait_SsExtendCallRes - Received DestParty= 0x0, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x100487A, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - awaitingCallResponse_SsExtendCallRes - DestParty= 0x0, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - awaitingCallResponse_SsRejectionInterceptInd - CFB processing. Party= 0x100487A, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - findInterceptTableEntry - Found Intercept table entry for dn= 4050, InterceptKey= 0x4 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - awaitingCallResponse_SsRejectionInterceptInd - CFB processing - Current Dn= 4050, redirect to this Dn dest, Party= 0x100487A, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - matchNextCallForwardDestination - Destination Matched - Dn= 4050, CSS= |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - formatRedirectCallReq - Using Orig Party CallKey= C74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - sendRedirectCallReq ForwardActiveCallEntry - Redirected Party= 0x100487A Node= 1, to Dn= 4050 CSS= , CallKey= C74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=1 reference=16795757 softKeySetIndex=2 validKeyMask=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Insert an entry into CiCcp table, now this table has 25 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 3b0cb1c CallState callState=12 lineInstance=1 callReference=16795770|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 3b0cb1c CallInfo callingPartyName='Voicemail' callingParty=4005 cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox=7100 originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty= lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795770. version: 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795770, CallingPartyName=Voicemail, CallingParty=4005, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 3b0cb1c DialedNumber dialedNumber=7100 lineInstance=1 callReference=16795770.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Delete entries from CiCcp table, now this table has 24 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Digit analysis: match(fqcn="4005", cn="4005", pss="API_Local:API_Long Distance:API_International", dd="4050")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Digit analysis: analysis results|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager||PretransformCallingPartyNumber=4005
|DialingPartition=
|DialingPattern=4050
|DialingRoutePatternRegularExpression=(4050)
|DialingWhere=
|DialingSdlProcessId=(1,37,468)
|PretransformDigitString=4050
|PretransformPositionalMatchList=4050
|CollectedDigits=4050
|UnconsumedDigits=
|TagsList=SUBSCRIBER
|VoiceMailbox=4050
|DisplayName=
|InterceptPartition=
|InterceptPattern=4050
|InterceptWhere=
|InterceptSsKey=4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|ForwardManager - wait_SsRedirectCallRes - Received DestParty= 0x0, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|ForwardManager - wait_SsInterceptInd Received - Party= 0x100487A, InterceptKey= 0x4 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|ForwardManager - wait_SsInterceptInd - Sending Intercept to child process. Party= 0x100487A, InterceptKey= 0x4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - awaitingCallResponse_SsRedirectCallRes - DestParty= 0x0, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - sendSsNotifyReq - to Party= 0x0, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - awaitingCallResponse_SsInterceptInd - Forwarded call Extended, or Call Pickup Call Extended. Party= 0x100487A, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - ss - Extended Call to Party= 0x100487A, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4050><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Locations_reserveBandwidth -- cdccPID=(1.15.9159) Orig=Dest=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 725eb64 StationOutputDisplayText don't need to send, because mIsALegacyDevice = 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 725eb64 CallState callState=4 lineInstance=2 callReference=16795773|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='Voicemail' callingParty=4005 cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox=7100 originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=1 lastRedirectingPartyName='' lastRedirectingParty=7100 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=1 callType=3(Forward) lineInstance=2 callReference=16795773. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795773, CallingPartyName=Voicemail, CallingParty=4005, CalledPartyName=, CalledParty=4050, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=7100|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 725eb64 SetLamp stimulus=9(Line) stimulusInstance=2 lampMode=5(LampBlink).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 725eb64 DisplayPromptStatus timeOutValue=0 promptStatus='€4005' content='From 005' lineInstance=2 callReference=16795773 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=2 reference=16795773 softKeySetIndex=3 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 18 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|ForwardManager - wait_SsExtendCallRes - Received DestParty= 0x100487D, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|ForwardManager - wait_SsExtendCallRes - mPartyToActiveCallIndexMap Added Entry for DestParty= 0x100487D, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.377 Cisco CallManager|Forwarding - awaitingCallResponse_SsExtendCallRes - DestParty= 0x100487D, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x100487D, BCC= 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x100487D, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x100487D, BCC= 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_ALERTING - CFNA timer set. CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4005:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.392 Cisco CallManager|StationD: 3b0cb1c CallInfo callingPartyName='Voicemail' callingParty=4005 cgpnVoiceMailbox= calledPartyName='' calledParty=4050 cdpnVoiceMailbox=4050 originalCalledPartyName='' originalCalledParty= originalCdpnVoiceMailbox= originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=7100 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795770. version: 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795770, CallingPartyName=Voicemail, CallingParty=4005, CalledPartyName=, CalledParty=4050, OriginalCalledPartyName=, OriginalCalledParty=, lastRedirectingPartyName=, lastRedirectingParty=7100|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|StationD: 3b0cb1c StartTone tone=36(AlertingTone), direction=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|StationD: 3b0cb1c CallState callState=3 lineInstance=1 callReference=16795770|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=1 reference=16795770 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.392 Cisco CallManager|StationD: 3b0cb1c DisplayPromptStatus timeOutValue=0 promptStatus='Ring Out' content='Ring Out' lineInstance=1 callReference=16795770 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.564 Cisco CallManager|StationInit: c2d6f28 KeypadButton kpButton=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|Digit analysis: match(fqcn="7302", cn="7302", pss="API_Local:API_Long Distance:API_International", dd="916198432987")|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|Digit analysis: analysis results|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager||PretransformCallingPartyNumber=7302
|DialingPartition=API_Long Distance
|DialingPattern=9.@
|DialingRoutePatternRegularExpression=(9)(1)([2-9]X[02-9])([2-9]XX)(XXXX)
|DialingWhere=(AREA-CODE EXISTS AND LONG-DISTANCE-DIRECT-DIAL EXISTS)
|PatternType=National
|DialingSdlProcessId=(1,87,3)
|PretransformDigitString=916198432987
|PretransformTagsList=ACCESS-CODE:LONG-DISTANCE-DIRECT-DIAL:AREA-CODE:OFFICE-CODE:SUBSCRIBER
|PretransformPositionalMatchList=9:1:619:843:2987
|CollectedDigits=16198432987
|UnconsumedDigits=
|TagsList=LONG-DISTANCE-DIRECT-DIAL:AREA-CODE:OFFICE-CODE:SUBSCRIBER
|PositionalMatchList=1:619:843:2987
|VoiceMailbox=
|DisplayName=
|InterceptPartition=
|InterceptPattern=
|InterceptWhere=
|InterceptSdlProcessId=(0,0,0)
|InterceptSsType=0
|InterceptSsKey=0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|RouteListCdrc - RouteListName = PRI-List; Processing route number 1; Trying to locate DeviceName = 10.64.15.111.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7302><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|RouteListCdrc; Device 10.64.15.111 located.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|RouteListCdrc (1,86,1626) extending call to Device (1,30,1)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|StationD: c2d6f28 SelectSoftKeys instance=1 reference=16795762 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:53.564 Cisco CallManager|Locations_reserveBandwidth -- cdccPID=(1.15.9154) Orig=Dest=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|StationInit: 3b0cb1c Stimulus stimulus=4(Transfer) stimulusInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|H225Cdpc::TcpStartSessionRes: from H225Handler=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:53.721 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Out Message -- H225SetupMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Ie - H225BearerCapabilityIe IEData= 04 03 80 90 A2 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Ie - Q931DisplayIe IEData= 28 0D 54 72 61 63 79 20 51 75 69 6E 74 65 6E |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Ie - H225CallingPartyIe IEData= 6C 0C 20 81 38 35 38 35 35 32 32 32 30 30 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Ie - Q931CalledPartyIe IEData= 70 0C A1 31 36 31 39 38 34 33 32 39 38 37 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Ie - H225UserUserIe IEData= 7E 00 6E 05 20 B0 06 00 08 91 4A 00 02 01 40 0C 00 54 00 72 00 61 00 63 00 79 00 20 00 51 00 75 00 69 00 6E 00 74 00 65 00 6E 02 00 01 05 00 49 4C B7 65 CB A0 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 00 49 0C 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 01 00 01 00 06 A0 01 00 0E 01 40 B5 00 00 12 07 80 44 04 00 01 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|IsdnMsgData2= 08 02 06 5A 05 04 03 80 90 A2 28 0D 54 72 61 63 79 20 51 75 69 6E 74 65 6E 6C 0C 20 81 38 35 38 35 35 32 32 32 30 30 70 0C A1 31 36 31 39 38 34 33 32 39 38 37 7E 00 6E 05 20 B0 06 00 08 91 4A 00 02 01 40 0C 00 54 00 72 00 61 00 63 00 79 00 20 00 51 00 75 00 69 00 6E 00 74 00 65 00 6E 02 00 01 05 00 49 4C B7 65 CB A0 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 00 49 0C 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 01 00 01 00 06 A0 01 00 0E 01 40 B5 00 00 12 07 80 44 04 00 01 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::store() : RP=4005:, bRc=1, CallOrigin=7, T=restart0_StationStimTransfer(), #entries=1|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 19 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|Insert an entry into MonitorPartyTable, now this table has 20 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|TransferManager: SsInfoInd : complete transfer,TransferringSecondarSsParty=16795770, TransferringPartyDslAddr (0,0,352665610,2426), TransferringPartyPID (1,37,443),TransferDestinationSsParty=16795773, TransferDestinationDslAddr (0,0,-768458742,50282), TransferDesinatonPID (1,37,468).|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.721 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795735,16795772): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|ConnectionManager - storeMediaInfo(16795735): EXISTING ENTRY DISCOVERED, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|ConnectionManager - storeMediaInfo(16795772): EXISTING ENTRY DISCOVERED, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6614)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6614)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|MohDControl - stationOutputStopMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.721 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16609 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
I: 1
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:53.721 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16609
03/05/2002 12:11:53.721 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16609|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:53.721 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:53.721 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16609 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.721 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.721 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795735) and party2(16795772)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.721 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6614) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795735,16795772): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MediaResourceManager::waiting_MrmDeallocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MRM::waiting_MrmDeallocateMohResourceReq- Deallocate received for MRM TransactionId= 16795772|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MRM::updateMohCounter MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MRM::updateMohCounter allocateCounter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(0,16795772): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - storeMediaInfo(0): NULL CI IGNORED, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - storeMediaInfo(16795772): EXISTING ENTRY DISCOVERED, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|Locations_releaseBandwidthForMediaResource -- cdccPID=(1.15.9147) no entry For MediaResource|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.736 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - no parties found|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest, extending disconnect to partyA interface instance(6063)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MohDControl - stationOutputStopMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(0,16795772): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - ERROR deleteMediaInfoEntry(0): ENTRY NOT FOUND, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795772): ENTRY DELETED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|Insert an entry into TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795757,0): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - storeMediaInfo(16795757): EXISTING ENTRY DISCOVERED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - storeMediaInfo(0): NULL CI IGNORED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest, extending disconnect to partyA interface instance(6060)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795757,0): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795757): ENTRY DELETED, tail == 18|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|ConnectionManager - ERROR deleteMediaInfoEntry(0): ENTRY NOT FOUND, tail == 18|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|Insert an entry into TransTable, now this table has 8 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|StationD: 3b0cb1c SetLamp stimulus=4(Transfer) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.736 Cisco CallManager|StationInit: 3b0cb1c OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.752 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|In Message -- H225CallProceedingMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|Ie - H225UserUserIe -- IEData= 7E 00 2A 05 21 C0 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D8 09 00 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 06 80 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|IsdnMsgData1= 08 02 86 5A 02 7E 00 2A 05 21 C0 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D8 09 00 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 06 80 01 00 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795770,0): NO ENTRY FOUND IN TABLE|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from CiCcp table, now this table has 24 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from TransTable, now this table has 7 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from TransTable, now this table has 6 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004857, CallKey= 0xC6F |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x100487D, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|ForwardManager - removeActiveCallTableEntry mPartyToActiveCallIndexMap - Removed entry OrigParty= 0x1004857, CallKey= 0xC6F |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|ForwardManager - removeActiveCallTableEntry mPartyToActiveCallIndexMap - Removed entry DestParty= 0x100486D, CallKey= 0xC6F |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|ForwardManager - removeActiveCallTableEntry - Removed entry from CallTable and Mapping tables for OrigParty= 0x1004857, DestParty= 0x100486D, CallKey= 0xC6F |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|ForwardManager - wait_SsJoinInd mPartyToActiveCallIndexMap - Add Entries for. Party1= 0x1004857 and Party2= 0x100487D, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|ForwardManager - getCallPickupEntry - No Entry Found for group= |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9161) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4050><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Forwarding - awaitingCallResponse_ForwardStopInd - Stopping. CallKey= 0xC6F|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Forwarding - Unregistered Rejection Intercept- PartyId= 0x1004857, CallKey= 0xC6F|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Forwarding - Unregistered Rejection Intercept- PartyId= 0x100487A, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Forwarding - awaitingCallResponse_SsJoinInd Joined PartyA 0x1004857 and PartyB 0x100487D, CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4005><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::remove() : RP=4005:; bRc=1, T=restart0_LmKeyReleaseReq(), #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4005:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from TransTable, now this table has 5 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from TransTable, now this table has 4 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 19 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 18 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|Delete entries from CiCcp table, now this table has 23 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|StationD: 3b0cb1c ClearPromptStatus lineInstance=1 callReference=16795757.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|StationD: 3b0cb1c CallState callState=2 lineInstance=1 callReference=16795757|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.752 Cisco CallManager|StationInit: 3b0cb1c OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.752 Cisco CallManager|StationD: 3b0cb1c SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=2(LampOn).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='' callingParty=2034220578 cgpnVoiceMailbox= calledPartyName='' calledParty=4050 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=1 lastRedirectingPartyName='' lastRedirectingParty=7100 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=0 callType=1(InBound) lineInstance=2 callReference=16795773. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795773, CallingPartyName=, CallingParty=2034220578, CalledPartyName=, CalledParty=4050, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=7100|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x100486D, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|ForwardManager - findCallBySsParty - mPartyToActiveCallIndexMap entry NOT found for party= 0x100486D |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|ForwardManager - findInterceptBySsParty - Found entry for party= 100486D, SsKey= 1BC |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9160) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.767 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4050><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD - CTI Reason Code: CtiReasonTransferredCall|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
RQNT 16610 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
X: 1
S: G/rt
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c SetSpeakerMode speakermode=2(Off).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c ClearPromptStatus lineInstance=1 callReference=16795770.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16610
03/05/2002 12:11:53.767 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16610|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:53.767 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16610 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c CallState callState=2 lineInstance=1 callReference=16795770|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c DisplayPromptStatus timeOutValue=0 promptStatus='Your current options' content='Your current options' lineInstance=0 callReference=0 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c ActivateCallPlane lineInstance=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c DefineTimeDate timeDateInfo=? systemTime=1015359113.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='' callingParty=2034220578 cgpnVoiceMailbox= calledPartyName='' calledParty=4050 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=1 lastRedirectingPartyName='' lastRedirectingParty=4005 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=3 callType=1(InBound) lineInstance=2 callReference=16795773. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795773, CallingPartyName=, CallingParty=2034220578, CalledPartyName=, CalledParty=4050, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=4005|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 17 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 16 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|Delete entries from TransTable, now this table has 4 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|Delete entries from CiCcp table, now this table has 22 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x100487A, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x100487A, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|ForwardManager - findInterceptBySsParty - mSsToInterceptIndexMap entry NOT found for party= 100487A |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9159) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.767 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x100487A, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:53.767 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4005:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c DefineTimeDate timeDateInfo=? systemTime=1015359113.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.767 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.783 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000821287EA3, TCPHandle=0xc2d6500, Socket=0xd48, IPAddr=10.64.51.10, Port=52327, Device Controller=[1,92,436]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.10><:SEP000821287EA3>
03/05/2002 12:11:53.783 Cisco CallManager|StationInit: c2d6500 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.10><:SEP000821287EA3>
03/05/2002 12:11:53.846 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC466, TCPHandle=0xc2d7568, Socket=0x920, IPAddr=10.64.50.148, Port=50186, Device Controller=[1,92,470]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.148><:SEP0007EB7CC466>
03/05/2002 12:11:53.846 Cisco CallManager|StationInit: c2d7568 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.148><:SEP0007EB7CC466>
03/05/2002 12:11:53.877 Cisco CallManager|StationInit: 3b0cb1c OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.877 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4005:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:53.877 Cisco CallManager|StationD: 3b0cb1c DefineTimeDate timeDateInfo=? systemTime=1015359113.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.877 Cisco CallManager|StationD: 3b0cb1c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.877 Cisco CallManager|StationD: 3b0cb1c SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:11:53.877 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644CC1, TCPHandle=0x72955f0, Socket=0x10ec, IPAddr=10.64.50.233, Port=50618, Device Controller=[1,92,371]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.233><:SEP0007EB644CC1>
03/05/2002 12:11:53.877 Cisco CallManager|StationInit: 72955f0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.233><:SEP0007EB644CC1>
03/05/2002 12:11:53.908 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750528C63, TCPHandle=0x927ce7c, Socket=0x7ac, IPAddr=10.64.50.215, Port=50714, Device Controller=[1,92,258]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.215><:SEP000750528C63>
03/05/2002 12:11:53.908 Cisco CallManager|StationInit: 927ce7c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.215><:SEP000750528C63>
03/05/2002 12:11:54.033 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644DA0, TCPHandle=0x729526c, Socket=0xf24, IPAddr=10.64.50.239, Port=50536, Device Controller=[1,92,363]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.239><:SEP0007EB644DA0>
03/05/2002 12:11:54.033 Cisco CallManager|StationInit: 729526c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.239><:SEP0007EB644DA0>
03/05/2002 12:11:54.096 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC415, TCPHandle=0x7294c2c, Socket=0x99c, IPAddr=10.64.50.153, Port=51446, Device Controller=[1,92,348]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.153><:SEP0007EB7CC415>
03/05/2002 12:11:54.096 Cisco CallManager|StationInit: 7294c2c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.153><:SEP0007EB7CC415>
03/05/2002 12:11:54.174 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B706, TCPHandle=0xc2d6adc, Socket=0x10bc, IPAddr=10.64.50.162, Port=53099, Device Controller=[1,92,450]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.162><:SEP0007EB39B706>
03/05/2002 12:11:54.174 Cisco CallManager|StationInit: c2d6adc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.162><:SEP0007EB39B706>
03/05/2002 12:11:54.346 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16073 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/8
03/05/2002 12:11:54.346 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:54.346 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16073
RQNT 16611 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
200 16611
03/05/2002 12:11:54.346 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16611|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:54.346 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:54.346 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16611 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:54.346 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:54.346 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=8(Eight).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:54.377 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750786E4B, TCPHandle=0xc2d6d34, Socket=0xf58, IPAddr=10.64.50.242, Port=53089, Device Controller=[1,92,161]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.242><:SEP000750786E4B>
03/05/2002 12:11:54.377 Cisco CallManager|StationInit: c2d6d34 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.242><:SEP000750786E4B>
03/05/2002 12:11:54.424 Cisco CallManager|MGCPManager remove recent Incoming transId 16063|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:54.424 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B56C, TCPHandle=0x7294fb0, Socket=0x85c, IPAddr=10.64.50.174, Port=50463, Device Controller=[1,92,356]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.174><:SEP0007EB39B56C>
03/05/2002 12:11:54.424 Cisco CallManager|StationInit: 7294fb0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.174><:SEP0007EB39B56C>
03/05/2002 12:11:54.455 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0004DD1E5C4F, TCPHandle=0x927c904, Socket=0x6dc, IPAddr=10.64.51.5, Port=53073, Device Controller=[1,92,270]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.5><:SEP0004DD1E5C4F>
03/05/2002 12:11:54.455 Cisco CallManager|StationInit: 927c904 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.5><:SEP0004DD1E5C4F>
03/05/2002 12:11:54.517 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A437, TCPHandle=0x3b0dd14, Socket=0x7c0, IPAddr=10.64.50.139, Port=52637, Device Controller=[1,92,432]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.139><:SEP00078546A437>
03/05/2002 12:11:54.517 Cisco CallManager|StationInit: 3b0dd14 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.139><:SEP00078546A437>
03/05/2002 12:11:54.517 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0006D74B1A22, TCPHandle=0xc2d71e4, Socket=0xfb8, IPAddr=10.64.50.147, Port=51110, Device Controller=[1,92,169]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.147><:SEP0006D74B1A22>
03/05/2002 12:11:54.517 Cisco CallManager|StationInit: c2d71e4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.147><:SEP0006D74B1A22>
03/05/2002 12:11:54.564 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B72E, TCPHandle=0xc2d7b44, Socket=0x1014, IPAddr=10.64.50.88, Port=50765, Device Controller=[1,92,480]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.88><:SEP0007EB39B72E>
03/05/2002 12:11:54.564 Cisco CallManager|StationInit: c2d7b44 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.88><:SEP0007EB39B72E>
03/05/2002 12:11:54.705 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16074 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/8
03/05/2002 12:11:54.705 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:54.705 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16074
RQNT 16612 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
200 16612
03/05/2002 12:11:54.705 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16612|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:54.705 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:54.705 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16612 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:54.705 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:54.705 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=8(Eight).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:54.814 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:54.814 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:55.205 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC489, TCPHandle=0xc2d6f28, Socket=0xee4, IPAddr=10.64.50.18, Port=52876, Device Controller=[1,92,458]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:55.205 Cisco CallManager|StationInit: c2d6f28 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:55.299 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00075079C7C4, TCPHandle=0x927cdb4, Socket=0x798, IPAddr=10.64.50.211, Port=52461, Device Controller=[1,92,260]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.211><:SEP00075079C7C4>
03/05/2002 12:11:55.299 Cisco CallManager|StationInit: 927cdb4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.211><:SEP00075079C7C4>
03/05/2002 12:11:55.486 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC421, TCPHandle=0x72956b8, Socket=0x750, IPAddr=10.64.50.107, Port=50373, Device Controller=[1,92,373]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.107><:SEP0007EB7CC421>
03/05/2002 12:11:55.486 Cisco CallManager|StationInit: 72956b8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.107><:SEP0007EB7CC421>
03/05/2002 12:11:55.611 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC435, TCPHandle=0x725e45c, Socket=0x86c, IPAddr=10.64.50.198, Port=50373, Device Controller=[1,92,487]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.198><:SEP0007EB7CC435>
03/05/2002 12:11:55.611 Cisco CallManager|StationInit: 725e45c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.198><:SEP0007EB7CC435>
03/05/2002 12:11:55.752 Cisco CallManager|StationInit: 725eb64 OffHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 ClearNotify.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 SetRinger ringMode=1(RingOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=2(LampOn).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 CallState callState=1 lineInstance=1 callReference=16795768|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 ActivateCallPlane lineInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004878, BCC= 5|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004878, CallKey= 0xC73 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795739,16795768): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 18|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|ConnectionManager - storeMediaInfo(16795768): ADD NEW ENTRY, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004878, BCC= 5|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_CONNECT - CFNA timer Reset. CallKey= 0xC73|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6615) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaManager(6615) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:55.767 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795739) and party2(16795768)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795739,16795768)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 OpenReceiveChannel conferenceID=0 passThruPartyID=97025 millisecondPacketSize=20 compressionType=4(Media_Payload_G711Ulaw64k) qualifierIn=?. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:55.767 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16613 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
C: D00000000100485b00000000800014bf
I: 4
X: 4
L: p:20, a:PCMU, s:off
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:55.767 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16613
03/05/2002 12:11:55.767 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16613|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:55.767 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:55.767 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16613 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:55.767 Cisco CallManager|StationD: 725eb64 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|StationD: 725eb64 CallState callState=5 lineInstance=1 callReference=16795768|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='' callingParty= cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=4003 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=3 callType=1(InBound) lineInstance=1 callReference=16795768. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795768, CallingPartyName=, CallingParty=, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=4003|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=1 reference=16795768 softKeySetIndex=1 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|StationD: 725eb64 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Connected' lineInstance=1 callReference=16795768 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
RQNT 16614 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
X: 4
S:
03/05/2002 12:11:55.783 Cisco CallManager|StationD: 725eb64 StartMediaTransmission conferenceID=0 passThruPartyID=97025 remoteIpAddress=132400a(10.64.50.1) remotePortNumber=24224 milliSecondPacketSize=20 compressType=4(Media_Payload_G711Ulaw64k) qualifierOut=?. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:55.783 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16614
03/05/2002 12:11:55.783 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16614|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:55.783 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:55.783 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16614 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:55.783 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:55.783 Cisco CallManager|StationInit: 725eb64 OpenReceiveChannelAck Status=0, IpAddr=0xd232400a, Port=23266, PartyID=97025|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
MDCX 16615 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 4 0 IN EPN S0/DS1-0/4@SDA00908F003733
s=Cisco SDP 0
t=0 0
c=IN IP4 10.64.50.210
m=audio 23266 RTP/AVP 96
a=rtpmap:96 PCMU
03/05/2002 12:11:55.783 Cisco CallManager|Locations: adjust: cdcc=9149 readjusting ciA=16795739 ciB=16795768 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:11:55.783 Cisco CallManager|Locations_adjustBandwidth -- cdccPID=(1.15.9149) Orig=Dest=0 no entry for cdcc. No need to adjust.|<:API-CM-1-CLUSTER><:10.64.5.11>
200 16615
03/05/2002 12:11:55.783 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16615|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:55.783 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16615 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:55.814 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B8B3, TCPHandle=0x3b0dcb0, Socket=0x98c, IPAddr=10.64.50.58, Port=52297, Device Controller=[1,92,431]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.58><:SEP0007EB39B8B3>
03/05/2002 12:11:55.814 Cisco CallManager|StationInit: 3b0dcb0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.58><:SEP0007EB39B8B3>
03/05/2002 12:11:55.877 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785056970, TCPHandle=0x725e204, Socket=0x664, IPAddr=10.64.50.76, Port=51383, Device Controller=[1,92,482]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.76><:SEP000785056970>
03/05/2002 12:11:55.877 Cisco CallManager|StationInit: 725e204 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.76><:SEP000785056970>
03/05/2002 12:11:55.908 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644DE4, TCPHandle=0x7295398, Socket=0xe78, IPAddr=10.64.50.106, Port=50616, Device Controller=[1,92,366]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.106><:SEP0007EB644DE4>
03/05/2002 12:11:55.908 Cisco CallManager|StationInit: 7295398 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.106><:SEP0007EB644DE4>
03/05/2002 12:11:56.033 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB4622BB, TCPHandle=0xc2d7248, Socket=0x7fc, IPAddr=10.64.50.6, Port=49781, Device Controller=[1,92,464]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.6><:SEP0007EB4622BB>
03/05/2002 12:11:56.033 Cisco CallManager|StationInit: c2d7248 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.6><:SEP0007EB4622BB>
03/05/2002 12:11:56.127 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B59D, TCPHandle=0x7294844, Socket=0xf8c, IPAddr=10.64.50.183, Port=50188, Device Controller=[1,92,345]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.183><:SEP0007EB39B59D>
03/05/2002 12:11:56.127 Cisco CallManager|StationInit: 7294844 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.183><:SEP0007EB39B59D>
03/05/2002 12:11:56.221 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=VGC0653d6b3d704, TCPHandle=0x72948a8, Socket=0xaa0, IPAddr=10.64.15.130, Port=20960, Device Controller=[1,92,275]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D704>
03/05/2002 12:11:56.221 Cisco CallManager|StationInit: 72948a8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D704>
03/05/2002 12:11:56.236 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785532B69, TCPHandle=0xc2d6c6c, Socket=0xc5c, IPAddr=10.64.50.60, Port=53155, Device Controller=[1,92,454]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.60><:SEP000785532B69>
03/05/2002 12:11:56.236 Cisco CallManager|StationInit: c2d6c6c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.60><:SEP000785532B69>
03/05/2002 12:11:56.424 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16075 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/4
03/05/2002 12:11:56.424 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:56.424 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16075
RQNT 16616 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
200 16616
03/05/2002 12:11:56.424 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16616|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:56.424 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:56.424 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16616 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:56.424 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:56.424 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=4(Four).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:56.533 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00070E81000A, TCPHandle=0x725e4c0, Socket=0x10d0, IPAddr=10.64.50.116, Port=52161, Device Controller=[1,92,185]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.116><:SEP00070E81000A>
03/05/2002 12:11:56.533 Cisco CallManager|StationInit: 725e4c0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.116><:SEP00070E81000A>
03/05/2002 12:11:56.549 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785057217, TCPHandle=0x927c9cc, Socket=0x854, IPAddr=10.64.50.154, Port=52308, Device Controller=[1,92,295]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.154><:SEP000785057217>
03/05/2002 12:11:56.549 Cisco CallManager|StationInit: 927c9cc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.154><:SEP000785057217>
03/05/2002 12:11:56.814 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:56.814 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.064 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC42F, TCPHandle=0x7294d58, Socket=0xb94, IPAddr=10.64.50.170, Port=50458, Device Controller=[1,92,351]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.170><:SEP0007EB7CC42F>
03/05/2002 12:11:57.064 Cisco CallManager|StationInit: 7294d58 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.170><:SEP0007EB7CC42F>
03/05/2002 12:11:57.330 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16076 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/3
03/05/2002 12:11:57.330 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:57.330 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16076
RQNT 16617 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
200 16617
03/05/2002 12:11:57.330 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16617|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:57.330 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:57.330 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16617 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:57.330 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:57.330 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=3(Three).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:57.455 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB3F637E, TCPHandle=0xc2d743c, Socket=0xc20, IPAddr=10.64.50.172, Port=49962, Device Controller=[1,92,468]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.172><:SEP0007EB3F637E>
03/05/2002 12:11:57.455 Cisco CallManager|StationInit: c2d743c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.172><:SEP0007EB3F637E>
03/05/2002 12:11:57.502 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0006D7446A86, TCPHandle=0xc2d6d98, Socket=0xf60, IPAddr=10.64.50.206, Port=50529, Device Controller=[1,92,254]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.206><:SEP0006D7446A86>
03/05/2002 12:11:57.502 Cisco CallManager|StationInit: c2d6d98 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.206><:SEP0006D7446A86>
03/05/2002 12:11:57.768 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.768 Cisco CallManager|In Message -- H225AlertMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.768 Cisco CallManager|Ie - Q931ProgressIndIe -- IEData= 1E 02 80 88 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.768 Cisco CallManager|Ie - Q931SignalIe -- IEData= 34 01 01 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.768 Cisco CallManager|Ie - H225UserUserIe -- IEData= 7E 00 3D 05 23 C0 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D8 09 00 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 06 A0 01 00 12 01 40 B5 00 00 12 0B 60 01 04 00 01 1E 04 1E 02 80 88 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.768 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.768 Cisco CallManager|IsdnMsgData1= 08 02 86 5A 01 1E 02 80 88 34 01 01 7E 00 3D 05 23 C0 06 00 08 91 4A 00 02 00 00 0A 40 0F 6F 77 D8 09 00 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 06 A0 01 00 12 01 40 B5 00 00 12 0B 60 01 04 00 01 1E 04 1E 02 80 88 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.768 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785057112, TCPHandle=0xc2d7374, Socket=0xf70, IPAddr=10.64.50.41, Port=52976, Device Controller=[1,92,466]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.41><:SEP000785057112>
03/05/2002 12:11:57.768 Cisco CallManager|StationInit: c2d7374 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.41><:SEP000785057112>
03/05/2002 12:11:57.783 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795762,16795763): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|ConnectionManager - storeMediaInfo(16795762): ADD NEW ENTRY, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|ConnectionManager - storeMediaInfo(16795763): ADD NEW ENTRY, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6616) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaManager(6616) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaManager - wait_AuConnectRequest(capbility query) - creating connection between party1(16795762) and party2(16795763)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|StationD: c2d6f28 CallState callState=12 lineInstance=1 callReference=16795762|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|StationD: c2d6f28 CallInfo callingPartyName='Tracy Quinten' callingParty=7302 cgpnVoiceMailbox= calledPartyName='' calledParty=16198432987 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=16198432987 originalCdpnVoiceMailbox= originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty= lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795762. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795762, CallingPartyName=Tracy Quinten, CallingParty=7302, CalledPartyName=, CalledParty=16198432987, OriginalCalledPartyName=, OriginalCalledParty=16198432987, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|StationD: c2d6f28 DialedNumber dialedNumber=916198432987 lineInstance=1 callReference=16795762.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:11:57.783 Cisco CallManager|ProcessH245Interface(0) created w/ ip = 6f0f400a and port = 30680|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:11:57.783 Cisco CallManager|H245Interface(1546)::start (H245Client session) ip = 6f0f400a, port = 30680|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795762) and party2(16795763)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.783 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.783 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795762,16795763)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.939 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7302><:>
03/05/2002 12:11:57.939 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=7302:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:57.939 Cisco CallManager|StationD: c2d6f28 CallInfo callingPartyName='Tracy Quinten' callingParty=7302 cgpnVoiceMailbox= calledPartyName='' calledParty=16198432987 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty= originalCdpnVoiceMailbox= originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=16198432987 lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795762. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.939 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795762, CallingPartyName=Tracy Quinten, CallingParty=7302, CalledPartyName=, CalledParty=16198432987, OriginalCalledPartyName=, OriginalCalledParty=, lastRedirectingPartyName=, lastRedirectingParty=16198432987|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.939 Cisco CallManager|StationD: c2d6f28 CallState callState=3 lineInstance=1 callReference=16795762|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.939 Cisco CallManager|StationD: c2d6f28 SelectSoftKeys instance=1 reference=16795762 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.939 Cisco CallManager|StationD: c2d6f28 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Ring Out' lineInstance=1 callReference=16795762 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:57.986 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CFB_API-CM-1, TCPHandle=0x7294718, Socket=0xa74, IPAddr=10.64.5.11, Port=1452, Device Controller=[1,102,2]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.11><:CFB_API-CM-1>
03/05/2002 12:11:57.986 Cisco CallManager|StationInit: 7294718 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.11><:CFB_API-CM-1>
03/05/2002 12:11:57.986 Cisco CallManager|MediaManager - wait_AuReConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:57.986 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:57.986 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6616)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, send ReconnectRequest to MC|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaCoordinator - wait_AuReConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6616) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6617) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaManager(6617) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:11:58.002 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795762) and party2(16795763)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.002 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.174 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C672F8, TCPHandle=0x927c83c, Socket=0xaf4, IPAddr=10.64.50.93, Port=52299, Device Controller=[1,92,293]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.93><:SEP000750C672F8>
03/05/2002 12:11:58.174 Cisco CallManager|StationInit: 927c83c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.93><:SEP000750C672F8>
03/05/2002 12:11:58.189 Cisco CallManager|H245Interface(1546) OLC indication chan number = 1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.189 Cisco CallManager|StationD: c2d6f28 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.189 Cisco CallManager|StationD: c2d6f28 OpenReceiveChannel conferenceID=0 passThruPartyID=97041 millisecondPacketSize=20 compressionType=4(Media_Payload_G711Ulaw64k) qualifierIn=?. myIP: 1232400a (10.64.50.18)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.205 Cisco CallManager|StationInit: c2d6f28 OpenReceiveChannelAck Status=0, IpAddr=0x1232400a, Port=29568, PartyID=97041|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:58.205 Cisco CallManager|H245Interface(1546) paths established ip = 1232400a, port = 29568|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.18><:SEP0007EB7CC489>
03/05/2002 12:11:58.205 Cisco CallManager|H245Interface(1546) OLC outgoing confirm ip = 6f0f400a, port = 16962|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.205 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.205 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.205 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.205 Cisco CallManager|StationD: c2d6f28 StartMediaTransmission conferenceID=0 passThruPartyID=97041 remoteIpAddress=6f0f400a(10.64.15.111) remotePortNumber=16962 milliSecondPacketSize=20 compressType=4(Media_Payload_G711Ulaw64k) qualifierOut=?. myIP: 1232400a (10.64.50.18)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:PORT 30680="">
03/05/2002 12:11:58.221 Cisco CallManager|Locations_adjustBandwidth -- cdccPID=(1.15.9154) Orig=Dest=0 no entry for cdcc. No need to adjust.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.283 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B858, TCPHandle=0xc2d7310, Socket=0xf14, IPAddr=10.64.50.144, Port=51985, Device Controller=[1,92,465]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.144><:SEP0007EB39B858>
03/05/2002 12:11:58.283 Cisco CallManager|StationInit: c2d7310 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.144><:SEP0007EB39B858>
03/05/2002 12:11:58.346 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000821541612, TCPHandle=0xc2d67bc, Socket=0xf98, IPAddr=10.64.51.3, Port=52504, Device Controller=[1,92,442]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.3><:SEP000821541612>
03/05/2002 12:11:58.346 Cisco CallManager|StationInit: c2d67bc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.3><:SEP000821541612>
03/05/2002 12:11:58.502 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB462208, TCPHandle=0x7295974, Socket=0xde8, IPAddr=10.64.50.243, Port=50984, Device Controller=[1,92,380]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.243><:SEP0007EB462208>
03/05/2002 12:11:58.502 Cisco CallManager|StationInit: 7295974 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.243><:SEP0007EB462208>
03/05/2002 12:11:58.814 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.814 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.846 Cisco CallManager|MGCPManager remove recent Incoming transId 66926|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.121><:>
03/05/2002 12:11:58.861 Cisco CallManager|MGCPHandler received msg from: 10.64.15.121
NTFY 66928 *@API-VG200FXO-1 MGCP 0.1
X: 0
O:
03/05/2002 12:11:58.861 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:><:>
03/05/2002 12:11:58.861 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.15.121
200 66928
03/05/2002 12:11:58.877 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16077 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/9
03/05/2002 12:11:58.877 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:11:58.877 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16077
RQNT 16618 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
200 16618
03/05/2002 12:11:58.877 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16618|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:58.877 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:58.877 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16618 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.877 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.877 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=9(Nine).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.893 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785056A9F, TCPHandle=0x927c710, Socket=0xf18, IPAddr=10.64.50.161, Port=51991, Device Controller=[1,92,291]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.161><:SEP000785056A9F>
03/05/2002 12:11:58.893 Cisco CallManager|StationInit: 927c710 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.161><:SEP000785056A9F>
03/05/2002 12:11:58.908 Cisco CallManager|MGCPBhHandler 10.64.50.1 - TCP msg available from Device|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:58.908 Cisco CallManager|MGCPBhHandler - Receiving BhHdr: 0004 0000 0011 0000 0001 0009
03/05/2002 12:11:58.908 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.908 Cisco CallManager|In Message -- PriDisconnectMsg -- Protocol= PriDmsProtocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.908 Cisco CallManager|Ie - Q931CauseIe -- IEData= 08 02 80 90 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.908 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=132400a IpPort=2427)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.908 Cisco CallManager|IsdnMsgData1= 08 02 18 88 45 08 02 80 90 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.908 Cisco CallManager|SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 7, MCStatus = 0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.908 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004814, BCC= 6|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004814, CallKey= 0xC63 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795668,16795671): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|ConnectionManager - storeMediaInfo(16795668): EXISTING ENTRY DISCOVERED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|ConnectionManager - storeMediaInfo(16795671): EXISTING ENTRY DISCOVERED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004814, BCC= 6|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6579)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - StopSession sending disconnect to (74,6579) and remove connection from list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|StationD: 3b0c66c CloseReceiveChannel conferenceID=0 passThruPartyID=96545. myIP: 1505400a (10.64.5.21)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|StationD: 3b0c66c StopMediaTransmission conferenceID=0 passThruPartyID=96545. myIP: 1505400a (10.64.5.21)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16619 S0/DS1-0/3@SDA00908F003733 MGCP 0.1
C: D0000000010048140000000080001888
I: 3
X: 3
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:11:58.908 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16619
03/05/2002 12:11:58.908 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16619|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:58.908 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16619 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795668) and party2(16795671)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6579) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795668,16795671): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795668): ENTRY DELETED, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795671): ENTRY DELETED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.908 Cisco CallManager|Out Message -- PriReleaseMsg -- Protocol= PriDmsProtocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.908 Cisco CallManager|IsdnMsgData2= 08 02 98 88 4D |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.924 Cisco CallManager|MGCPBhHandler - Sending BhHdr: 0004 0000 0010 0000 0001 0005
03/05/2002 12:11:58.924 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4001><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4001:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.924 Cisco CallManager|StationCdpc - INFO: clearType=0, mHoldFlag=0, mMediaConnFlag=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationCdpc - INFO: NormalClear.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c DefineTimeDate timeDateInfo=? systemTime=1015359118.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c SetSpeakerMode speakermode=2(Off).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c ClearPromptStatus lineInstance=1 callReference=16795671.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c CallState callState=2 lineInstance=1 callReference=16795671|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c DisplayPromptStatus timeOutValue=0 promptStatus='Your current options' content='Your current options' lineInstance=0 callReference=0 ver=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c ActivateCallPlane lineInstance=0.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=1(LampOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|StationD: 3b0c66c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004817, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004817, CallKey= 0xC63 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|ForwardManager - wait_SsDataInd mPartyToActiveCallIndexMap - Removed entry DestParty= 0x1004817, CallKey= 0xC63 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|ForwardManager - findInterceptBySsParty - Found entry for party= 1004817, SsKey= B1 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004817, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.924 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_RELEASE - Destination Release. Party= 0x1004817, CallKey= 0xC63|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.939 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785993700, TCPHandle=0x927d714, Socket=0x8b4, IPAddr=10.64.50.67, Port=52567, Device Controller=[1,92,36]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.67><:SEP000785993700>
03/05/2002 12:11:58.939 Cisco CallManager|StationInit: 927d714 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.67><:SEP000785993700>
03/05/2002 12:11:58.939 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B742, TCPHandle=0x7295208, Socket=0x7d8, IPAddr=10.64.50.171, Port=50312, Device Controller=[1,92,362]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.171><:SEP0007EB39B742>
03/05/2002 12:11:58.939 Cisco CallManager|StationInit: 7295208 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.171><:SEP0007EB39B742>
03/05/2002 12:11:58.955 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B75D, TCPHandle=0xc2d79b4, Socket=0x10f0, IPAddr=10.64.50.145, Port=53163, Device Controller=[1,92,478]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.145><:SEP0007EB39B75D>
03/05/2002 12:11:58.955 Cisco CallManager|StationInit: c2d79b4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.145><:SEP0007EB39B75D>
03/05/2002 12:11:58.955 Cisco CallManager|MGCPBhHandler 10.64.50.1 - TCP msg available from Device|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:58.955 Cisco CallManager|MGCPBhHandler - Receiving BhHdr: 0004 0000 0011 0000 0001 0005
03/05/2002 12:11:58.955 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.955 Cisco CallManager|In Message -- PriReleaseCompleteMsg -- Protocol= PriDmsProtocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.955 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=132400a IpPort=2427)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.955 Cisco CallManager|IsdnMsgData1= 08 02 18 88 5A |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.955 Cisco CallManager|SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 7, MCStatus = 0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.955 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 15 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|Delete entries from MonitorPartyTable, now this table has 14 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|Delete entries from TransTable, now this table has 3 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|Delete entries from CiCcp table, now this table has 20 entries|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
DLCX 16620 S0/DS1-0/3@SDA00908F003733 MGCP 0.1
I: 3
X: 3
S:
03/05/2002 12:11:58.955 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x1004814, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x1004814, CallKey= 0xC63 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|ForwardManager - findInterceptBySsParty - mSsToInterceptIndexMap entry NOT found for party= 1004814 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|Locations_releaseBandwidth -- cdccPID=(1.15.9117) no entry.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:58.955 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x1004814, BCC= 7|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_RELEASE - Stopping Forwarding on origination Release. Party= 0x1004814, CallKey= 0xC63|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|ForwardManager - removeActiveCallTableEntry mPartyToActiveCallIndexMap - Removed entry OrigParty= 0x1004814, CallKey= 0xC63 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|ForwardManager - removeActiveCallTableEntry - Removed entry from CallTable and Mapping tables for OrigParty= 0x1004814, DestParty= 0x0, CallKey= 0xC63 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|Forwarding - Unregistered Rejection Intercept- PartyId= 0x1004814, CallKey= 0xC63|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
250 16620
P: PS=17290, OS=2766400, PR=15238, OR=2438080, PL=0, JI=0, LA=0
03/05/2002 12:11:58.955 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16620|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:11:58.955 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:11:58.955 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16620 FOUND a match for DLCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:11:58.971 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644E18, TCPHandle=0x72950dc, Socket=0xeb0, IPAddr=10.64.50.65, Port=51420, Device Controller=[1,92,359]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.65><:SEP0007EB644E18>
03/05/2002 12:11:58.971 Cisco CallManager|StationInit: 72950dc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.65><:SEP0007EB644E18>
03/05/2002 12:11:59.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644CF0, TCPHandle=0x7295848, Socket=0xfb4, IPAddr=10.64.50.94, Port=51324, Device Controller=[1,92,377]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.94><:SEP0007EB644CF0>
03/05/2002 12:11:59.002 Cisco CallManager|StationInit: 7295848 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.94><:SEP0007EB644CF0>
03/05/2002 12:11:59.018 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A080, TCPHandle=0xc2d74a0, Socket=0x8d4, IPAddr=10.64.50.17, Port=52894, Device Controller=[1,92,469]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.17><:SEP00078546A080>
03/05/2002 12:11:59.018 Cisco CallManager|StationInit: c2d74a0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.17><:SEP00078546A080>
03/05/2002 12:11:59.064 Cisco CallManager|StationInit: 3b0c66c OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:11:59.064 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=4001:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:11:59.064 Cisco CallManager|StationD: 3b0c66c DefineTimeDate timeDateInfo=? systemTime=1015359119.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:11:59.064 Cisco CallManager|StationD: 3b0c66c StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:11:59.064 Cisco CallManager|StationD: 3b0c66c SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:11:59.111 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A0BD, TCPHandle=0xc2d77c0, Socket=0xbfc, IPAddr=10.64.50.26, Port=52852, Device Controller=[1,92,474]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.26><:SEP00078546A0BD>
03/05/2002 12:11:59.111 Cisco CallManager|StationInit: c2d77c0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.26><:SEP00078546A0BD>
03/05/2002 12:11:59.111 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A3B8, TCPHandle=0xc2d68e8, Socket=0xe94, IPAddr=10.64.50.10, Port=52876, Device Controller=[1,92,445]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.10><:SEP00078546A3B8>
03/05/2002 12:11:59.111 Cisco CallManager|StationInit: c2d68e8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.10><:SEP00078546A3B8>
03/05/2002 12:11:59.377 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC487, TCPHandle=0xc2d7888, Socket=0xb8c, IPAddr=10.64.50.184, Port=52963, Device Controller=[1,92,476]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.184><:SEP0007EB7CC487>
03/05/2002 12:11:59.377 Cisco CallManager|StationInit: c2d7888 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.184><:SEP0007EB7CC487>
03/05/2002 12:11:59.439 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750DD07A4, TCPHandle=0xc2d775c, Socket=0xf4c, IPAddr=10.64.50.199, Port=50352, Device Controller=[1,92,473]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.199><:SEP000750DD07A4>
03/05/2002 12:11:59.439 Cisco CallManager|StationInit: c2d775c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.199><:SEP000750DD07A4>
03/05/2002 12:11:59.674 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC428, TCPHandle=0x7294ee8, Socket=0xba4, IPAddr=10.64.50.112, Port=50526, Device Controller=[1,92,354]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.112><:SEP0007EB7CC428>
03/05/2002 12:11:59.674 Cisco CallManager|StationInit: 7294ee8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.112><:SEP0007EB7CC428>
03/05/2002 12:11:59.705 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B695, TCPHandle=0xc2d75cc, Socket=0xcfc, IPAddr=10.64.50.52, Port=53221, Device Controller=[1,92,471]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.52><:SEP0007EB39B695>
03/05/2002 12:11:59.705 Cisco CallManager|StationInit: c2d75cc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.52><:SEP0007EB39B695>
03/05/2002 12:11:59.752 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750D54B0A, TCPHandle=0x7294e20, Socket=0xad8, IPAddr=10.64.50.86, Port=50507, Device Controller=[1,92,352]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.86><:SEP000750D54B0A>
03/05/2002 12:11:59.752 Cisco CallManager|StationInit: 7294e20 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.86><:SEP000750D54B0A>
03/05/2002 12:11:59.768 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B773, TCPHandle=0xc2d7630, Socket=0xed0, IPAddr=10.64.50.178, Port=53024, Device Controller=[1,92,472]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.178><:SEP0007EB39B773>
03/05/2002 12:11:59.768 Cisco CallManager|StationInit: c2d7630 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.178><:SEP0007EB39B773>
03/05/2002 12:11:59.939 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007850568B5, TCPHandle=0x7295014, Socket=0x984, IPAddr=10.64.50.33, Port=51654, Device Controller=[1,92,357]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.33><:SEP0007850568B5>
03/05/2002 12:11:59.939 Cisco CallManager|StationInit: 7295014 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.33><:SEP0007850568B5>
03/05/2002 12:11:59.955 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644CBA, TCPHandle=0x7295b04, Socket=0x76c, IPAddr=10.64.50.57, Port=51087, Device Controller=[1,92,384]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.57><:SEP0007EB644CBA>
03/05/2002 12:11:59.955 Cisco CallManager|StationInit: 7295b04 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.57><:SEP0007EB644CBA>
03/05/2002 12:11:59.971 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB59463F, TCPHandle=0x725ea9c, Socket=0xb5c, IPAddr=10.64.50.212, Port=52968, Device Controller=[1,92,495]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.212><:SEP0007EB59463F>
03/05/2002 12:11:59.971 Cisco CallManager|StationInit: 725ea9c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.212><:SEP0007EB59463F>
03/05/2002 12:11:59.971 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EBF0F19D, TCPHandle=0x729558c, Socket=0x930, IPAddr=10.64.50.126, Port=50509, Device Controller=[1,92,370]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.126><:SEP0007EBF0F19D>
03/05/2002 12:11:59.971 Cisco CallManager|StationInit: 729558c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.126><:SEP0007EBF0F19D>
03/05/2002 12:12:00.018 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785469CC2, TCPHandle=0x927cc24, Socket=0x10c0, IPAddr=10.64.50.77, Port=52489, Device Controller=[1,92,300]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.77><:SEP000785469CC2>
03/05/2002 12:12:00.018 Cisco CallManager|StationInit: 927cc24 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.77><:SEP000785469CC2>
03/05/2002 12:12:00.158 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007850571F2, TCPHandle=0x7295528, Socket=0xc78, IPAddr=10.64.50.16, Port=50808, Device Controller=[1,92,369]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.16><:SEP0007850571F2>
03/05/2002 12:12:00.158 Cisco CallManager|StationInit: 7295528 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.16><:SEP0007850571F2>
03/05/2002 12:12:00.174 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A1B7, TCPHandle=0x7294c90, Socket=0xfa8, IPAddr=10.64.50.44, Port=50452, Device Controller=[1,92,349]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.44><:SEP00078546A1B7>
03/05/2002 12:12:00.174 Cisco CallManager|StationInit: 7294c90 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.44><:SEP00078546A1B7>
03/05/2002 12:12:00.236 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16078 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/7
03/05/2002 12:12:00.236 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:12:00.252 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16078
RQNT 16621 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:00.252 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16621
03/05/2002 12:12:00.252 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16621|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:00.252 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:00.252 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16621 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.252 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.252 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=7(Seven).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.283 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00075079C0DC, TCPHandle=0x7294a38, Socket=0xa94, IPAddr=10.64.50.192, Port=53105, Device Controller=[1,92,117]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.192><:SEP00075079C0DC>
03/05/2002 12:12:00.283 Cisco CallManager|StationInit: 7294a38 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.192><:SEP00075079C0DC>
03/05/2002 12:12:00.299 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644C62, TCPHandle=0x72953fc, Socket=0x1050, IPAddr=10.64.50.150, Port=50505, Device Controller=[1,92,520]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.150><:SEP0007EB644C62>
03/05/2002 12:12:00.299 Cisco CallManager|StationInit: 72953fc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.150><:SEP0007EB644C62>
03/05/2002 12:12:00.314 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00075079C77B, TCPHandle=0x725ec2c, Socket=0x116c, IPAddr=10.64.50.201, Port=52720, Device Controller=[1,92,255]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.201><:SEP00075079C77B>
03/05/2002 12:12:00.314 Cisco CallManager|StationInit: 725ec2c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.201><:SEP00075079C77B>
03/05/2002 12:12:00.346 Cisco CallManager|StationInit: 725eb64 SoftKeyEvent softKeyEvent=3 lineInstance=1 callReference=16795768.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795739,16795768): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|ConnectionManager - storeMediaInfo(16795768): EXISTING ENTRY DISCOVERED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6615)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6615)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 CloseReceiveChannel conferenceID=0 passThruPartyID=97025. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 StopMediaTransmission conferenceID=0 passThruPartyID=97025. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.346 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16622 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:00.346 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16622
03/05/2002 12:12:00.346 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16622|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:00.346 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16622 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795739) and party2(16795768)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6615) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795739,16795768): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7100><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq - MRGL=0,CREATED CHILD USING DEFAULT LIST|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-1 Group=0 Counter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-2 Group=0 Counter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc - Started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::findDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq MtpDevice=MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 DefineTimeDate timeDateInfo=? systemTime=1015359120.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 CallState callState=8 lineInstance=1 callReference=16795768|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=1 reference=16795768 softKeySetIndex=2 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Hold' lineInstance=1 callReference=16795768 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::store() : RP=7100:, bRc=1, CallOrigin=5, T=restart0_DStopInd(), #entries=2|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 SetRinger ringMode=2(InsideRing).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 SetSpeakerMode speakermode=2(Off).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|StationD: 725eb64 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=3(LampWink).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes MohResource=MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|Locations_reserveBandwidthForMediaResource -- cdccPID=(1.15.9149) UserParty=Media Source=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:00.346 Cisco CallManager|MohDControl - AllocateMohResourceReq successfully - AudioSourceID and MuticastFlag = 1, 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::resource_rsvp_AllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MRM::updateMohCounter MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MRM::updateMohCounter allocateCounter=1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceManager::waiting_MrmChildStopInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.346 Cisco CallManager|MediaResourceCdpc::shutting_down_MrmChildStopConf|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795739,16795774): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 19|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|ConnectionManager - storeMediaInfo(16795774): ADD NEW ENTRY, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6618) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaManager(6618) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:00.361 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795739) and party2(16795774)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795739,16795774)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16623 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
C: D00000000100485b00000000800014bf
I: 4
X: 4
L: p:20, a:PCMU, s:off
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:00.361 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16623
03/05/2002 12:12:00.361 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16623|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:00.361 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16623 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
MDCX 16624 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
v=0
o=- 4 0 IN EPN S0/DS1-0/4@SDA00908F003733
s=Cisco SDP 0
t=0 0
c=IN IP4 0.0.0.0
m=audio 0 RTP/AVP 96
a=rtpmap:96 PCMU
03/05/2002 12:12:00.361 Cisco CallManager|MohDControl - stationOutputStartMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.361 Cisco CallManager|MohDControl - RemoteIpAddr: 132400a (10.64.50.1) RemoteRtpPortNumber: 24224 msecPacketSize: 20 compressionType: 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
200 16624
03/05/2002 12:12:00.361 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16624|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:00.361 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16624 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.658 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785057125, TCPHandle=0x725e268, Socket=0x80c, IPAddr=10.64.50.228, Port=52984, Device Controller=[1,92,483]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.228><:SEP000785057125>
03/05/2002 12:12:00.658 Cisco CallManager|StationInit: 725e268 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.228><:SEP000785057125>
03/05/2002 12:12:00.705 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078599380E, TCPHandle=0x72949d4, Socket=0xab8, IPAddr=10.64.50.200, Port=52015, Device Controller=[1,92,33]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.200><:SEP00078599380E>
03/05/2002 12:12:00.705 Cisco CallManager|StationInit: 72949d4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.200><:SEP00078599380E>
03/05/2002 12:12:00.705 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B7B0, TCPHandle=0x72951a4, Socket=0x7b8, IPAddr=10.64.50.152, Port=50341, Device Controller=[1,92,361]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.152><:SEP0007EB39B7B0>
03/05/2002 12:12:00.705 Cisco CallManager|StationInit: 72951a4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.152><:SEP0007EB39B7B0>
03/05/2002 12:12:00.768 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
NTFY 16079 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
O: D/#
03/05/2002 12:12:00.768 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:>
03/05/2002 12:12:00.768 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
200 16079
RQNT 16625 S0/DS1-0/5@SDA00908F003733 MGCP 0.1
X: 5
R: D/[0-9ABCD*#]
Q: process,loop
200 16625
03/05/2002 12:12:00.768 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16625|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:00.768 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:00.768 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16625 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.768 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.768 Cisco CallManager|StationD: 3b0c9f0 KeypadButton KeyPadButton=15(Pound).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:00.768 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007505A3713, TCPHandle=0x725e970, Socket=0x1130, IPAddr=10.64.50.187, Port=53182, Device Controller=[1,92,164]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.187><:SEP0007505A3713>
03/05/2002 12:12:00.768 Cisco CallManager|StationInit: 725e970 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.187><:SEP0007505A3713>
03/05/2002 12:12:00.814 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:00.814 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:00.814 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A42D, TCPHandle=0x72957e4, Socket=0xbd4, IPAddr=10.64.50.120, Port=51001, Device Controller=[1,92,376]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.120><:SEP00078546A42D>
03/05/2002 12:12:00.814 Cisco CallManager|StationInit: 72957e4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.120><:SEP00078546A42D>
03/05/2002 12:12:00.861 Cisco CallManager|StationInit: 725eb64 OnHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.861 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=7100:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:00.861 Cisco CallManager|StationD: 725eb64 DefineTimeDate timeDateInfo=? systemTime=1015359120.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.861 Cisco CallManager|StationD: 725eb64 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:00.861 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=0 reference=0 softKeySetIndex=0 validKeyMask=7.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|StationInit: 725eb64 OffHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|StationD: 725eb64 ClearNotify.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|StationD: 725eb64 SetRinger ringMode=1(RingOff).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|StationD: 725eb64 SetLamp stimulus=9(Line) stimulusInstance=2 lampMode=2(LampOn).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|StationD: 725eb64 CallState callState=1 lineInstance=2 callReference=16795773|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|StationD: 725eb64 ActivateCallPlane lineInstance=2.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|ForwardManager - wait_SsDataInd - Key= 0x0, Party= 0x100487D, BCC= 5|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|ForwardManager - findCallBySsParty - Found entry for party= 0x100487D, CallKey= 0xC74 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795735,16795773): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|ConnectionManager - storeMediaInfo(16795735): EXISTING ENTRY DISCOVERED, tail == 20|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|ConnectionManager - storeMediaInfo(16795773): ADD NEW ENTRY, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - Key= 0x0, Party= 0x100487D, BCC= 5|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|Forwarding - awaitingCallResponse_SsDataInd - BASIC_CALL_CONNECT - CFNA timer Reset. CallKey= 0xC74|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6619) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|MediaManager(6619) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:01.080 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.080 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795735) and party2(16795773)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795735,16795773)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 OpenReceiveChannel conferenceID=0 passThruPartyID=97073 millisecondPacketSize=20 compressionType=4(Media_Payload_G711Ulaw64k) qualifierIn=?. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:01.096 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16626 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
C: D00000000100485700000000800012c8
I: 1
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:01.096 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16626
03/05/2002 12:12:01.096 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16626|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:01.096 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:01.096 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16626 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 CallState callState=5 lineInstance=2 callReference=16795773|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='' callingParty=2034220578 cgpnVoiceMailbox= calledPartyName='' calledParty=4050 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty=7100 originalCdpnVoiceMailbox=7100 originalCdpnRedirectReason=1 lastRedirectingPartyName='' lastRedirectingParty=4005 lastRedirectingVoiceMailbox=7100 lastRedirectingReason=3 callType=1(InBound) lineInstance=2 callReference=16795773. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795773, CallingPartyName=, CallingParty=2034220578, CalledPartyName=, CalledParty=4050, OriginalCalledPartyName=, OriginalCalledParty=7100, lastRedirectingPartyName=, lastRedirectingParty=4005|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=2 reference=16795773 softKeySetIndex=1 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Connected' lineInstance=2 callReference=16795773 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
RQNT 16627 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
X: 1
S:
03/05/2002 12:12:01.096 Cisco CallManager|StationD: 725eb64 StartMediaTransmission conferenceID=0 passThruPartyID=97073 remoteIpAddress=132400a(10.64.50.1) remotePortNumber=24222 milliSecondPacketSize=20 compressType=4(Media_Payload_G711Ulaw64k) qualifierOut=?. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
200 16627
03/05/2002 12:12:01.096 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16627|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:01.096 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16627 FOUND a match for RQNT|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:01.096 Cisco CallManager|MGCPHandler recv RQNT Ack from 10.64.50.1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:01.096 Cisco CallManager|StationInit: 725eb64 OpenReceiveChannelAck Status=0, IpAddr=0xd232400a, Port=23798, PartyID=97073|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.096 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
MDCX 16628 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
I: 1
X: 1
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 1 0 IN EPN S0/DS1-0/1@SDA00908F003733
s=Cisco SDP 0
t=0 0
c=IN IP4 10.64.50.210
m=audio 23798 RTP/AVP 96
a=rtpmap:96 PCMU
03/05/2002 12:12:01.111 Cisco CallManager|Locations: adjust: cdcc=9147 readjusting ciA=16795735 ciB=16795773 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:01.111 Cisco CallManager|Locations_adjustBandwidth -- cdccPID=(1.15.9147) Orig=Dest=0 no entry for cdcc. No need to adjust.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:01.111 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16628
03/05/2002 12:12:01.111 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16628|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:01.111 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:01.111 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16628 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:01.721 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C675FF, TCPHandle=0x725e5ec, Socket=0x1140, IPAddr=10.64.50.20, Port=51252, Device Controller=[1,92,488]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.20><:SEP000750C675FF>
03/05/2002 12:12:01.721 Cisco CallManager|StationInit: 725e5ec KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.20><:SEP000750C675FF>
03/05/2002 12:12:01.721 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000628F0F587, TCPHandle=0xc2d7a18, Socket=0x1064, IPAddr=10.64.51.6, Port=52085, Device Controller=[1,92,250]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.6><:SEP000628F0F587>
03/05/2002 12:12:01.721 Cisco CallManager|StationInit: c2d7a18 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.6><:SEP000628F0F587>
03/05/2002 12:12:01.814 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007850571FA, TCPHandle=0xc2d7180, Socket=0x774, IPAddr=10.64.50.78, Port=51147, Device Controller=[1,92,463]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.78><:SEP0007850571FA>
03/05/2002 12:12:01.814 Cisco CallManager|StationInit: c2d7180 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.78><:SEP0007850571FA>
03/05/2002 12:12:01.971 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A0AF, TCPHandle=0xc2d7ae0, Socket=0xe48, IPAddr=10.64.50.72, Port=50788, Device Controller=[1,92,479]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.72><:SEP00078546A0AF>
03/05/2002 12:12:01.971 Cisco CallManager|StationInit: c2d7ae0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.72><:SEP00078546A0AF>
03/05/2002 12:12:02.033 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785993423, TCPHandle=0x927d6b0, Socket=0x8ac, IPAddr=10.64.50.227, Port=52147, Device Controller=[1,92,119]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.227><:SEP000785993423>
03/05/2002 12:12:02.033 Cisco CallManager|StationInit: 927d6b0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.227><:SEP000785993423>
03/05/2002 12:12:02.174 Cisco CallManager| |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.174 Cisco CallManager|In Message -- H225ConnectMsg -- Protocol= H225Protocol|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.174 Cisco CallManager|Ie - H225BearerCapabilityIe -- IEData= 04 03 80 90 A3 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.174 Cisco CallManager|Ie - H225UserUserIe -- IEData= 7E 00 55 05 22 C0 06 00 08 91 4A 00 02 00 0A 40 0F 6F 77 D8 08 80 01 3C 05 01 00 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 09 00 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 06 A0 01 00 13 01 40 B5 00 00 12 0C C0 01 00 02 80 06 00 04 00 00 00 08 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.174 Cisco CallManager|MMan_Id= 0. (iep= 0 dsl= 0 sapi= 0 ces= 0 IpAddr=6f0f400a IpPort=1720)|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.174 Cisco CallManager|IsdnMsgData1= 08 02 86 5A 07 04 03 80 90 A3 7E 00 55 05 22 C0 06 00 08 91 4A 00 02 00 0A 40 0F 6F 77 D8 08 80 01 3C 05 01 00 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 09 00 11 00 00 D0 C8 3A 78 4E 71 1D 5A 06 8C CE 0A 40 32 12 06 A0 01 00 13 01 40 B5 00 00 12 0C C0 01 00 02 80 06 00 04 00 00 00 08 |<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.174 Cisco CallManager|CTI: RoutePatternToCtiCommandData::findValue() : RP=7302:, bRc=0, T=, #entries=0|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.174 Cisco CallManager|StationD: c2d6f28 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:12:02.174 Cisco CallManager|StationD: c2d6f28 CallState callState=5 lineInstance=1 callReference=16795762|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:12:02.174 Cisco CallManager|StationD: c2d6f28 CallInfo callingPartyName='Tracy Quinten' callingParty=7302 cgpnVoiceMailbox= calledPartyName='' calledParty=16198432987 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty= originalCdpnVoiceMailbox= originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty=16198432987 lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=2(OutBound) lineInstance=1 callReference=16795762. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:12:02.174 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795762, CallingPartyName=Tracy Quinten, CallingParty=7302, CalledPartyName=, CalledParty=16198432987, OriginalCalledPartyName=, OriginalCalledParty=, lastRedirectingPartyName=, lastRedirectingParty=16198432987|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:12:02.189 Cisco CallManager|StationD: c2d6f28 SelectSoftKeys instance=1 reference=16795762 softKeySetIndex=1 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:12:02.189 Cisco CallManager|StationD: c2d6f28 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Connected' lineInstance=1 callReference=16795762 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.111><:>
03/05/2002 12:12:02.314 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785056AB5, TCPHandle=0x7295078, Socket=0xda4, IPAddr=10.64.50.3, Port=50594, Device Controller=[1,92,358]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.3><:SEP000785056AB5>
03/05/2002 12:12:02.314 Cisco CallManager|StationInit: 7295078 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.3><:SEP000785056AB5>
03/05/2002 12:12:02.377 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC47A, TCPHandle=0x72952d0, Socket=0x1158, IPAddr=10.64.50.49, Port=50467, Device Controller=[1,92,364]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.49><:SEP0007EB7CC47A>
03/05/2002 12:12:02.377 Cisco CallManager|StationInit: 72952d0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.49><:SEP0007EB7CC47A>
03/05/2002 12:12:02.393 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C67820, TCPHandle=0xc2d6ec4, Socket=0x109c, IPAddr=10.64.50.246, Port=49473, Device Controller=[1,92,457]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.246><:SEP000750C67820>
03/05/2002 12:12:02.393 Cisco CallManager|StationInit: c2d6ec4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.246><:SEP000750C67820>
03/05/2002 12:12:02.408 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785057131, TCPHandle=0x927d2c8, Socket=0x1114, IPAddr=10.64.50.250, Port=52438, Device Controller=[1,92,311]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.250><:SEP000785057131>
03/05/2002 12:12:02.408 Cisco CallManager|StationInit: 927d2c8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.250><:SEP000785057131>
03/05/2002 12:12:02.408 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C6773B, TCPHandle=0x7294cf4, Socket=0xb98, IPAddr=10.64.50.117, Port=50416, Device Controller=[1,92,350]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.117><:SEP000750C6773B>
03/05/2002 12:12:02.408 Cisco CallManager|StationInit: 7294cf4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.117><:SEP000750C6773B>
03/05/2002 12:12:02.455 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC40B, TCPHandle=0x927cf44, Socket=0xe00, IPAddr=10.64.50.166, Port=52414, Device Controller=[1,92,305]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.166><:SEP0007EB7CC40B>
03/05/2002 12:12:02.455 Cisco CallManager|StationInit: 927cf44 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.166><:SEP0007EB7CC40B>
03/05/2002 12:12:02.502 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB594738, TCPHandle=0x927cc88, Socket=0xe6c, IPAddr=10.64.50.175, Port=52352, Device Controller=[1,92,301]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.175><:SEP0007EB594738>
03/05/2002 12:12:02.502 Cisco CallManager|StationInit: 927cc88 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.175><:SEP0007EB594738>
03/05/2002 12:12:02.596 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644CBB, TCPHandle=0x725e1a0, Socket=0xc34, IPAddr=10.64.50.159, Port=51886, Device Controller=[1,92,481]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.159><:SEP0007EB644CBB>
03/05/2002 12:12:02.596 Cisco CallManager|StationInit: 725e1a0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.159><:SEP0007EB644CBB>
03/05/2002 12:12:02.643 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785057211, TCPHandle=0x7295654, Socket=0x1120, IPAddr=10.64.50.54, Port=50220, Device Controller=[1,92,372]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.54><:SEP000785057211>
03/05/2002 12:12:02.643 Cisco CallManager|StationInit: 7295654 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.54><:SEP000785057211>
03/05/2002 12:12:02.815 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.815 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:02.877 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C672FF, TCPHandle=0x725e3f8, Socket=0xde0, IPAddr=10.64.50.51, Port=50588, Device Controller=[1,92,486]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.51><:SEP000750C672FF>
03/05/2002 12:12:02.877 Cisco CallManager|StationInit: 725e3f8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.51><:SEP000750C672FF>
03/05/2002 12:12:02.924 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=VGC0653d6b3d703, TCPHandle=0x725ecf4, Socket=0x11b8, IPAddr=10.64.15.130, Port=20966, Device Controller=[1,92,276]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D703>
03/05/2002 12:12:02.924 Cisco CallManager|StationInit: 725ecf4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D703>
03/05/2002 12:12:02.940 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A1EB, TCPHandle=0x3b0c6d0, Socket=0xd70, IPAddr=10.64.51.1, Port=51368, Device Controller=[1,92,389]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.1><:SEP00078546A1EB>
03/05/2002 12:12:02.940 Cisco CallManager|StationInit: 3b0c6d0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.1><:SEP00078546A1EB>
03/05/2002 12:12:02.971 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC405, TCPHandle=0x72959d8, Socket=0xca8, IPAddr=10.64.50.98, Port=50920, Device Controller=[1,92,381]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.98><:SEP0007EB7CC405>
03/05/2002 12:12:02.971 Cisco CallManager|StationInit: 72959d8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.98><:SEP0007EB7CC405>
03/05/2002 12:12:03.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC406, TCPHandle=0xc2d78ec, Socket=0xcd8, IPAddr=10.64.50.122, Port=50661, Device Controller=[1,92,477]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.122><:SEP0007EB7CC406>
03/05/2002 12:12:03.002 Cisco CallManager|StationInit: c2d78ec KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.122><:SEP0007EB7CC406>
03/05/2002 12:12:03.080 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC478, TCPHandle=0x3b0c98c, Socket=0x9b8, IPAddr=10.64.50.223, Port=51324, Device Controller=[1,92,394]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.223><:SEP0007EB7CC478>
03/05/2002 12:12:03.080 Cisco CallManager|StationInit: 3b0c98c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.223><:SEP0007EB7CC478>
03/05/2002 12:12:03.205 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC4A2, TCPHandle=0x72958ac, Socket=0xe50, IPAddr=10.64.50.125, Port=50845, Device Controller=[1,92,378]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.125><:SEP0007EB7CC4A2>
03/05/2002 12:12:03.205 Cisco CallManager|StationInit: 72958ac KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.125><:SEP0007EB7CC4A2>
03/05/2002 12:12:03.315 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC43A, TCPHandle=0x927cd50, Socket=0xeec, IPAddr=10.64.50.102, Port=52732, Device Controller=[1,92,303]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.102><:SEP0007EB7CC43A>
03/05/2002 12:12:03.315 Cisco CallManager|StationInit: 927cd50 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.102><:SEP0007EB7CC43A>
03/05/2002 12:12:03.315 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC43B, TCPHandle=0x7295780, Socket=0xbc4, IPAddr=10.64.50.238, Port=51166, Device Controller=[1,92,375]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.238><:SEP0007EB7CC43B>
03/05/2002 12:12:03.315 Cisco CallManager|StationInit: 7295780 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.238><:SEP0007EB7CC43B>
03/05/2002 12:12:03.690 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750786E60, TCPHandle=0x927c774, Socket=0x6a8, IPAddr=10.64.50.81, Port=52851, Device Controller=[1,92,274]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.81><:SEP000750786E60>
03/05/2002 12:12:03.690 Cisco CallManager|StationInit: 927c774 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.81><:SEP000750786E60>
03/05/2002 12:12:03.736 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644DA6, TCPHandle=0x725e8a8, Socket=0xc0c, IPAddr=10.64.50.83, Port=52226, Device Controller=[1,92,493]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.83><:SEP0007EB644DA6>
03/05/2002 12:12:03.736 Cisco CallManager|StationInit: 725e8a8 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.83><:SEP0007EB644DA6>
03/05/2002 12:12:03.799 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644810, TCPHandle=0x725e7e0, Socket=0x8c4, IPAddr=10.64.50.12, Port=51338, Device Controller=[1,92,491]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.12><:SEP0007EB644810>
03/05/2002 12:12:03.799 Cisco CallManager|StationInit: 725e7e0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.12><:SEP0007EB644810>
03/05/2002 12:12:04.065 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C676A6, TCPHandle=0x927ca30, Socket=0xf04, IPAddr=10.64.50.185, Port=52428, Device Controller=[1,92,296]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.185><:SEP000750C676A6>
03/05/2002 12:12:04.065 Cisco CallManager|StationInit: 927ca30 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.185><:SEP000750C676A6>
03/05/2002 12:12:04.096 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC48E, TCPHandle=0x725e2cc, Socket=0xec4, IPAddr=10.64.50.134, Port=53042, Device Controller=[1,92,484]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.134><:SEP0007EB7CC48E>
03/05/2002 12:12:04.096 Cisco CallManager|StationInit: 725e2cc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.134><:SEP0007EB7CC48E>
03/05/2002 12:12:04.127 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC473, TCPHandle=0x72954c4, Socket=0xfdc, IPAddr=10.64.50.118, Port=50536, Device Controller=[1,92,368]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.118><:SEP0007EB7CC473>
03/05/2002 12:12:04.127 Cisco CallManager|StationInit: 72954c4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.118><:SEP0007EB7CC473>
03/05/2002 12:12:04.330 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB4632D5, TCPHandle=0x725ea38, Socket=0x958, IPAddr=10.64.50.216, Port=51783, Device Controller=[1,92,494]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.216><:SEP0007EB4632D5>
03/05/2002 12:12:04.330 Cisco CallManager|StationInit: 725ea38 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.216><:SEP0007EB4632D5>
03/05/2002 12:12:04.533 Cisco CallManager|MGCPManager remove recent Incoming transId 16064|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:04.643 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000750C6760A, TCPHandle=0x7295460, Socket=0xd90, IPAddr=10.64.50.254, Port=50950, Device Controller=[1,92,367]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.254><:SEP000750C6760A>
03/05/2002 12:12:04.643 Cisco CallManager|StationInit: 7295460 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.254><:SEP000750C6760A>
03/05/2002 12:12:04.783 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI1, TCPHandle=0x725ef4c, Socket=0x11f8, IPAddr=10.64.5.21, Port=2421, Device Controller=[1,92,237]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI1>
03/05/2002 12:12:04.783 Cisco CallManager|StationInit: 725ef4c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI1>
03/05/2002 12:12:04.815 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:04.815 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:04.846 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI2, TCPHandle=0x3b0c66c, Socket=0xc8c, IPAddr=10.64.5.21, Port=2422, Device Controller=[1,92,239]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:12:04.846 Cisco CallManager|StationInit: 3b0c66c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI2>
03/05/2002 12:12:04.861 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI3, TCPHandle=0x3b0c860, Socket=0xcb4, IPAddr=10.64.5.21, Port=2450, Device Controller=[1,92,284]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI3>
03/05/2002 12:12:04.861 Cisco CallManager|StationInit: 3b0c860 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI3>
03/05/2002 12:12:04.893 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI4, TCPHandle=0x3b0c928, Socket=0xcc4, IPAddr=10.64.5.21, Port=2424, Device Controller=[1,92,238]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:12:04.893 Cisco CallManager|StationInit: 3b0c928 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI4>
03/05/2002 12:12:04.908 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007850569B7, TCPHandle=0xc2d72ac, Socket=0x124c, IPAddr=10.64.51.13, Port=52325, Device Controller=[1,92,512]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.13><:SEP0007850569B7>
03/05/2002 12:12:04.908 Cisco CallManager|StationInit: c2d72ac KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.51.13><:SEP0007850569B7>
03/05/2002 12:12:04.908 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI5, TCPHandle=0x3b0c9f0, Socket=0xce0, IPAddr=10.64.5.21, Port=2425, Device Controller=[1,92,227]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI5>
03/05/2002 12:12:04.908 Cisco CallManager|StationInit: 3b0c9f0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI5>
03/05/2002 12:12:04.924 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B88C, TCPHandle=0x927c8a0, Socket=0x125c, IPAddr=10.64.50.133, Port=52288, Device Controller=[1,92,294]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.133><:SEP0007EB39B88C>
03/05/2002 12:12:04.924 Cisco CallManager|StationInit: 927c8a0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.133><:SEP0007EB39B88C>
03/05/2002 12:12:04.940 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI6, TCPHandle=0x3b0cb1c, Socket=0xd08, IPAddr=10.64.5.21, Port=2426, Device Controller=[1,92,236]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:12:04.940 Cisco CallManager|StationInit: 3b0cb1c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI6>
03/05/2002 12:12:04.940 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007505A4737, TCPHandle=0x725e9d4, Socket=0x1138, IPAddr=10.64.50.189, Port=51379, Device Controller=[1,92,163]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.189><:SEP0007505A4737>
03/05/2002 12:12:04.940 Cisco CallManager|StationInit: 725e9d4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.189><:SEP0007505A4737>
03/05/2002 12:12:04.971 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI7, TCPHandle=0x3b0cc48, Socket=0xd0c, IPAddr=10.64.5.21, Port=2427, Device Controller=[1,92,235]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI7>
03/05/2002 12:12:04.971 Cisco CallManager|StationInit: 3b0cc48 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI7>
03/05/2002 12:12:05.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI8, TCPHandle=0x3b0cd74, Socket=0xd1c, IPAddr=10.64.5.21, Port=2428, Device Controller=[1,92,228]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI8>
03/05/2002 12:12:05.002 Cisco CallManager|StationInit: 3b0cd74 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI8>
03/05/2002 12:12:05.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC42E, TCPHandle=0x725e844, Socket=0x1038, IPAddr=10.64.50.196, Port=52207, Device Controller=[1,92,492]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.196><:SEP0007EB7CC42E>
03/05/2002 12:12:05.002 Cisco CallManager|StationInit: 725e844 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.196><:SEP0007EB7CC42E>
03/05/2002 12:12:05.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078546A1AE, TCPHandle=0x7295a3c, Socket=0xebc, IPAddr=10.64.50.7, Port=51218, Device Controller=[1,92,382]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.7><:SEP00078546A1AE>
03/05/2002 12:12:05.002 Cisco CallManager|StationInit: 7295a3c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.7><:SEP00078546A1AE>
03/05/2002 12:12:05.018 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI9, TCPHandle=0x725efb0, Socket=0x1200, IPAddr=10.64.5.21, Port=2429, Device Controller=[1,92,233]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI9>
03/05/2002 12:12:05.018 Cisco CallManager|StationInit: 725efb0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI9>
03/05/2002 12:12:05.080 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI10, TCPHandle=0x3b0ce3c, Socket=0xd64, IPAddr=10.64.5.21, Port=2431, Device Controller=[1,92,234]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI10>
03/05/2002 12:12:05.080 Cisco CallManager|StationInit: 3b0ce3c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI10>
03/05/2002 12:12:05.111 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI11, TCPHandle=0x3b0d094, Socket=0xd9c, IPAddr=10.64.5.21, Port=2432, Device Controller=[1,92,229]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI11>
03/05/2002 12:12:05.111 Cisco CallManager|StationInit: 3b0d094 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI11>
03/05/2002 12:12:05.127 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI12, TCPHandle=0x3b0d350, Socket=0xdb4, IPAddr=10.64.5.21, Port=2433, Device Controller=[1,92,232]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI12>
03/05/2002 12:12:05.127 Cisco CallManager|StationInit: 3b0d350 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI12>
03/05/2002 12:12:05.158 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI13, TCPHandle=0x725f014, Socket=0x121c, IPAddr=10.64.5.21, Port=2464, Device Controller=[1,92,285]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI13>
03/05/2002 12:12:05.158 Cisco CallManager|StationInit: 725f014 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI13>
03/05/2002 12:12:05.174 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI14, TCPHandle=0x725f078, Socket=0x1228, IPAddr=10.64.5.21, Port=2465, Device Controller=[1,92,286]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI14>
03/05/2002 12:12:05.174 Cisco CallManager|StationInit: 725f078 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI14>
03/05/2002 12:12:05.205 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI15, TCPHandle=0x3b0d47c, Socket=0xd34, IPAddr=10.64.5.21, Port=2434, Device Controller=[1,92,231]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI15>
03/05/2002 12:12:05.205 Cisco CallManager|StationInit: 3b0d47c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI15>
03/05/2002 12:12:05.236 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=CiscoUM1-VI16, TCPHandle=0x3b0d60c, Socket=0xe98, IPAddr=10.64.5.21, Port=2435, Device Controller=[1,92,230]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:12:05.236 Cisco CallManager|StationInit: 3b0d60c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.5.21><:CISCOUM1-VI16>
03/05/2002 12:12:05.736 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=VGC0653d6b3d707, TCPHandle=0x725ed58, Socket=0x11bc, IPAddr=10.64.15.130, Port=20968, Device Controller=[1,92,281]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D707>
03/05/2002 12:12:05.736 Cisco CallManager|StationInit: 725ed58 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.130><:VGC0653D6B3D707>
03/05/2002 12:12:06.002 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB46224A, TCPHandle=0x3b0d3b4, Socket=0xf34, IPAddr=10.64.50.64, Port=51988, Device Controller=[1,92,410]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.64><:SEP0007EB46224A>
03/05/2002 12:12:06.002 Cisco CallManager|StationInit: 3b0d3b4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.64><:SEP0007EB46224A>
03/05/2002 12:12:06.065 Cisco CallManager|StationInit: 725eb64 SoftKeyEvent softKeyEvent=3 lineInstance=2 callReference=16795773.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795735,16795773): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|ConnectionManager - storeMediaInfo(16795735): EXISTING ENTRY DISCOVERED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|ConnectionManager - storeMediaInfo(16795773): EXISTING ENTRY DISCOVERED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6619)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6619)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 CloseReceiveChannel conferenceID=0 passThruPartyID=97073. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 StopMediaTransmission conferenceID=0 passThruPartyID=97073. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.065 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16629 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
I: 1
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:06.065 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16629
03/05/2002 12:12:06.065 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16629|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:06.065 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16629 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795735) and party2(16795773)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6619) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795735,16795773): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:4050><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceReq - MRGL=0,CREATED CHILD USING DEFAULT LIST|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-2 Group=0 Counter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::sortDeviceGivenList Name=MOH_API-CM-1 Group=0 Counter=1|<:API-CM-1-CLUSTER><:10.64.5.11><:0><:><:>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc - Started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::findDeviceGivenList|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::waiting_MrmAllocateMohResourceReq MtpDevice=MOH_API-CM-2|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 DefineTimeDate timeDateInfo=? systemTime=1015359126.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 CallState callState=8 lineInstance=2 callReference=16795773|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=2 reference=16795773 softKeySetIndex=2 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Hold' lineInstance=2 callReference=16795773 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|CTI: RoutePatternToCtiCallOrigin::store() : RP=4050:, bRc=1, CallOrigin=5, T=restart0_DStopInd(), #entries=3|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 SetSpeakerMode speakermode=2(Off).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|StationD: 725eb64 SetLamp stimulus=9(Line) stimulusInstance=2 lampMode=3(LampWink).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::device_lookup_DevicePidRes MohResource=MOH_API-CM-2|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|Locations_reserveBandwidthForMediaResource -- cdccPID=(1.15.9147) UserParty=Media Source=0 no need to reserve bw.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:06.065 Cisco CallManager|MohDControl - AllocateMohResourceReq successfully - AudioSourceID and MuticastFlag = 1, 0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceCdpc::resource_rsvp_AllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.065 Cisco CallManager|MediaResourceManager::waiting_MrmAllocateMohResourceRes|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MRM::updateMohCounter MOH_API-CM-2|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MRM::updateMohCounter allocateCounter=1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaResourceManager::waiting_MrmChildStopInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaResourceCdpc::shutting_down_MrmChildStopConf|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795735,16795775): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|ConnectionManager - storeMediaInfo(16795735): EXISTING ENTRY DISCOVERED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|ConnectionManager - storeMediaInfo(16795775): ADD NEW ENTRY, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6620) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaManager(6620) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:06.080 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795735) and party2(16795775)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795735,16795775)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0006D74B13DD, TCPHandle=0xc2d630c, Socket=0xe80, IPAddr=10.64.50.138, Port=52881, Device Controller=[1,92,146]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.138><:SEP0006D74B13DD>
03/05/2002 12:12:06.080 Cisco CallManager|StationInit: c2d630c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.138><:SEP0006D74B13DD>
03/05/2002 12:12:06.080 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16630 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
I: 1
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:06.080 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16630
03/05/2002 12:12:06.080 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16630|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:06.080 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16630 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
MDCX 16631 S0/DS1-0/1@SDA00908F003733 MGCP 0.1
I: 1
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
v=0
s=Cisco SDP 0
t=0 0
c=IN IP4 0.0.0.0
a=rtpmap:96 PCMU
03/05/2002 12:12:06.080 Cisco CallManager|MohDControl - stationOutputStartMediaTransmission tcpHandle=7294650 myIP: c05400a (10.64.5.12)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|MohDControl - RemoteIpAddr: 132400a (10.64.50.1) RemoteRtpPortNumber: 24222 msecPacketSize: 20 compressionType: 4|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
200 16631
03/05/2002 12:12:06.080 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16631|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:06.080 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16631 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.080 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CB17E, TCPHandle=0x927cb5c, Socket=0xecc, IPAddr=10.64.50.85, Port=52214, Device Controller=[1,92,298]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.85><:SEP0007EB7CB17E>
03/05/2002 12:12:06.080 Cisco CallManager|StationInit: 927cb5c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.85><:SEP0007EB7CB17E>
03/05/2002 12:12:06.111 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB644BF7, TCPHandle=0x3b0c5a4, Socket=0x970, IPAddr=10.64.50.103, Port=51231, Device Controller=[1,92,387]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.103><:SEP0007EB644BF7>
03/05/2002 12:12:06.111 Cisco CallManager|StationInit: 3b0c5a4 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.103><:SEP0007EB644BF7>
03/05/2002 12:12:06.174 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785056D69, TCPHandle=0x725e77c, Socket=0x950, IPAddr=10.64.50.110, Port=51173, Device Controller=[1,92,490]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.110><:SEP000785056D69>
03/05/2002 12:12:06.174 Cisco CallManager|StationInit: 725e77c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.110><:SEP000785056D69>
03/05/2002 12:12:06.174 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP000785057209, TCPHandle=0x927cbc0, Socket=0x908, IPAddr=10.64.50.39, Port=52466, Device Controller=[1,92,299]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.39><:SEP000785057209>
03/05/2002 12:12:06.174 Cisco CallManager|StationInit: 927cbc0 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.39><:SEP000785057209>
03/05/2002 12:12:06.190 Cisco CallManager|MGCPManager remove recent Incoming transId 16065|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:06.330 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007505A46C9, TCPHandle=0x7294b64, Socket=0xadc, IPAddr=10.64.50.89, Port=53151, Device Controller=[1,92,116]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.89><:SEP0007505A46C9>
03/05/2002 12:12:06.330 Cisco CallManager|StationInit: 7294b64 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.89><:SEP0007505A46C9>
03/05/2002 12:12:06.393 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC494, TCPHandle=0x3b0c4dc, Socket=0x8f8, IPAddr=10.64.50.32, Port=50998, Device Controller=[1,92,386]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.32><:SEP0007EB7CC494>
03/05/2002 12:12:06.393 Cisco CallManager|StationInit: 3b0c4dc KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.32><:SEP0007EB7CC494>
03/05/2002 12:12:06.455 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP00078599380D, TCPHandle=0x3b0c540, Socket=0xc6c, IPAddr=10.64.50.225, Port=51710, Device Controller=[1,92,95]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.225><:SEP00078599380D>
03/05/2002 12:12:06.455 Cisco CallManager|StationInit: 3b0c540 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.225><:SEP00078599380D>
03/05/2002 12:12:06.471 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB594E34, TCPHandle=0xc2d6f8c, Socket=0x1284, IPAddr=10.64.50.240, Port=51407, Device Controller=[1,92,510]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.240><:SEP0007EB594E34>
03/05/2002 12:12:06.471 Cisco CallManager|StationInit: c2d6f8c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.240><:SEP0007EB594E34>
03/05/2002 12:12:06.580 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB39B886, TCPHandle=0x7295910, Socket=0xd58, IPAddr=10.64.50.70, Port=51048, Device Controller=[1,92,379]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.70><:SEP0007EB39B886>
03/05/2002 12:12:06.580 Cisco CallManager|StationInit: 7295910 KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.70><:SEP0007EB39B886>
03/05/2002 12:12:06.596 Cisco CallManager|MGCPManager remove recent Incoming transId 227948|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.128><:>
03/05/2002 12:12:06.596 Cisco CallManager|MGCPHandler received msg from: 10.64.15.128
NTFY 227950 *@API-VG200LOAN-1-TCD MGCP 0.1
X: 0
O:
03/05/2002 12:12:06.596 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:><:>
03/05/2002 12:12:06.596 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.15.128
200 227950
03/05/2002 12:12:06.611 Cisco CallManager|StationInit: 725eb64 Stimulus stimulus=9(Line) stimulusInstance=1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7100><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|StationD - StimLine: hold cases|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|StationInit: 725eb64 OffHook.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|StationD: 725eb64 SetSpeakerMode speakermode=1(On).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=1 reference=16795768 softKeySetIndex=8 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(16795739,16795774): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - storeMediaInfo(16795774): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(6618)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|MediaManager - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|MediaManager - wait_AuDisconnectRequest - no proxy and StopStreaming send disconnect to (74,6618)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|MohDControl - stationOutputStopMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.627 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16632 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
C: D00000000100485b00000000800014bf
I: 4
X: 4
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:06.627 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16632
03/05/2002 12:12:06.627 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16632|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:06.627 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16632 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaManager - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaManager - wait_AuDisconnectReply - received all disconnect replies, forwarding a reply for party1(16795739) and party2(16795774)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuDisconnectReply - removing MediaManager(6618) from connection list|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(16795739,16795774): STOP STREAMING|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaResourceManager::waiting_MrmDeallocateMohResourceReq|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MRM::waiting_MrmDeallocateMohResourceReq- Deallocate received for MRM TransactionId= 16795774|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MRM::updateMohCounter MOH_API-CM-1|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MRM::updateMohCounter allocateCounter=0|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - wait_AuDisconnectRequest(0,16795774): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - storeMediaInfo(0): NULL CI IGNORED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - storeMediaInfo(16795774): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|Locations_releaseBandwidthForMediaResource -- cdccPID=(1.15.9149) no entry For MediaResource|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest - no parties found|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuDisconnectRequest, extending disconnect to partyA interface instance(6066)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MohDControl - stationOutputStopMediaTransmission tcpHandle=729477c myIP: b05400a (10.64.5.11)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - wait_AuConnectRequest(16795739,16795768): INFORM MEDIA LAYER|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - storeMediaInfo(16795739): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - storeMediaInfo(16795768): EXISTING ENTRY DISCOVERED, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - wait_AuDisconnectReply(0,16795774): STOP SESSION|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - ERROR deleteMediaInfoEntry(0): ENTRY NOT FOUND, tail == 22|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|ConnectionManager - deleteMediaInfoEntry(16795774): ENTRY DELETED, tail == 21|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.627 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest()|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - starting MediaManager w/ existing (0) connections|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MediaCoordinator - wait_AuConnectRequest - new MediaManager(43,6621) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MediaManager(6621) started|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:><:>
03/05/2002 12:12:06.643 Cisco CallManager|MediaManager - wait_AuConnectRequest|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MediaManager - wait_AuConnectRequest - normal connection|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MediaManager - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MediaManager - wait_AuConnectReply - received 1 responses, fowarding reply for party1(16795739) and party2(16795768)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MediaCoordinator - wait_AuConnectReply|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|ConnectionManager - wait_AuConnectReply(16795739,16795768)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 StopTone.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 OpenReceiveChannel conferenceID=0 passThruPartyID=97026 millisecondPacketSize=20 compressionType=4(Media_Payload_G711Ulaw64k) qualifierIn=?. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16633 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
L: p:20, a:PCMU, s:off
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
03/05/2002 12:12:06.643 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:DIRECTORY number=""><:7100><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16633
03/05/2002 12:12:06.643 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16633|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:06.643 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16633 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 SetLamp stimulus=9(Line) stimulusInstance=1 lampMode=2(LampOn).|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 CallState callState=5 lineInstance=1 callReference=16795768|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 DisplayPromptStatus timeOutValue=0 promptStatus='€' content='Connected' lineInstance=1 callReference=16795768 ver=3.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 CallInfo callingPartyName='' callingParty= cgpnVoiceMailbox= calledPartyName='' calledParty=7100 cdpnVoiceMailbox= originalCalledPartyName='' originalCalledParty= originalCdpnVoiceMailbox= originalCdpnRedirectReason=0 lastRedirectingPartyName='' lastRedirectingParty= lastRedirectingVoiceMailbox= lastRedirectingReason=0 callType=1(InBound) lineInstance=1 callReference=16795768. version: 3|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD::star_StationOutputCallInfo(): callInfo: CI=16795768, CallingPartyName=, CallingParty=, CalledPartyName=, CalledParty=7100, OriginalCalledPartyName=, OriginalCalledParty=, lastRedirectingPartyName=, lastRedirectingParty=|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 SelectSoftKeys instance=1 reference=16795768 softKeySetIndex=1 validKeyMask=-1.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.643 Cisco CallManager|StationD: 725eb64 StartMediaTransmission conferenceID=0 passThruPartyID=97026 remoteIpAddress=132400a(10.64.50.1) remotePortNumber=24224 milliSecondPacketSize=20 compressType=4(Media_Payload_G711Ulaw64k) qualifierOut=?. myIP: d232400a (10.64.50.210)|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.658 Cisco CallManager|StationInit: 725eb64 OpenReceiveChannelAck Status=0, IpAddr=0xd232400a, Port=24350, PartyID=97026|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.658 Cisco CallManager|MediaManager - wait_AuConnectInfo|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.658 Cisco CallManager|MediaManager - wait_AuConnectInfo - recieved response, fowarding|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.658 Cisco CallManager|MediaCoordinator - wait_AuConnectInfoInd|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.658 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.50.1
MDCX 16634 S0/DS1-0/4@SDA00908F003733 MGCP 0.1
I: 4
X: 4
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 4 0 IN EPN S0/DS1-0/4@SDA00908F003733
s=Cisco SDP 0
t=0 0
m=audio 24350 RTP/AVP 96
a=rtpmap:96 PCMU
03/05/2002 12:12:06.658 Cisco CallManager|Locations: adjust: cdcc=9149 readjusting ciA=16795739 ciB=16795768 |<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.210><:SEP0006D708FF66>
03/05/2002 12:12:06.658 Cisco CallManager|Locations_adjustBandwidth -- cdccPID=(1.15.9149) Orig=Dest=0 no entry for cdcc. No need to adjust.|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:06.658 Cisco CallManager|MGCPHandler received msg from: 10.64.50.1
200 16634
03/05/2002 12:12:06.658 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16634|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:>
03/05/2002 12:12:06.658 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:S0><:S0>
03/05/2002 12:12:06.658 Cisco CallManager|MGCPHandler received RESP header w/ transId= 16634 FOUND a match for MDCX|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.1><:S0>
03/05/2002 12:12:06.658 Cisco CallManager|MGCPManager remove recent Incoming transId 285879|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.15.129><:>
03/05/2002 12:12:06.674 Cisco CallManager|MGCPHandler received msg from: 10.64.15.129
NTFY 285881 *@API-VG200LOAN-2-ED MGCP 0.1
X: 0
O:
03/05/2002 12:12:06.674 Cisco CallManager|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:MGCPENDPOINT><:><:>
03/05/2002 12:12:06.674 Cisco CallManager|MGCPHandler send msg SUCCESSFULLY to: 10.64.15.129
200 285881
03/05/2002 12:12:06.815 Cisco CallManager|CMProcMon - ------Entered Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:06.815 Cisco CallManager|CMProcMon - ----Exited Router Verification|<:API-CM-1-CLUSTER><:10.64.5.11>
03/05/2002 12:12:06.877 Cisco CallManager|StationInit - InboundStim - KeepAliveMessage - Send KeepAlive to Device Controller. DeviceName=SEP0007EB7CC448, TCPHandle=0x927d32c, Socket=0x8f0, IPAddr=10.64.50.68, Port=52568, Device Controller=[1,92,312]|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.68><:SEP0007EB7CC448>
03/05/2002 12:12:06.877 Cisco CallManager|StationInit: 927d32c KeepAliveAck.|<:API-CM-1-CLUSTER><:10.64.5.11><:1><:10.64.50.68><:SEP0007EB7CC448>
734
