Call forwarding
User A is out of the office on leave, and has her phone forwarded to User B. If User B does not pick up the phone, it will go into User's A voice mail. Is there a way to change this so that it goes into User B's voice mail box?
CM: 3.2(2c) sph
Unity 3.1(5)
Re: Call forwarding
Try the following. This will work but not an ideal solution.
Change the User's A voice mail DN (different from CM DN). This will accomplish what you are looking for.
You can change the voice mail DN back to the original DN when you need to remove the forward option.
Hope this helps.
Re: Call forwarding
This was my backup solution....I was hoping not to use this...Thanks!
CHRIS
94
