Hi, I'm making a call from 5300 . after the called offhook for 3 seconds, the call is released, below is the 5300 log . the log is only after the capacity negotiation successfully
*Jan 8 00:28:07.338: H.225 SM: changing from H225_WAIT_FOR_H245 state to H225_ACTIVE state for callID FB
*Jan 8 00:28:07.338: cch323_h225_setup_cfm_notify: status 269B
*Jan 8 00:28:07.338: cch323_h225_generic_setup_cfm_notify: status 269B
*Jan 8 00:28:07.338: ======= PI in cch323_h225_generic_setup_cfm_notify = 0
*Jan 8 00:28:07.338: cch323_rtp_open_notify:
*Jan 8 00:28:07.338: ****** cut through in BOTH direction *****
RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
*Jan 8 00:28:09.246: cch323_rtcp_timer: packet stats request failed, ignore req
uestRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRcch323_do_call_disconnect: gw_id=1, call
ID=251
*Jan 8 00:28:10.346: H.225 SM: process event H225_EVENT_RELEASE, for callID FB
*Jan 8 00:28:10.346: cch323_run_h225_sm: received event H225_EVENT_RELEASE whil
e at state H225_ACTIVE
don't know why .
The destination GW is CG6000,
if we make a call to another GW(another type),the call is successful.
