So you want to set up some kind of crude hunt group using call handlers? I suppose you could do that if you set up a chain of call handlers and you linked the 1 key on the Opening Greeting call handler to attempt transfer to the first one in the chain.
Each handler in the chain would need to be configured to try an extension (supervised transfer with 4 rings at least), set the greeting to be blank or have it say please hold while I try the next line or whatever and set the after greeting action to attempt transfer to the next call handler in the chain. This would effectively try a series of phones until someone answered or you got to the end of the chain.
Not real pretty and your call progress had better be pretty tight. Thisll burn a lot of ports if youre handling a bunch of calls as well. Be careful
Seems to me that a PBX hunt group would be a cleaner solution here if you could do it. Youd have options for first available or round robin hunting as well.
If thats not what you were gunning for, let me know
Jeff Lindborg
Unity Product Architect
Active Voice
jlindborg@activevoice.com
http://members.home.net/jlindborg
