Community Member
Call Handling on FXO on Cisco 2611
Hi I am using the following simple config on 2611 with VIC-2FXO
voice-port 1/1/0
input gain 14
timeouts wait-release 3
connection plar 101
caller-id enable
supervisory disconnect anytone
ring number 2
voice-port 1/1/1
input gain 14
dial-peer voice 2 pots
destination-pattern 101
port 1/1/1
prefix 2426920
When call comes in on voice-port 1/1/0 the dial-peer 2 is matched and call is forwarded to voice-port 1/1/1 (as configured). The port 1/1/1 comes up for couple of seconds but does not forward the call on the no. mentioned. Sometimes it does work, and most of the time it does not. Is it a hardware issue with the FXO card, or does it seem to be an IOS issue. I am using c2600-is-mz.121-5.T9.bin. Does this have some issues ??
Will appreciate some help on it .
Thanks - Athar
Re: Call Handling on FXO on Cisco 2611
What is connected to voice-port 1/1/1 ? if it is a phone, probably wont work, your phone should be connected to FXS port. Another option is use the "connection plar opx 101" this will enable the port 1/1/0 to hold the call until the pbx on 1/1/1 answers the call.
There is probably more info needed to help you with this senario.
Community Member
a direct line from Telephone exchange is connected to the port. If i put in a different FXO-M1 then it works OK, but with couple of FOX modules it gives this error. The port 1/1/1 goes up briefly, but does not dial out, and call is dropped. It looked to be a hardware issue, but when two modules had the same error then it put me in suspicions as if there is a config problem.
