Call History and Corporate Directory on 7960/40 phones
Hi, does anyone know how much call history is saved? I suspect the file wraps.
Also, is there a way to connect Corporate Directories between Callmanager Clusters? I have customers that would like to use the Corporate Directory to find phone numbers on another Cluster. I am thinking that I may need to use a LDAP connector. The two clusters are on the same private network and I do have Inter-cluster trunks for routing calls between the clusters. Also, one cluster is running 3.0(11) and the other is at 3.1(2c).
Tom.
Re: Call History and Corporate Directory on 7960/40 phones
If you make a service that will search all your LADP database that should fix your problem.
We found the answer to the number of call history records. Up to 32 records per call type. We found it by pressing the "i" button twice on the Directory screen. We looked everywhere else in the documentation on Callmanager.
237
