Call hold & transfer H450
I have a network with a 2811 router with an E1 card acting as a
gateway to
the PSTN, another router running CCME4 with some 7940s and a couple of
AudioCode
MP-124 VoIP-to-Analogue boxes providing a number of POTs phones.
Using H450 supplementary services, calls between the two MP-124s can be
put
on hold, transferred etc OK via the hookflash facility on the analogue
phone. However when I try and put on hold/transfer a call involving
endpoints on the Cisco boxes and phones on the MP-124s nothing happens
(the
analogue phone doesn't give out a secondary dial-tone and the exiting
call
continues uninterrupted).
"Debug h225 asn1" show that the routers do receive h450 events (sample
output below) when a hookflash event occurs on the analogue phones:
000596: Sep 21 12:18:58.875 UTC: H225.0 INCOMING ENCODE BUFFER::=
2680060008914A00048601001F01801100801A4736A506001F1B3DF243C0F93E9F0100010011
800C
010A280110D39200016701000100
000597: Sep 21 12:18:58.875 UTC:
000598: Sep 21 12:18:58.875 UTC: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body facility :
protocolIdentifier { 0 0 8 2250 0 4 }
reason transportedInformation : NULL
callIdentifier
guid '801A4736A506001F1B3DF243C0F93E9F'H
multipleCalls FALSE
maintainConnection FALSE
h4501SupplementaryService
'280110D3920001670100'H
h245Tunneling FALSE
000599: Sep 21 12:18:58.879 UTC: H450 INCOMING ENCODE BUFFER::=
000600: Sep 21 12:18:58.879 UTC:
000601: Sep 21 12:18:58.879 UTC: H450 INCOMING PDU ::=
I am sure that I got this working a while back by just including the
following:
voice service voip
supplementary-service h450.12
but alas I can not reproduce these earlier results now.
Any help much appreciated.
PS the CCME router is running 12.4(9)T1
and the E1 router 12.4(4)T1
Re: Call hold & transfer H450
Can you post what you have in the telephony-service configuration?
The allow connections is going to support hairpin routing for the calls not supported by H.450.2 transfer. To enable H.450.2 transfer you need to set the transfer-system full-consult in CME Telephony-service. The issue might also be because you don't have a transfer-pattern set. If you are trying to transfer to a number other than a CME endpoint you need this set.
Please rate any helpful posts
Fred
the Cisco VoIP phones can initiate transfer calls etc OK it is when I try and use the hookflash on the analogue phones that the H450 stuff doesn't function any longer.
Here is my CME telephony service section.
cheers
steve
telephony-service
fxo hook-flash
load 7960-7940 P0030702T023
max-ephones 64
max-dn 256
ip source-address 10.1.10.1 port 2000
calling-number local
service dnis overlay
timeouts interdigit 4
system message QinetiQ CCME Test
network-locale GB
date-format dd-mm-yy
max-conferences 12 gain -6
call-forward pattern ...
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000
web admin system name sjah password password
dn-webedit
transfer-pattern ...
secondary-dialtone 9
login timeout 10
after-hours day Thu 00:00 23:59
create cnf-files version-stamp 7960 Sep 22 2006 14:17:42
196
