Call id in use
Hi all,
This is a wierd error message that I am getting when connecting the call. Not all the calls but many of the calls are disconnecting with this error message. I could not understand the reason behind this nor could I understand the error.
Here is the output of debug isdn q931.
Dec 2 13:30:14: ISDN Se0:15: TX -> SETUP pd = 8 callref = 0x14C4
Dec 2 13:30:14: Sending Complete
Dec 2 13:30:14: Bearer Capability i = 0x8090A3
Dec 2 13:30:14: Channel ID i = 0xA9839F
Dec 2 13:30:14: Progress Ind i = 0x8183 - Origination address is non-IS
DN
Dec 2 13:30:14: Display i = 'cisco'
Dec 2 13:30:14: Calling Party Number i = 0x00, 0x80, '1111', Plan:Unkno
wn, Type:Unknown
Dec 2 13:30:14: Called Party Number i = 0x81, '0091407759160', Plan:ISD
N, Type:Unknown
Dec 2 13:30:14: ISDN Se0:15: RX <- CALL_PROC pd = 8 callref = 0x94C4
Dec 2 13:30:15: ISDN Se0:15: RX <- ALERTING pd = 8 callref = 0x94C4
Dec 2 13:30:15: Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may
have in-band info
Dec 2 13:30:24: ISDN Se0:15: RX <- CONNECT pd = 8 callref = 0x94C4
Dec 2 13:30:24: Channel ID i = 0xA9839F
Dec 2 13:30:24.572: %ISDN-6-CONNECT: Interface Serial0:30 is now connected to 0
091407759160
Dec 2 13:30:24: ISDN Se0:15: TX -> CONNECT_ACK pd = 8 callref = 0x14C4
Dec 2 13:30:30.573: %ISDN-6-CONNECT: Interface Serial0:30 is now connected to 0
091407759160
Dec 2 13:31:30.594: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId D
8F8EC35 EBEB1810 8BC40010 DC2FB16E, SetupTime 13:30:14.934 GMT Mon Dec 2 2002, P
eerAddress 0091407759160, PeerSubAddress , DisconnectCause 54 , DisconnectText
call id in use, ConnectTime 13:30:24.584 GMT Mon Dec 2 2002, DisconnectTime 13:3
1:30.594 GMT Mon Dec 2 2002, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitP
ackets 924, TransmitBytes 21703, ReceivePackets 1091, ReceiveBytes 25218
Dec 2 13:31:30.594: %ISDN-6-DISCONNECT: Interface Serial0:30 disconnected from
0091407759160 , call lasted 66 seconds
Dec 2 13:31:30: ISDN Se0:15: TX -> DISCONNECT pd = 8 callref = 0x14C4
Dec 2 13:31:30: Cause i = 0x80D4 - Call ID in use
Dec 2 13:31:30.750: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId D
8F8EC35 EBEB1810 8BC40010 DC2FB16E, SetupTime 13:30:14.890 GMT Mon Dec 2 2002, P
eerAddress , PeerSubAddress , DisconnectCause 54 , DisconnectText call id in us
e, ConnectTime 13:30:24.580 GMT Mon Dec 2 2002, DisconnectTime 13:31:30.740 GMT
Mon Dec 2 2002, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 1091,
TransmitBytes 25218, ReceivePackets 924, ReceiveBytes 21703
Dec 2 13:31:30: ISDN Se0:15: RX <- RELEASE pd = 8 callref = 0x94C4
Dec 2 13:31:30: ISDN Se0:15: TX -> RELEASE_COMP pd = 8 callref = 0x14C4
Please help me
Kiran
Silver
Re: Call id in use
The disconnect is most likely coming from the IP network. Can you run traces on the originating gateway and see what happens.
Re: Call id in use
The scenario is like this...
The calls from external clients are coming to a softswitch, and softswitch sends the calls to the cisco AS5300 from where they get terminated via a dedicated channel. Where do you want me to run traces on now.
Please reply.
Thank you.
99
