Call log options for received calls
Could you tell me if it's possible to insert the 9 in the log information for received call, because if you want to dial it you have to modifie before you dial.
Thank you!
  • Other Collaboration Voice and Video Subjects
Re: Call log options for received calls
Yes why not,
You need to do some manipulations with your CSS , Partition and Translation pattern
1. Create a prtition called PT_Incoming_Number
2. Create a call search space called CSS_incoming_Number and add PT_incoming_Number created above to it.
3.Create a translation pattern and put it in partition PT_Incoming_Number and Call serach space should b e the normal call search space used for your phoness.
4. check the calling party transformation and 9 to the prefix outgoing number box.
5. don't change anything in the transaltion pattern exceot those mentioned in 3 and 4 above
This way all incoming called number would match the none translation-pattern and a 9 is prefixed in front of the calling number.
Hope it helps
Tola.
Re writing step 4
4. In the traslation pattern put the Internal numbering traslation pattern match say if you have incoming calls with 7 digit then use XXXXXXX as you pattern
5. check the calling party transformation and 9 to the prefix outgoing number box.
6. Called number mask use XXXXXXXXXX for ten digit incoming number or 1XXXXXXXXXX if the incoming number has a 1 etc.
7. Called number Transformation mask should be the same as the Translation pattern XXXXXXX.
8.Apply the Call search space created above in 2 to te incoming gateway Call serarch space entry.
X means pass the digit matched in those position hence you called number is maitaned as received but 9 is prepended in front of the calling number. After translation the call is router to the intended destination if the Call Search Space attached in step 2 permits.
Tola.
Check out the Cisco Press Callmanager fundamentals book pg.136. It has a detailed explanation on how to configure this option.
-lennie
207
