call manager and gatekeeper
hi all,
Does ccm 3.x perform gatekeeper fonctionalities
(call admission control) or do i need to conf a router to do this?
is it protocol dependent, i mean if i work in MGCP
between ccm and my gateway can ccm perform cac?
is it architecture dependent ? if i have a ccm on my main site ,how can i perform CAC for the remote site
for outbound calls?
Thanks for your time and sorry for these basics question
1 REPLY
Re: call manager and gatekeeper
On call manager you can use location to perform CAC. If you have a GW on remote side you can put that gatway in certain location and assign certain amount of bandwidth. Call manager will then keep track of amound of bandwidth used between main and remote location. If end device makes a call to remote site and bandwidth is not available for this call the call will fail.
Please refer to the attached link..
http://cisco.com/en/US/partner/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c4c85.html
Hope that helps..
ketan
82
