Call Manager Audio Source on a remote router
Can someone enlighten me to a URL or give me some insite on if you can / how to configure a remote branch router to be the Music on Hold source for that branch's phones. How do you configure router and how do you configure Call Manager. What considerations do I need to think about when it comes to regions and codec? What about multicast or not?
Thanks in advace - S
Silver
Re: Call Manager Audio Source on a remote router
Thanks, looks like that will work.
Green
Dear All ,
I am still experiencing problems to establish an InterCluster Trunk between 2 CCM Clusters. Please find below brief description of the configuration on both CCM's :
1st CCM :
1.A - Intercluster Trunk - Non GK Controlled - that have the IP Address of the Second CCM Configured in it.
1.B - Route Pattern that contains in its Gateway Route List the Trunk mentioned above.
2nd CCM :
2.A - Intercluster Trunk - Non GK Controlled - that have the IP Address of the First CCM Configured in it.
2.B - Route Pattern that contains in its Gateway Route List the Trunk mentioned above.
I ensurred many times that the CSS & Partitions are having the approperate Access.
I suspect that the Problem is that the 2 Trunk is not Up & Running between the 2 CCM's , and the Problem that i do not know any tool on the CCM that can ensure the operation of the Trunk between the 2 CCM's . If it was a GK Controlled Trunk it would be easy to issue the Commans ( #show gatekeepr endpoint ) and this would show us all the registered Trunks. Is there any tool on the CCM to know the Registered Trunks ?
M.Tag
104
