Community Member
Call Manager backup/tape problems
I was looking thru the call manager backup logs today and saw something wrong. Here is a copy of the log, but basically it states that there is a problem opening the tape to verify the backup. Does this mean there is something wrong with the tape itself, or something else? It says that the backup completed successfully, but it can't verify and the error shown when trying to verify, to me, looks awefully disconcerting....
I'm using the following versions:
Backup 3.5.44
Restore 3.5.44
Viewer 3.5.44
stiTape.dll 1.0.1095
Here are the logs (I'll edit for space. If you need the whole thing, let me know):
*stiBack.log*
[02:00:01] ______________________________________
[02:00:01]
[02:00:01] Cisco IP Telephony Applications Backup Utility
[02:00:01] by Spirian Technologies Inc
[02:00:01]
[02:00:01] Backup service 3.5.44
[02:00:01] Restore applet 3.5.44
[02:00:01] Viewer applet 3.5.44
[02:00:01] stiTape.dll 1.0.1095
[02:00:01]
[02:00:01] Opening stiBack.log on 12/02/2003
[02:00:01] Local machine name is Ccdccmpub
[02:00:01] Local IP address is 172.20.10.10
[02:00:01] Service account is BackAdmin
[02:00:01] Backadmin has local administrative rights
[02:00:02] Found 25162MB available on the boot partition for staging the backup
[02:00:02] Backup running with Low priority
[02:00:21] Staging CallManager target Ccdccmpub
[02:00:21] Finding latest Cisco CallManager database on Ccdccmpub
[02:00:21] Dumping Ccm0300 database on Ccdccmpub
[02:00:24] Staging database dump file from Ccdccmpub
....snip.....
[02:02:59] Saving version information
[02:03:00] No Cisco CER targets found
[02:03:01] Staging stiBack.log file as 00stiBack.log
[02:03:01] Staged stiBack.log file successfully
[02:03:01] Opening backup media Tape0
[02:03:28] Copying files to Tape0
[02:06:12] Finished backing up files to Tape0
[02:06:12] Closed backup media
[02:06:13] Opening backup media to extract catalog Tape0
[02:11:01] Finished getting file information
[02:11:01] Closed backup media
[02:11:01] Catalog created successfully
[02:11:01] Could not open the catalog file
[02:11:01] Failed to verify archive on backup media. Please check log
[02:11:02] Closing stiBack.log on 12/02/2003
[02:11:02] RESULT: Backup completed successfully
And here is the tape log:
*stiTape_0.log*
stiTapeErrorMap: ERROR_NO_DATA_DETECTED
Closing TapeDevice
Callback =00000000
BlockSize=00008192
TotalMB =00000314
UpdateMB =00000000
Update% =02
Device:[\\.\Tape0] opened for 0
GetBlockSize [16384]
SetBlockSize to [16384]
Closing TapeDevice
Callback =00000000
BlockSize=00008192
TotalMB =00000000
UpdateMB =00000000
Update% =02
Device:[\\.\Tape0] opened for 1
** Signature: 0x55aa
** Version : 0x106
** Size of TapeLabel = 160 (0xa0)
** Size of FileInfo = 1024 (0x400)
** Size of TapeBlock = 16384 (0x4000)
** Label: STI_TAPEBACKUP created on Tue Dec 02 02:03:01 2003
Closing TapeDevice
STI TAPE LOG Created on Tue Dec 02 12:13:00 2003
Any ideas?
Bronze
Re: Call Manager backup/tape problems
When was the last time you used a new tape? My guess is it has gone bad.
Community Member
This is the first time I've used this tape. It's fresh out the box....but I'll put in a new one and see how tonight's backup goes.
I'll update tomorrow. Thanks...that's what I thought, but this is my virginal trip down call manager backup lane....
Community Member
New tape, same error. Any ideas?
Community Member
That error ERROR_NO_DATA_DETECTED looks like a Win32 system error = The end-of-data marker was reached during an operation.
Do you use the drive regularly ? If so you might want to use a cleaning tape. Try to format a new tape.
Also if your backup fails try and make a backup to a network drive.
JK
Community Member
How long has this drive been in use? What kind of drive is it? Backup to a network drive is a good idea, just until you get the tape working.
-Dennis
Community Member
Brand new tape drive on a brand new server. In service less than one month. Have made backups to network...and am working a case with cisco to find out if this is cosmetic or a real problem.
Loy
Community Member
FYI, for anyone having this problem, it was something funky with the way the backup program got installed. I ended up opening a case and after much laborious whatnot, I uninstalled the backup software and reinstalled. It worked like a champ, no worries.
Enjoy,
Loy
Community Member
Do you have the Cisco Security Agent Installed? We had problems with the Agent and STIbackup
Community Member
yes...i did the typical install of cm, all of the updates, and then the CSA. I guess that could have done it, but the bottom line was that I uninstalled the STIbackup utility and reinstalled and it worked just fine after that.
156
