10-19-2005 05:13 AM - edited 03-13-2019 10:55 AM
Hi all.
I've got a ROUTER 2651XM with an IOS Version 12.3(8)T3, and a Voice Card for 2 ISDN BRI.
The voice gateway is connected, at the other side, to a CallManager 3.3(3).
I'd like to terminate ANY CALLS after 15 minutes of conversation...
How and Where can I set this timeout?
10-19-2005 07:51 AM
There is no such setting on either CCM nor the GW.
Chris
10-19-2005 05:43 PM
On the router, see if you can use 'timeout absolute 15' under either the BRI or dialer interface.
10-19-2005 11:14 PM
Hi and thanks for the answer.
I've already tried (at the BRIs) the command 'timeout absolute', putting the value '1' (timeout absolute 1).
So, I was waiting for my call to be disconnected after one minute... but it happens only for the FIRST call which occurs after I gave the command on the router. The next calls does not to have the limitation and the duration is not of one minute.
D'you know why?
10-20-2005 03:05 PM
Can you post your router config?
10-20-2005 11:18 PM
