call manager call connection timeout
m.paolelli
Hi all.
I've got a ROUTER 2651XM with an IOS Version 12.3(8)T3, and a Voice Card for 2 ISDN BRI.
The voice gateway is connected, at the other side, to a CallManager 3.3(3).
I'd like to terminate ANY CALLS after 15 minutes of conversation...
How and Where can I set this timeout?
5 Replies 5
Chris Deren
There is no such setting on either CCM nor the GW.
Chris
tnooning
On the router, see if you can use 'timeout absolute 15' under either the BRI or dialer interface.
Hi and thanks for the answer.
I've already tried (at the BRIs) the command 'timeout absolute', putting the value '1' (timeout absolute 1).
So, I was waiting for my call to be disconnected after one minute... but it happens only for the FIRST call which occurs after I gave the command on the router. The next calls does not to have the limitation and the duration is not of one minute.
D'you know why?
Can you post your router config?
Hi. My router configuration (I've cut off the 'timeout absolute 1' command for it didn't work... but the first time!) is in attach...
Thanks for any help.
