Call manager DDI and translation pattern
I have a 2811 router with isdn connectivity. DDI numbers allocated are similar to 455xxx where xxx is 100 to 299
I need the call manager to allow these calls to go to device numbers in the format of 8xxx where the xxx relates to the ddi number.
Is there a good document that details inbound translation that would assist me with this task.
Simon
  • Other Collaboration Voice and Video Subjects
Re: Call manager DDI and translation pattern
Take a look at the following link on translation patterns. Basically, you would create a translation pattern of 455XXX and make the Called Party Transform Mask 8XXX. Also, Make sure that the translation pattern has a valid partition and calling search space.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed690.html
Hope this helps. If so, please rate the post.
Brandon
Brandon
Thanks a lot for the reply. This is what I have done to date. what is the relationship between the xxx in the 455xxx and the xxx in the 8xxx ?
Simon
Perhaps I could add a little more if that is ok. I have checked via debug isdn that the requested number is presented on the gateway. Is there a way of checking that this is passed to the call manager?
Simon
You could look at a trace on CCM. What happens when you call the number? Fast busy?
Brandon
Simon,
If you have a called number of 455123, it will be translated to 8123.
Brandon
Hall of Fame Super Silver
As Brandon said make sure that the GWs Calling Search Space has access to the TPs partition, and number of significant digits is set correcttly to 6 or ALL. Also make sure that the TPs CSS has access to the phone's partition.
Chris
thanks for the feedback. Greatly appreciated. I still do not appear to have this working. More specfic details
isdn presents inbound call as 874007. I have a directory number of 4007 I have entered a translation pattern of 874xxx along with a mask of 4xxx
isdn q931 reports still
SETUP pd = 8 callref = 0x0059
Sending Complete
Bearer Capability i = 0x9090A3
Channel ID i = 0xA18381
Progress Ind i = 0x8483 - Origination address is non-ISDN
Called Party Number i = 0x81, '874007'
RELEASE_COMP pd = 8 callref = 0x8059
Cause i = 0x8081 - Unallocated/unassigned number
Please post CCM trace log for this call. Have you verified the CSS/Paritions as suggested?
Also, try assigning 874007 as the phone DN to elimiate the translation step.
Another question is do you use MGCP or H.323 on your GW? If H.323 make sure you have a matching dial-peer.
Chris
If you config your inbound translation in 2811, you can also test and debug the translation rule with IOS commands.
Router# test translation-rule name-tag input-number
Router# show translation-rule [name-tag]
Router# debug translation min
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a0080094681.shtml
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
1164
