Call manager device rehoming issue
Hi Frenz,
I am getting a error on the ccm (4.1(2)).there are continuous error on the ccm event viewer. The error says that a device is trying to register with the ccm1 and its rehoming to another ccm in the middle of registration .and on ccm2 also I get the same error .so I understand that the device is not registering with either ccms and its trying to rehome and the event logs is getting full coz its sends 5 to 6 errors in every second.
Again the device name I see is MTP0011BB085AA0 and the device ip address I see is my voice gateway IP . I am unable to identify this device.
The reason codes of the event are coming as either 3 or 6 and the device type 111 and 255 respectively.
I would appreciate a prompt advice on this issue as my ccm is getting stuck once the event log is full. Right now I am manually clearing all the events.
Please advice
Jaleel
Re: Call manager device rehoming issue
Jaleel,
Go to Service -> Media Resource - > Media Termination Point and see if you Search/Find an enhanced Media Termination point (IOS based) added under this. You may be able to locate the above MTP here. If yes you may delete it (but make sure this resource is also not being used in a Media Resource Group / List / Device pool).
Thanks for the prompted reply .. i am not using any IOS MTP devices .how ever to make sure i have checked the media termination ponits and i can see only my ccms and dedicated moh server as media termination ponits.
i really cant figure out which device it is and y its not registering..
please advice .
Cheers
Jaleel
Super Bronze
Registration is initiated from the end device, not the CallManager - so if your gateway is trying to register as an MTP there must be some config on it that is telling it to register....
Can you post the config of your router? Or post the output of 'show sccp'?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
hi Aaron
please find the config
VOIR0126512#sh sccp
SCCP Admin State: UP
Gateway IP Address: 10.1.2.11
Switchover Method: IMMEDIATE, Switchback Method: GUARD_TIMER
Switchback Guard Timer: 1200 sec, IP Precedence: 5
Max Supported MTP sessions: 0
User Masked Codec list: None
Transcoding Oper State: DOWN - Cause Code: NOT_REGIS_WITH_CCM
Active Call Manager: 10.100.1.12, Port Number: 2000
TCP Link Status: CONNECTED
Conferencing Oper State: DOWN - Cause Code: DSPFARM_DOWN
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED
Call Manager: 10.100.1.11, Port Number: 2000
Priority: 1, Version: 3.1 or Higher
Priority: 2, Version: 3.1 or Higher
now i understand that this sccp is initiating a connection towards the ccm and its not registering ..
and i have the following config on the gateway
sccp local FastEthernet0/0.5
sccp
sccp ccm 10.100.1.11 priority 1
sccp ccm 10.100.1.12 priority 2
is this config really required there or can i remove this ..
Please advice
Cheers
Jaleel
MTP can also be xcoders. But, if you are not doing trascoding on your voice gateway, then you do not need any sccp configuration.
Super Bronze
Hi Jaleel
Looking at the output you've posted, no services are registering successfully.
It looks like someone may have configured the GW for transcoding (is there a command like transcoder maximum-sessions in there as well somewhere?).
It may be that someone has deleted the transcoder from CallManager (hence the not_regis_with_ccm message on your show sccp output).
Really you need to find out whether a transcoder is required (and which MRG/MRGLs it should be in if it is needed), or just type in 'no sccp' on the gateway to stop the errors.
Aaron
please rate helpful posts
Hi Aaron,
Thanks for the the information and your advice now i have disabled the sccp on the gateway and everything seems to be ok.
Thanking you again for the prompt help ..
Cheers
Abdul Jaleel
Super Bronze
Good to hear...
Please take the time to rate posts you find useful.
Aaron
251
