Community Member
Call Manager Express Hunt Group roll over doesn't work correctly
Hello,I have a wierd issue occuring on the CME portion of a client's UC520. Currently, I have a hunt group set up that has 1 user and then the auto attendant. Basically, I want to give a user a chance to answer the main line, and if she doesn't, it then roll's to the main auto attendant. This is working as long as I keep the time out on the hunt group under 12 seconds. The issue is that is about 2.5 rings. She'd like a little more time to be able to pick it up. When I put the time out above 12 seconds (say 16) and dial from an external number, it rings her phone correctly, then you can hear it attempt to transfer, but it transfers it back to her phone instead of rolling over to the auto attendant. You can even see on her phone that the transfer occurs and it transfers to herself. For an instance, it shows 2 calls with the same caller ID. Change the time out back under to 12 or under, and everything works great. Any help would be greatly appreciated.
Hall of Fame Super Gold
Re: Call Manager Express Hunt Group roll over doesn't work corre
Exact IOS used ?
Community Member
Sorry about that. Here is the IOS.
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
And here is some relevant code.
ephone-hunt 1 sequential
pilot 501
list 201
final 401
timeout 11
no-reg pilot
statistics collect
destination-pattern 401
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
Since you've only one DN in the hunt-group, can you try sending the call directly to the DN only ?
Community Member
Well, I don't think I want to do that b/c the purpose is to allow the paralegal to attempt to answer it if she is available. If she doesn't, then it rolls to the auto attendant where the caller can then navigate the menu tree to reach their party.
It's a very common configuration, under ephone-dn:
call-forward noan XX timeout YY
where XX is AA number. You can also create a custom AA if you want.
Community Member
But if I did that, then the person would not have personal voice mail correct?
I guess I could set up a 2nd line.
I see.
Yes, a 2nd line is probably the best idea. She will also to selectively set CFA for it if she wants.
512
