Call Manager Express Problem
I have installed the CM Express 3.03 and I noticed that the "user" login gives full access to the web admin like an administrator. So I can see all the options instead of seeing only the ones related to my phone. Someone has tried it? I'm using a 1760 router.
Fabio
  • Other Collaboration Voice and Video Subjects
Re: Call Manager Express Problem
Fabio,
Is the user password the same as the enable/secret password ?
Could be you are being authenticated at level 15 and if "ip http authentication" is set to allow authentication using the enable password then you are in as admin.
Phil
You are right, this is the cause. I'm in lab environment so I set all the password the same to be sure to not forget it. So, at the end the "username" is not taken into account by the system. It uses only the passord in this case. Thanks a lot,
Fabio
64
