07-23-2002 01:27 AM - edited 03-12-2019 08:01 PM
Does someone who can explain to me why in the installation of the Call Manager 3.2.2c on an approved-cisco Compaq DL320 does'nt work and fail with this msg :
"This application may only be installed on servers that were deployed using the standard cisco-approved process"
Thanks.
07-31-2002 11:37 AM
It is approved on that platform so TAC should support you. I'm planning a similar deployement, can you come back and tell us what you find and I'll do the same if I learn anything new?
08-01-2002 02:09 AM
Did you install the base operating system using the CISCO CD's?
Sounds like that part of the installation did not write the cisco-signatures into the registry!
