Call Manager - Meet Me can only be used with help from operator
There is probably very simple I am over looking, however when I set up a conference bridge Internal users can access it without any issues, however, if you are calling in from the outside, and you access the bridge by extension, it will not work. You need to get transfered from the operator.. is there any way to allow people to dial in, nad go to the bridge by punching in the bridge extension?
Re: Call Manager - Meet Me can only be used with help from opera
Are you going through an Auto-Attendant (Unity or IPCC)? Assuming you are using an AA then, you still need an internal user to start the bridge via the Meet-Me softkey. If the bridge is active though you should be able to create a Call Handler in Unity that allows transfers to that bridge number or a rule in your script that transfers on to that number.
Fred is correct. I have this one running by making a call handler for each meet-me extension. I am not sure if there is a way to make a wildcard transfer ?
130
