Call Manger 3.0(8) to 3.11 upgrade
Greetings,
I am upgrading CM3.0(8) to 3.11.
The box is a MCS7835.\
There are several issues that I am concerned about.
1.Failover in the event Mr. Murphy shows his ugly head.
2.Is there a BIOS upgrade that needs to be applied prior to upgrading?
3.Compatability issues with Unity 2.4
Rick
Re: Call Manger 3.0(8) to 3.11 upgrade
Here's a quick answer to your questions:
1. I always break the RAID mirror before any upgrade. It's a little more work, but it makes your life whole lot easier for back out. There are good instructions for breaking the mirror in the ciscocm-fmu.3-0-11ReadmeFirst.pdf document.
2. You should already have applied the BIOS upgrade for the 3.05 and above, which was 7835-BIOS-11-08-00.exe. The next BIOS upgrade is for 3.1
3. I am not sure about Unity 2.4. However, the release notes for 3.0(11) states that it was tested with Unity 2.4.6.102
Just make sure that you are using a good AvTSP. We are Unity 2.4.6(102) with 10.0.0.32 TSP. This seems to work fine.
93
