Call Mgr. 3.1 Upgrade
cbuckingham
I see in the notes, that CM 3.1 upgrade has been from a 3.08 system & higher.
Would you suspect any problems with a 3.07 system upgrading to 3.1?
Thanks in advance,
Chris Buckingham
k.poplitz
Level 3
Level 3
Since the release notes say 3.0.8 or higher, go to that first. If you go from 3.0.7 you might have problems. (Talk to Cisco TAC to be sure.)
I agree.
It doesn't seem like there is that much of a differance between 3.0.7 & 3.0.8.....
It just means that I have to spend that much more time finilizing a 3.1 upgrade, which in turn costs the customer more dollars.
There was no major reason (in this case) to upgrade from 3.0.7 until 3.0.11 came out.
By the time that decision was made, our Cisco Rep announced the 3.1 release to be within a month.
So the truck has to roll twice to the customers site.
Regardless...
I just wish a Cisco Engineer would have responded.
d-frost
Actually if you read the Upgrading Cisco CallManager Release 3.1(1), link below, it says that you can upgrade to 3.1 from any previous version of CallManager 3.0. It does not support an upgrade from anything earlier than 3.0
http://www.cisco.com/cgi-bin/Software/Tablebuild/download.cgi/ciscocm-ffu.3-1-1ReadmeFirst.pdf?code=&file_size=344905&filename=cisco/crypto/3DES/voice/cmva/ciscocm-ffu.3-1-1ReadmeFirst.pdf
