Community Member
Call no catch channel in T1 ISDN
Hi Body,
I don't know where is the problem, all my setting is correct, I think so.
------------------00000000000000-----------------------
This is log of one call:
23:17:00: ISDN Se3:23: RX <- SETUP pd = 8 callref = 0x000A
23:17:00: Bearer Capability i = 0x9090A2
23:17:00: Channel ID i = 0xA98381
23:17:00: Calling Party Number i = 'A', 0x80, '2131231312', Plan:ISDN,
ype:Subscriber(local)
23:17:00: Called Party Number i = 0xC1, '225763360340', Plan:ISDN, Type
Subscriber(local)
23:17:00: ISDN Se3:23: Incoming call id = 0x000F, dsl 3
23:17:00: ISDN Se3:23: NegotiateBchan: bchan 1 intid 0 serv_st 0 chan_st 0 call
d 0x0000 ev 0x90 n/w? 0
23:17:00: Negotiated int_id 0 bchan 0 cr=0x800A callid=0x000F lo_chan 1 final i
t_id/bchan 0/1 cause 0x0
23:17:00: ISDN Se3:23: LIF_EVENT: ces/callid 1/0xF CALL_INCOMING
23:17:00: ISDN Se3:23: CALL_INCOMING dsl 3 bchan 0
23:17:00: ISDN Se3:23: CALL_INCOMING: call type is VOICE ULAW, bchan = 0
23:17:00: ISDN Se3:23: Event: Received a VOICE call from 2131231312 on B0 at 6
Kb/s
23:17:00: ISDN Se3:23: RM returned call_type 1 resource type 0 response 2
23:17:00: ISDN Se3:23: INCOMING CALL: VOICE ERROR: Requested circuit/channel no
available(0x2C): bchan 0, call id F
23:17:00: ISDN Se3:23: process_disconnect(): call id 0xF, call type is VOICE, b
idb 0x625848A4, ces 1, cause Requested circuit/channel not available(0x2C)
23:17:00: ISDN Se3:23: TX -> CALL_PROC pd = 8 callref = 0x800A
23:17:00: ISDN Se3:23: TX -> DISCONNECT pd = 8 callref = 0x800A
23:17:00: Cause i = 0x80AC - Requested circuit/channel not available
23:17:00: ISDN Se3:23: RX <- RELEASE pd = 8 callref = 0x000A
23:17:00: ISDN Se3:23: CCPRI_ReleaseCall(): bchan 1, call id 0xF, call type VOI CE
23:17:00: CCPRI_ReleaseChan released b_dsl 3 B_Chan 1
23:17:00: ISDN Se3:23: LIF_EVENT: ces/callid 1/0xF CALL_CLEARED
23:17:00: ISDN Se3:23: received CALL_CLEARED call_id 0xF
23:17:00: no resend setup, no redial
23:17:00: ISDN Se3:23: TX -> RELEASE_COMP pd = 8 callref = 0x800A
-------------------------------00000000000-------------------------------
This is my setting:
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(2)XA5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
Voice Feature Card in Slot 1:
VCware Version : 9.08a
ROM Monitor Version: 1.3
DSPware Version : 3.6.6aL
Technology : C549
-----------------------000000000000000---------------
GRT_LA#sh voic port 3:D
ISDN 3:D - 3:D
Type of VoicePort is ISDN
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 14 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 8 ms
Playout-delay Mode is set to default
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 200 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Station name None, Station number None
Voice card specific Info Follows:
DS0 channel specific status info:
IN OUT
PORT CH SIG-TYPE OPER STATUS STATUS TIP RING
----------------------------ooooooooooooo---------
ISDN Se3:23, Channel [1-24]
Configured Isdn Interface (dsl) 3
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3
Service State (0=Inservice 1=Maint 2=Outofservice)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2
-----------------------000000--------------
controller T1 3
framing esf
clock source line secondary 3
linecode b8zs
pri-group timeslots 1-24
-------------------------0000-------------------
interface Serial3:23
no ip address
isdn switch-type primary-4ess
isdn incoming-voice modem
no cdp enable
-----------------------00000---------
I apreciate your Help
Community Member
Re: Call no catch channel in T1 ISDN
You haven't specified in your example if you have any VoIP dial-peer define on the GW.
It is vital in order to proceed with an inbound traffic to have a VoIP dial peer.
Community Member
Hi yraps,
Yes, I have one dial peer voip for this call, and this is:
dial-peer voice 576 voip
destination-pattern 011576T
session target ipv4:68.151.29.38
num-exp 22576 011576
Any help please give me, let me do one questions, do you have conection isdn, between Cisco AS5300 and excel switch??
if is yes what is the true setting
121
