call pickup group error - key is not active - CUCM9
I am using Cisco CUCM 9, I set up a call pick up group for a few phones, when I tried to pick it up when the other phone is ringing by pressing the Pickup button, it says " key is not active"
It should be just a simple setting to add the group to the device according to my understand... the pickup number is same partition as the directory number....
anywhere else I should check to resolve this issue?
note: setting access is enable on the phone
Rachel
Hi Rachel,Have you added the
Hi Rachel,
Have you added the Pickup Group the DN? Browse to the Phone via Device > Phone and click on the phone, then click on the Directory Number and scroll down to Call Forward and Pickup Settings and select the appropriate group from the drop down menu. You will need to do this on all the phones you want in the pickup group, alternatively you can do this via BAT.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/9_1_1/ccmfeat/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91_chapter_0111.html#CUCM_TK_C823CE5F_00
Richard
Hi Richard yes I have already
Hi Richard
yes I have already associated the call pickup group to the DN.
it seems the issue may be more related to the button seem not active
when I pick up the handset and the  pressing the PickUp button on phone, it says key is not active
but the setting access is enable on the phone
thanks
Rachel
VIP Purple
Hi,[+5] to Richard for tips
[+5] to Richard for tips.
Can u try going off-hook first and then, press pickup softkey?
regds,
aman
Hi Aman yes, I pick up the
Hi Aman
yes, I pick up the handset and then press pickup
I also tried to just press " new call" and then press pickup
but it still the same error message " key is not active
I have also tried it on a few different handset
thanks
VIP Purple
Hi Rachel, what is the phone
Hi Rachel,
what is the phone model u are using on which this problem is coming and the firmware version ?
regds,
aman
I am using Cisco 7942I have
I have upgraded the firmware to SCCP42.9-4-2-1S... still not working
7960 and 8941 also not working
Rachel,Are the calls being
Rachel,
Are the calls being delivered to the phones via a hunt pilot?  If so, you also need to configure the Call Pickup Group within the Hunt Pilot.
(something else to check)
Dave
342
