If CallManager fails,
1. What happens to a call from the PSTN through H.323 GW ?
1b. With and without GateKeeper.
2. What Happens to call when running over IPWAN ?
I am interested if the voice path is perserved, and maybe the signal path is lost. Will call remain up if CCM fails ?
What a gate failure, Iassume the PRI goes down and the channel disconnects. Will the Gateway perform any signal freezing, then switch to secondary gateway.
Thanks for all you consideration..
Steve
